Old 10-31-2010, 12:11 AM   #1
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Default **PhatBotti Tuned: 35R 2004 WRX, *STOCK 16 BIT ECU* 543.1 whp on 93oct *UPDATE**
Event: Dyno Tuning
Ambient Temp: 65
Elevation: sea level
Weather: sunny, cool
Tires: 17" rims/tires
Car: 2004 WRX
Tuner: STi Mikey of PhatBotti Tuning
Dyno Info: DynoDynamics w/ 1.2 CF
Transmission: 5 spd Andrewtech Built Dogbox
Gear: 3rd
Peak HP at RPM: 543.1 @ 6650 rpm
Peak Torque at RPM: 445 @ 5000 rpm
Baseline hp/tq for a stock on same dyno: 170whp, 2.0l
Target Boost: 25psi
Target AFR: 11.3
Fuel: 93 pump gas right from Shell's pump
Engine/Power Modifications:
2.5 hybrid with stock STi forged internals and ceramic coated top custom JE forged pistons (30cc dish) CR: ~8.3:1
Coated oem bearings
ARP casebolts, head studs, and rod bolts
2.0 WRX heads ported /oversized ferrea valvetrain dual springs
non AVCS Kelford 280/ 276 cams (need to raise the idle?)
Cometic HG's
Rotated Garrett 3582r turbo
tial 44mm with a .9 bar spring
hallman manual boost controller
blow thru 3" maf
Tial 50 mm BOV
3" catless exhaust
DW 1100 injectors
tgv deletes
perrin v2 fuel rails
dual walbros ( future- 2nd pump switched by solenoid)
precision 700 hp front mount w/ custom 2.75" IC piping
PPG SC 1-4 dog box w/ oem 5th, stock diffs/ axles
I had alot of fun tuning Chris's car today, partly because I felt like a doctor doing it
With such a setup, there was significant "noise" in the motor. After scaling the low voltage range and dialing in WOT fueling, I began thowing some boost at the car. The Utec would inconsistently pick up 2 counts, flashing the engine light.
No matter the ignition timing, boost level, or AFR, noise was in and out every few pulls.
Now, I have seen a few "false knock" cars live short lives in the past. I did not want to be that guy to take such a machine into my hands, and dumb down the knock sensor assuming that the noise was false.
I told the owner, Chris, we needed to use Det-Cans.
Chris got the equipment, mounted it to the block, we switched over to opensource, and on we went to making some power.
Im sure Im leaving some info out, but Chris will probably chime in. I think at the end of the day, though happy, he was regretting not going with a better rod. I had 15 gallons of race gas on me, 650whp on the stock 16bit would have been a cake walk
I cant wait, next week I'll be down in south florida tuning a few more setups just like this one + a few stg 2 cars.
Enjoy Nasioc, and happy Halloween
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 10-31-2010, 12:24 AM   #2
karlknaupp
Member#: 60871
04 Wrx & 17 fxt
damn thats nasty. 1/4 track appearance?
karlknaupp is offline   Reply With Quote
Old 10-31-2010, 12:28 AM   #3
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
He wants to go to ATCO. This setup is very similar to Jays05, who made 545whp when Junior tuned him. He went 10.7 @132, with a chitty trans. This thing will do 145ish in 4th, it should hall some major ass.
-Mikey
Old 10-31-2010, 01:51 AM   #4
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Idle is set to a nice 900 rpm.
STi Mikey is offline   Reply With Quote
Old 10-31-2010, 02:21 AM   #5
norcalwrx816
Member#: 203489
03 wrx wagon
flat4/Mayhem Tuning!
i love the sound of cams
norcalwrx816 is offline   Reply With Quote
Old 10-31-2010, 02:59 AM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
damn....i looked at the laptop once or twice....no love
Car was freaking fast with 600 lbs of passengers in it on pump gas.....i can only imagine what it felt like without us in it.....93 octane is like race gas compared to our piss 91
Old 10-31-2010, 03:22 AM   #7
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
big boy cams. non avcs.
maxpowr is offline   Reply With Quote
Old 10-31-2010, 03:28 AM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Have fun doing the exact same thing to my car next week
Him and I even have the same name, haha.
godforbid67 is offline   Reply With Quote
Old 10-31-2010, 08:44 AM   #9
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Nice job guys, I heard a guy saying that a car with 280 cams either kelford or gsc, is difficult to drive in the streets. That the car has to be rev to 3000rpm to get it moving, is that correct?
it sounds
Old 10-31-2010, 08:45 AM   #10
juanmedina
Member#: 133146
sweet Chris, you are going to be so happy
Old 10-31-2010, 09:09 AM   #11
KurtP
Member#: 44836
1999 Fozzy
good grief. those cams sound like a damn UH-60
KurtP is offline   Reply With Quote
Old 10-31-2010, 10:22 AM   #12
mikaust
Member#: 7468
2008 Outback Limited
That is one impressive set up. Nice tune!
mikaust is offline   Reply With Quote
Old 10-31-2010, 11:30 AM   #13
CatfaceType-R
Member#: 81102
nice stuff mike
Old 10-31-2010, 12:42 PM   #14
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
on one working walbro!!!???!!!
