Notices
Old 09-18-2011, 03:18 PM   #1
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Default Stance GR+ Coilover Install | 2011 WRX
Time for another install.
Check out my build thread to see more images, write-ups and a lot more installs. Here is the link.
This time I decided to upgrade the suspension to Coilovers in order to get a little more dampening and to lower the car down.
I went with STANCE for a couple reasons. Customer service, Built in the USA, great price, availability, and ease of install. My first thought was to do Koni shocks and springs and would have done it if they weren't backordered for a while longer. In my search for Koni's I ran into THMotorsport who happened to be having a Labor Day sale so I was able to get the Stance's for $1100.
First impression was amazed by the quality of the coilover, my last pair was over 10 years ago and they were $2800 w/o camber plates and height adjustment at the bottom of the strut. They have come a long way and they are built as works of art, they're beautiful!
Okay, so to the install pictures...
Before the install
Tools needed besides a Jack and Jack stands (or lift)
Rear first: Remove the 17mm bolt at the bottom of the shock and the 14mm bolt on the sway bar.
Remove the two 14mm bolts inside the car.
Once all the bolts mentioned above are removed, push down on the rear brake rotor to release the shock from the lower trailing arm them remove the entire shock out from the car. Repeat on opposite side.
Once both are out, its time to measure.
Stock was at 17-1/2" from top to top of lower mounting bolt.
I took a guess and estimated 14-3/4" for the STANCE coilovers.
Time to install already. I placed the lower shock bolts it and the strut bar bolts in but only hand tight. (both sides)
The I used the jack on the lower knuckle to raise the shock into its mounting holes. Once the shock as getting compressed by jacking, I knew the shock was seated. I bolted the two 14mm bolts and set the dampening to 8 out of 15. (repeat on opposite side)
Once you have the inside bolts torqued, torque the lower shock bolt and the sway bar bolt. Lower the car back down and enjoy the new lowered rear!
Time for the Fronts!
Overland04 is offline   Reply With Quote
Old 09-18-2011, 03:19 PM   #2
Overland04
Member#: 293311
2013 FXT 6-Speed
Fronts are really easy, almost easier then the rears...
Remove the two 12mm bolts, one holding the brake line and the other holding the ABS sensor. Then remove the two 19mm bolts holding the strut to the hub.
Remove the three 12mm bolts under the hood. Once the bolts are removed the strut basically falls out (be careful)
Do the same measurements as you did in the rear. The stock struts were 17-1/2" and the Stances's were 15-1/4". The most important for me was to be exact between each side. If they are to high or too low at least they will be evenly high or low.
Installation is reverse of removal, bolt the top 12mm bolts, them jack up the knuckle till the large 19mm bolts slide in, them lastly most the two 12mm bolts for the brake and ABS lines.
I started out with my camber at +2 on both sides, mostly because I want to run as close to stock as possible.
Once everything is torqued, get the wheels back on then lower the car to reveal a sweet ride!
After the install
I took the car for a nice long ride over as much terrain as I could find to get a good feel of the setup. I'm in love so far, they are tight but not bouncy, the dampening is perfect with them all set at 8 out of 15, no squeaks, no rubbing, and it sits perfect for my taste.
I'm going to get the car aligned and corner balanced next thursday so I'm not to stressed about if the height is perfect on all 4 corners but as of now before settling, from the bottom of the center cap to the center of the fenders are all exactly at 14-1/2" The car doesn't pull at all and feels great.
Overall took about 2 hours not counting taking pictures. and I give it a 3 out of 10 for an install level.
Cheers!!
Old 09-18-2011, 03:36 PM   #3
sethsdown
Member#: 214083
2009 WRX Sedan
nice write up. love to see great pictures!
sethsdown is offline   Reply With Quote
Old 09-18-2011, 04:48 PM   #4
stormhalter
Member#: 145884
06 STi
I wish my car was that clean underneath, lol. Great write up.
I'm interested in these coilovers after this write up and seeing the ease of installation. Have you had any of the bumping or knocking associated with some coilover installs during turns or road bumps?
stormhalter is offline   Reply With Quote
Old 09-18-2011, 06:21 PM   #5
Overland04
Member#: 293311
2013 FXT 6-Speed
Thanks Seth!
Hey Storm, So far so good. Tough to really tell at the moment. I just put another 40 miles on them to get a better feel. I'm at about a 1-1/4" drop on stock 17x8 235-45 R17 tires. With the stock set-up I have no rubbing, scraping, knocking or anything, just a great ride so far. I would like to keep updating as the miles rack on but for now since they've only been in for 6 hours I don't have a very good evaluation report.
The dampening is amazing though!
Cheers!
Old 09-18-2011, 06:24 PM   #6
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
subscribed.....stances seem really popular because of their price....im interested to know how long they hold up before you start having problems....please keep updating as you see fit but dont forget about this
brew02wrx is offline   Reply With Quote
Old 09-18-2011, 09:20 PM   #7
sc00by4life
Member#: 97135
stance aren't made in the USA.
