Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-18-2011, 08:27 PM   #1
2011boostdwrx
Member#: 263470
Default 2011 WRX w/FMS FMIC installed!! please read made custome brackets etc! w/ AEM intak
First I will say this is a serious pain in the ass, took over 8-hours to install. Cutting bumper is not easy and we got it perfect after cutting, fitting, cutting fitting, we taped off the area measured, measured, and then cut. Cut is perfect, fitment of the FMIC to the replacement crash beam was way off, we had to elongate all the holes ( alot) to get it cenetered. Pipes are not marked, but after trial error we got it. I was using the AEM intake so I had to custom make two brackets for this kit, one for the OEM overflow coolant bottle relocation to passengers side and the other for the AEM tube vibra-mount. I am going to get a little peice of 2 3/4 tubbing and silicone couplings to make it fit better by moving it deeper into the hole. Now the pics:
Custom Overflow bracket installed:
Custom AEM w/vibra-mount bracket, notice the notch by the filter, wanted to make sure it would not cut through with vibration. Paint was rushed and will be fixed, maybe fabricate a shield.:
The AEM heat shield can not be used at this time, until i mock an extended pipe for the intake, so i used the lining to line the areas where the pipes go through the body! Important because both pipes will rub with the AEM intake! I couldnt wait for the paint to dry so it looks a little molded.
I used vacuum line caps on all the exposed t-bolt clamps as they can take a pretty good chunk out of your hand. I also used the new Tomioka Racing (EDO-Performance) Silicone Throtle Body Hose, this thing is great better than the AVO in my opionion.
As mentioned before the bumper cut is a serious pain, but I think this is the best cut I have seen thus far!
Performance, is hard to say as I have not had it tuned by Akuma yet, probably going this week if I can get the tubing for the intake extended and fixed. The core reminded me very much of the IPR TMIC I had, nothing great, but nothing totally useless. I ran some IAT while driving saturday and they were much lower than my AVO TMIC was, but the build quality on the AVO is night and day!! Would I do it again? Probably not unless I was going with a cosworth or AVO FMIC, if the AVO FMIC fits anything like the AVO TMIC, it would have been done in 1/2 the time.
I will update!
2011boostdwrx is offline   Reply With Quote
Old 04-17-2012, 12:30 AM   #2
scoobiesnacks5566
Member#: 317062
Default LaG?
Hey is there a lot of noticeable turbo lag when you instaled this on stock turbo?
scoobiesnacks5566 is offline   Reply With Quote
Old 08-30-2012, 07:35 PM   #3
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
I know it's an old thread but can you explain your overflow bracket further?
addictionsoLA is offline   Reply With Quote
Old 08-31-2012, 06:54 PM   #4
HAMsubaru
Member#: 326468
2009 subaru
WRX
I'd like to kno as well, installing the same kit in my 09 this weekendish. Waiting on bov gasket.
HAMsubaru is offline   Reply With Quote
Old 08-31-2012, 09:23 PM   #5
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
Well, figured i'd post here.
Firstly I am using the FMS FMIC, I decided to use the coolant bottle that came with the intercooler only to find this yesterday.
The weld on the bracket for the reservoir broke.
So I flipped the hard coolant line and drilled holes where it was mounted so I could ziptie it.
Lastly I used some sheet metal and a dremel to make some brackets, I bolted one using the hole that was for the air duct and the other one comes off of the headlight. Eventually I'll get a tig welder and make it look more professional.
Oh and I changed intakes
Old 09-01-2012, 05:56 PM   #6
Kornfedrex
Member#: 318081
2010 STi
Dark Silver
You bought a FMS kit LOL, that's why it took you eight hours, it's horrible fitment. Junky kit. You get what you pay for.
Kornfedrex is offline   Reply With Quote
Old 09-02-2012, 06:36 PM   #7
2011boostdwrx
Member#: 263470
Really funny you say that i am 373whp on a mustang dyno and this kit cools the charge just fine with no issues. So you go spend your $1000 plus on your Perrin/AMS etc. Yes I made some adjustments and had a few issues but worth it in my opinion, thanks for yours.
Old 09-02-2012, 11:38 PM   #8
Kornfedrex
Member#: 318081
2010 STi
Dark Silver
Sorry, I actually bought a Turbo XS, and no issues with crash beam support when it comes to family money isn't important. Also it took 4 hours with out any directions to install. BOOM FoOL
Old 09-03-2012, 04:05 PM   #9
addictionsoLA
Member#: 301236
2010 Wrx
Grayish!
This is the EXACT same kit as the turboXS.
Old 04-08-2013, 07:29 PM   #10
bbrock171
Member#: 341461
Sorry to dig up an old thread, but I just went through an FMS FMIC install on my '13 STi. Overall the install went great. I wish I had seen this thread prior to doing my own, but overall I think it went pretty smooth. I will say the wrinkle red piping looks a lot better than mine. Also the cut looks cleaner in the corners because I removed the black part across the top to expose more of the core, which also exposed the right angles deep in the bumper, but I don't really mind. I might put the black piece back at some point to see what it looks like.
If anyone is looking to see what this kit looks like on an STi check it out.
bbrock171 is offline   Reply With Quote
FS : Nh: Bnib 08+ Wrx/sti Fms Fmic ryebread929 Engine/Power/Exhaust 18 06-17-2011 10:19 AM
FS: OEM 03 WRX parts from FMIC install (Foglights, TMIC, intake, etc) dlh1999 NWIC Private Classifieds 3 05-29-2009 03:25 AM
HID Installer Please read... Blue_Diamond Electrical & Lighting 17 06-14-2004 11:06 PM
All Greddy FMIC owners, PLEASE READ! STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 10-08-2003 08:45 PM
Those with MRT FMIC installed please look GDA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-01-2002 05:39 PM
