Old 04-15-2013, 03:16 PM   #76
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Originally Posted by Myth21 View Post
I'd be really interested in them if they offer different spring rates..Idk about 9/7k..
I don't think they offer softer springs but swift makes great upgraded spring that make this a much better combo. Even adding $300 springs still makes them a good deal.
Overland04 is offline   Reply With Quote
Old 04-26-2013, 11:10 AM   #77
Loring
Member#: 331979
Great write up, I am going to be swapping out my suspension over the weekend, just curious if you know the torque setting for the bolt that connects the endlink to the arm in the rear. Also what are you torquing the bolts at the bottom of the struts down to. Thanks in advance glad I found this thread.
Loring is offline   Reply With Quote
Old 04-26-2013, 11:19 AM   #78
Overland04
Member#: 293311
2013 FXT 6-Speed
Hey man,
Torque setting are as follows:
Endlink to swing arm is - 33lbs
Shock (rear) to swing arm is - 89lbs
Tophat to Chassis (rear) is - 23lbs x2
Shock (front) to knuckle is - 129lbs
Tophat to Chassis (front) is - 15lbs x3
ABS and Brake line (front) is 24lbs
Good luck!
- Jason
Old 04-26-2013, 11:26 AM   #79
Loring
Member#: 331979
Originally Posted by Overland04 View Post
Hey man,
Good luck!
- Jason
Awesome thanks for that, are you torquing the camber bolt down to 129 as well? Thanks for the fast response, I feel a lot better about doing this now, especially as I probably would have gone over 15 pounds on the front without knowing. Thanks again.
Old 05-17-2013, 11:56 PM   #80
S1CkWrx
Member#: 325249
2012 wrx
dgm
silly question i have the same brand coilovers im installing tomorrow night. shouldnt the front camber plates be dead center for being "stock"?
S1CkWrx is offline   Reply With Quote
Old 12-20-2013, 06:48 AM   #81
Profoxcg
Member#: 169036
2015 STI
^ I would think so, if you are going to use the camber bolt.
Profoxcg is offline   Reply With Quote
Old 06-05-2014, 03:08 PM   #82
matigas_TT
Member#: 322775
2012 WRX-4Dr
Thanks!Very easy install I though changing to coilovers was hard
matigas_TT is offline   Reply With Quote
Old 10-27-2014, 11:17 PM   #83
julionb
Member#: 358324
2013 WRX
Thanks! This helped me a lot with my Feal 441 install.
julionb is offline   Reply With Quote
Kartboy Short throw install w/ Bushings, 2011 WRX 5dr. Overland04 Interior & Exterior Modification 142 06-10-2015 08:55 PM
KW Variant 1 Coilovers for 2011 WRX Cake Brakes, Steering & Suspension 11 12-31-2011 06:51 PM
WTB : STP exhaust for 2011 WRX 5dr nvrupnvrin Private 'Wanted' Classifieds 5 08-10-2011 07:15 AM
2011 wrx 5dr. What size sway bars?? ripalpine Interior & Exterior Modification 3 07-18-2011 04:43 PM
2011 WRX 5dr - Rear Window Condensation M3Octane General Community 13 12-15-2010 10:55 AM
