Old 09-17-2011, 06:25 PM   #1
fantasticfour
Member#: 215453
2000 2.0RSTi
Default Help me wire up A/C after swap....
The car is a 2000 RS. The A/C components should be fine, they're the original from before the swap. The engine/ECU/wiring are all EJ20K.
I need to figure out how to wire up the A/C properly. I've got the USDM and JDM wiring diagrams but because the donor car uses a different climate control than the RS one, it's not quite "plug and play".
Mainly it's how to wire the evaporator thermoswitch that has me puzzled. The A/C on switch is also wired differently between the two cars and the JDM one has a couple of extra components that I'm not sure I need.
If anyone has done this swap previously with working A/C, please point me in the right direction. Thanks in advance.
fantasticfour is offline   Reply With Quote
Old 09-19-2011, 01:40 PM   #2
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
what engine do you have in there now?
Look at this thread. Yes I know there is a lot to go through. There there is some good info that may help you.
http://www.rs25.com/forums/f128/t828...add-notes.html
Osgood30 is online now   Reply With Quote
Help me make up my mind with me build (ARP studs) cribbie Built Motor Discussion 3 11-17-2009 05:32 PM
Need help re-installing wiring/abs control unit after ej20g swap curt Subaru Conversions 2 11-03-2009 05:21 PM
So I asked the wife to get me a Coke to help me wake up .... Jessie James Off-Topic 35 02-17-2009 12:01 AM
Help me wire this up! LC-1 Wideband to Fuel Level on the ECU thrlskr Electrical & Lighting 10 09-10-2008 09:27 PM
HELP - auto transmission no response after swap zrl Transmission (AT/MT) & Driveline 2 09-07-2007 10:13 PM