Old 10-31-2010, 12:44 PM   #15
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
is that you mike in the shorts in 40* weather...?
Old 10-31-2010, 12:57 PM   #16
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
it sounds
Thanks for the comments guys
Juan,
Having to rev the car to 3k to get going is not true at all. In all honesty, its not even close. The car takes off from a light as a stock car would.
Difficult drivabilty.. only if the basic tables in the ROM were touched upon and nothing else.
When I first got to the car, it would not hot start, or hold an idle for very long. It would stall when coming to a stop also, pretty much at every light and stop sign. Cranking tables, Warm up enrichment tables, per injector comps all had to be adjusted so that a good start up and idle was achieved.
A chit ton of maf tabbing was performed to scale the 3" blow thru perfect. I scaled the maf a week ago and it came to the dyno with corrections ranging from 3.1 in the A range to .2 in the C range.
Also, being a 16 Bit ECU, I initially half-maf'ed the car but had to end up 1/4 maf'ing in the end
If you put time and effort into a car like this, as did chris with the motor and myself with the tune, good results can be acheived with such a machine via ECU-Flash and RomRaider.
-Mikey
Old 10-31-2010, 01:01 PM   #17
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
spoken like abraham lincolns emancipation proclomation.
Old 10-31-2010, 03:04 PM   #18
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
Sounds nothing like a UH-60
RFoy91TSi is offline   Reply With Quote
Old 10-31-2010, 03:11 PM   #19
godforbid67
Member#: 137168
06 Built SGM WRX
it sounds
I dont think its as severe as that but its not fun.
My car bogs at anything under 2500 rpms whether trying to get moving or already moving. It actually really kinda sucks with the PPG's because the gears are so long.
Between the clutch, cams, and transmission its not easy but its not hard either. Its more than worth it for the benefits.
Old 10-31-2010, 03:21 PM   #20
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Chris,
Send me a list of mods so I can begin working on your map. I want to have all base files completed and in a seperate folder for the trip.
Text or PM me, thanks man.
-Mikey
Old 10-31-2010, 03:35 PM   #21
rob58
Member#: 192024
06 sti drag car
silver, built by the shop
nice work mikey,, good to see you at the shop on sat... rob...
rob58 is offline   Reply With Quote
Old 10-31-2010, 04:10 PM   #22
godforbid67
Member#: 137168
06 Built SGM WRX
Originally Posted by STi Mikey View Post
Chris,
-Mikey
Sure man, but I think your best bet is to work off the map im already on. Either way, pming you now.
Old 10-31-2010, 04:15 PM   #23
godforbid67
Member#: 137168
06 Built SGM WRX
Btw, are you able to get this car to not throw a cel? Idk if its the cams, injectors or w/e but my car always throws a code. It idles rough at first start up then the cel comes on.
Old 10-31-2010, 04:29 PM   #24
juanmedina
Member#: 133146
Chris u have BC 280s they are quite more mild than the kelford 280s or GSC 3s, I blame ur problem in the tuning. Mikey will get u r beast running perfect .
Mikey, would u recommend the kelford 280s for a DD like my car?
Old 10-31-2010, 04:59 PM   #25
godforbid67
Member#: 137168
06 Built SGM WRX
Yes I know, but I am sure drivability is very similar between the two.
*** Phatbotti Tuned 2002 WRX: 2.5L FP Red KSTech 83mm 16 Bit ECU 450whp E85 *** PhatBotti Tuning TKR Proven Power Bragging 34 11-22-2010 01:43 PM
Dyno Tune: Visconti @ THESHOPCT makes 360WHP on VF39 STRAIGHT 93 Pump Gas Visconti Proven Power Bragging 98 10-25-2010 08:29 AM
Swapping out a 16-bit ECU for a 32-bit thefoos Open Source Reflashes 8 09-24-2010 01:32 PM
05 STI, World One Built Motor, Hydra, HTA GT35R - 649 whp on Q16/92 pump mix WorldOne Proven Power Bragging 84 11-13-2009 07:02 PM
Big Blow through maf on 16 bit ecu kahtep Engine Management & Tuning 0 05-31-2007 07:34 PM
