Old 09-18-2011, 03:42 PM   #1
gtfaded
Member#: 142322
2002 wrx
wrb
Default Over heated + No start + engine clatter
My Friend just got a GC8 and we were just out driving when the engine began to clatter and then overheated and died. The res is full and was bubbling over but the oil is clean but it won't start just turns over. Any thoughts on where to start?
gtfaded is offline   Reply With Quote
Old 09-18-2011, 04:35 PM   #2
cmyles
Member#: 275572
2007 Built STi
Fuel , Air, Spark, Compression.
Start checking.
cmyles is offline   Reply With Quote
Old 09-18-2011, 06:47 PM   #3
gtfaded
Member#: 142322
2002 wrx
wrb
Nevermind pretty sure he spun a bearing.
Old 09-19-2011, 02:44 PM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Do not discount blown head gasket. Subies blow cardboard HG without getting coolant in oil or vice versa.
Refill coolant. fully bump coolant system and then use a coolant gas tester while the engine is running to determine if you have exhaust gas in your coolant.
TommyAtomic is offline   Reply With Quote
2005 Stock WRX, Fuel Pump keeps primeing over and over, no start Oem233 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-26-2011 03:47 PM
over heating/ heat no longer working johnlattanzi Newbies & FAQs 10 02-22-2010 10:04 AM
Engine over heating. Thermostat? RightyTighty Service & Maintenance 3 04-29-2006 08:33 AM
No Start Mystery!!! Turns over but doesn't start... super-ooh Newbies & FAQs 11 10-22-2005 01:48 PM
Over heated engine last night phat pat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-17-2003 12:51 AM
