Old 09-18-2011, 11:00 PM   #1
02insecturbo
Member#: 251522
2003 wrx
blue
Default Does a Catless down pipe need a 02 Sensor??
Hi I have a 2003 wrx with a perrin DWG cattless downpipe, Evo 2 catback, K&N typoon. I got it tunned with a Coob Accessport. My question is do i really need a 02 sensor on my DP? If my dp is catless. Will this ruin my car? Thanks
02insecturbo is offline   Reply With Quote
Old 09-19-2011, 12:37 AM   #2
02insecturbo
Member#: 251522
2003 wrx
blue
Bumppppp
Old 09-19-2011, 08:52 AM   #3
rrob311
Member#: 248743
I am not sure if the downstream o2 influences fuel trim at all on these but I have seen it do weird things on yotas. If you had it tuned I would imagine they know a way to eliminate the need for the downstream if the cat is gone. As long as the upstream is doing it's job I would think it would be ok.
rrob311 is offline   Reply With Quote
Old 09-19-2011, 10:25 AM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
wrong section
remove the rear 02 from the ecu and you shall be fine. some argue it affects fuel trims, but it really just checks for voltage change compared to the front 02
eg33GC is offline   Reply With Quote
Old 09-20-2011, 10:08 PM   #5
02insecturbo
Member#: 251522
2003 wrx
blue
Originally Posted by eg33GC View Post
wrong section
Thanks
cobb catless down pipe/ gtspec up pipe 2.5turbo Engine/Power/Exhaust 0 12-13-2007 06:19 PM
cobb catless down pipe , xs-engineering intake, sti injectors, sti up pipe STIFLYBY_RANGER Engine/Power/Exhaust 2 03-02-2007 09:55 AM
Boost Creep Revisited - catted down pipe vs. catless down pipe Dyno Flash Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 01-18-2007 01:33 PM
Perrin Downpipe Fits WRX / STI 02+ Catless Down Pipe chopaholix Private 'For Sale' Classifieds 18 04-14-2005 11:06 PM
Will a uppipe and catless down pipe pass emissions? Camperguy New England Impreza Club Forum -- NESIC 18 03-14-2003 10:57 PM