Old 09-18-2011, 09:33 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i cant see the pics on photobucket because they are blocked here....but its too low
Old 09-18-2011, 09:42 PM   #9
damonchoy
Member#: 279935
03 350Z - Summer
97 E36 328i - Winter
damonchoy is offline   Reply With Quote
Old 09-18-2011, 10:09 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Hi, I'm the Brakes, Steering & Suspension technical forum. I'm the proper location for this thread.
Originally Posted by Overland04 View Post
Is that nut the extended style that passes down through the pillow ball, like this Cusco one?
If it's not, then that seems like some pretty sketchy thread engagement.
Old 09-18-2011, 10:47 PM   #11
Shockwave179
Member#: 105522
+1
My buddy got some earlier this year for his 350z and the disaster in Japan prevented them from getting to the US for awhile.
Shockwave179 is offline   Reply With Quote
Old 09-18-2011, 10:56 PM   #12
sc00by4life
Member#: 97135
Not sure about OP's, but my GR+ Pro's (from the first batch released) have the nut with the extended sleeve.
Old 09-19-2011, 12:23 AM   #13
Mr. Me
Member#: 193598
2002 Bugeye Wagon
Ive got the gr+plus pros on my 02 wagon. Installed them about 8k miles ago and havent had any problems with them. Theyre responsive enough for autox and are comfy enough for dd use. The build quality was great for the price.
Mr. Me is offline   Reply With Quote
Old 09-19-2011, 12:30 AM   #14
jordanc15
Member#: 276118
2011 WRX
You can't possibly drive this car any farther than around the garage.... How the hell is it so clean underneath???
jordanc15 is offline   Reply With Quote
Old 09-19-2011, 12:35 AM   #15
iowanoob
Member#: 290885
like how it sits looks good!
iowanoob is offline   Reply With Quote
Old 09-19-2011, 07:35 AM   #16
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
i see your after pic but how much room do you have for raising it. can i get up to stock height? reason i ask is id love some coilovers but i already have to roll up on some 2x4's for oil changes for my mechanics lift, any lower and he'll really hate me.
bluemax189 is offline   Reply With Quote
Old 09-19-2011, 09:57 AM   #17
20pvwrx11
Member#: 271144
2011 Wrx
Satin White Pearl
^ id like to know as well. I already sit low enough stock.
20pvwrx11 is offline   Reply With Quote
Old 09-19-2011, 10:52 AM   #18
91cmcl
Member#: 272154
helpfull
91cmcl is offline   Reply With Quote
Old 09-19-2011, 11:54 AM   #19
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
nice write up , maybe include the torque spec
bbun is offline   Reply With Quote
Old 09-19-2011, 01:48 PM   #20
RL-N-AH
Member#: 107752
07 VF39 Power ;)
07 wrx wrb > 04 wrx aw
which stance coilover did you get? LX or GR plus
RL-N-AH is offline   Reply With Quote
Old 09-19-2011, 02:36 PM   #21
Overland04
Member#: 293311
2013 FXT 6-Speed
Hey Bluemax,
I don't believe I can get it to stock height. With having a safe amount of threads in the lower bracket I can probably raise it up a 1/2" which would give the car an estimated 3/4" drop. It looks a lot lower then it really is though, you should be ok on most lifts.
Old 09-19-2011, 02:44 PM   #22
Overland04
Member#: 293311
2013 FXT 6-Speed
They are the GR+
I didn't do a ton of research before I bought but the LX seem nice too. The inverted shock isn't a deal breaker for me so if I could have bought the LX for lets say $900, I probably would have.
Old 09-19-2011, 02:50 PM   #23
Overland04
Member#: 293311
2013 FXT 6-Speed
Hey Jordan,
I swear the car isn't as low as the picture looks, the more I look at it, I'm wondering why it looks that low. The drivers side was on a little hill about 4" higher the the passenger but in all honestly it's almost an exact 1-1/4 drop all around.
I'll take new pictures this weekend on flat pavement.
Oh also, the car only has 500 miles on it, I can only hope after a winter in Maine it will be this clean
Old 12-17-2011, 10:24 AM   #24
jwongx27
Member#: 300323
sub so i can knw what tools to use to lower car :thumbsup:
jwongx27 is offline   Reply With Quote
Old 12-17-2011, 10:39 AM   #25
Overland04
Member#: 293311
2013 FXT 6-Speed
I was shocked that it only took a couple hand tools to do...
Even if you had to buy the tools separately it would cost about $20
The picture in the top post is an accurate image of the tools used except for a jack and some jack stands.
Good luck!!
Kartboy Short throw install w/ Bushings, 2011 WRX 5dr. Overland04 Interior & Exterior Modification 142 06-10-2015 07:55 PM
KW Variant 1 Coilovers for 2011 WRX Cake Brakes, Steering & Suspension 11 12-31-2011 05:51 PM
WTB : STP exhaust for 2011 WRX 5dr nvrupnvrin Private 'Wanted' Classifieds 5 08-10-2011 06:15 AM
2011 wrx 5dr. What size sway bars?? ripalpine Interior & Exterior Modification 3 07-18-2011 03:43 PM
2011 WRX 5dr - Rear Window Condensation M3Octane General Community 13 12-15-2010 09:55 AM
