Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-19-2011, 08:14 AM   #1
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
Unhappy EJ20K Head gasket probably gone
Looks like one of my head gaskets has gone. Would love to hear it is something cheaper, but not expecting it.
Checked the diagnostics on my JDM Version 4 STI yesterday morning, to make sure nothing was malfunctioning. [Was about to fit K&N intake, and wanted to know everything was working beforehand.] No error codes at all.
Symptoms:
Went for short drive, 8-10 miles.
Arrived home, turned off engine, opened bonnet to look at the intake install. Heard a gurgling sound from the coolant header tank. Removed lid of overflow tank, noticed bubbling gas coming through (the first time I've seen this).
Let car cool a bit. Removed lid of header tank, noticed was no longer full. Added water to fill up.
Restarted car. At idle the level of the header tank quickly dropped to the level it was at before refilling, and after a while bubbling resumed in the overflow tank. The car is decatted (in case it matters). I checked the exhaust gas, it became white, and seemed to have water vapour in it (condensation in pipe).
Have I lost a head gasket? Is there any way of fixing this economically, or is it an engine out only job? I checked the thread about using gasket fixer of some sort in the coolant. Does not seem to be a good idea in the long term
I pushed the car back a few feet this morning, and noticed a couple of dark marks under the car on the passenger side. In the JDM (RHD) car, this is the side with the battery and screen wash reservoir. I know everyone says you have to do both at once anyway.
If I have to pay someone to fix the head gaskets, is it worth me trying to remove the engine myself and bring it to a workshop? In other words, is it harder to get the engine out and then put it back after than it is to change the gaskets, or if I can successfully get the engine out is it a straightforward job to change the gaskets?
I have plenty of time but not much money, as I am unemployed. I don't have an engine hoist, but I might be able to get one. No engine stand either.
Sorry for long post, thanks for any help. Tom
thoughto is offline   Reply With Quote
Old 09-19-2011, 10:07 AM   #2
Poppie
Member#: 262422
1998 V4 Type R
Feather White
You will see bubbles as the turbo coolant goes into the header tank and will boil off due to no pressure in the system (when you have the cap off obviously)
May be worth just checking your header cap is sealing properly as mine went on my 93wrx and I could here gurgling noises thought the worse and it just turned out to be the cap not sealing properly.
Poppie is offline   Reply With Quote
Old 09-19-2011, 04:21 PM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
The headgaskets can be replaced with the engine still in the car. It is an epic PITA but it is not impossible. I had a shop that did my headgasket replacement that way. It was cheaper for me because they didnt have to pull the engine.
Feel free to replace the waterpump, timing belt and pulleys while your at it. You will save a grip of money later by doing it now.
TommyAtomic is offline   Reply With Quote
Old 09-19-2011, 04:32 PM   #4
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
Thanks very much guys. I am still not a hundred percent sure, will investigate further tomorrow, but basically pessimistic. My header cap is unfortunately almost new, and fits great, more's the pity. TommyAtomic, you don't know of a webpage showing how to do the job with the engine in do you? Would be very interested. My searches failed to deliver in that department. Tom
Old 09-19-2011, 07:56 PM   #5
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
another way you can check if your headgasket is going/gone, make sure all the caps and lines and hoses are sealed up and then start the car. squeeze the top hose from the crossover pipe into the radiator, if it feels extra inflated, as if there is lots of pressure inside of it (moreso than usual) then its probably the headgasket, because some of the compression of the engine is pushing into the coolant system
elislider is offline   Reply With Quote
Old 09-20-2011, 02:32 AM   #6
pmugabi
Member#: 280926
My test for a headgasket is to start the car and wait till the fans come on and then turn the engine off. If the top hose is still pressurized 20 minutes after turning the engine off, then it's a headgasket issue.
pmugabi is offline   Reply With Quote
Old 09-20-2011, 05:01 PM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
This should assume that the coolant system has been properly burped. If there is still air in the system the air will still expand when heated by the coolant and easily maintain pressure for 20 minutes unless its quite cool outside.
Ive seen a few complaints of bad clamps or hoses that allowed air in the system after the engine shut down. Then when the engine was restarted the air was heated and expanded.
Old 10-15-2011, 08:23 PM   #8
cmyles
Member#: 275572
2007 Built STi
No smoke at all ? Wheres the coolant going then?
The coolant lines running to the turbo do take in coolant and circulate after shutdown.
Could be an air bubble in the system, try burping it if you havent already.
cmyles is offline   Reply With Quote
Old 10-16-2011, 05:29 AM   #9
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
Thanks very much for all advice. I decided the head gasket had gone, and the mechanic confirmed this at cylinder 1.
What apparently happens is that no coolant is consumed until the car hits boost, so at idle all seems well. On boost pressure rises and gas bubbles out through the leaking gasket and fires coolant out of the overflow bottle. This seemed to be the case with my car.
People attach a plastic tube to the outlet of the overflow bottle and run the tube under the bonnet so it exits under a windscreen wiper blade. Then the overflowing coolant can be seen when going on boost.
In my case the plastic tube did not fit perfectly, and I did not see a projectile flow of coolant, but I could tell that was what was going on.
Hope this helps someone else.
Engine gone back together now with new gaskets, all new bearings and stronger later model rods, so will be much stronger. Cheaper than a rod / rod bearing / crankshaft fail anyway.
Old 10-17-2011, 04:15 PM   #10
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Have the timing belt, pulleys and waterpump replaced with headgasket. Its hardly more work for the mechanic and will save you trouble later.
Old 10-17-2011, 04:41 PM   #11
kheff46
Member#: 66739
2002 WRX wagon
is he doing it in car? if you are doing all those replacement parts, its easier to pull the engine and have all the room in the world to work on it. otherwise your rear main seal is still old and suspect if you're leaving it in the bay. i did a clutch also since its THAT far along anyway! lol. thats the issue with a HG failure, you end up wanting to do everything else just to NOT have to do it again in a couple months.
--keith
kheff46 is offline   Reply With Quote
Old 10-17-2011, 04:48 PM   #12
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
Engine is out. I did nearly all the work to get it out, but my mechanic did a great job bringing a hoist and separating engine from gearbox for me. Nearly everything is getting done, as you both say it makes sense. Luckily my clutch was very good, and even my turbo inlet pipe was fine. Bought a lot of hoses though. Timing belt def changed, pulleys and water pump not sure, but definitely checked.
Old 10-17-2011, 05:42 PM   #13
kheff46
Member#: 66739
2002 WRX wagon
gaskets and seals galore! glad to hear you're doing it yourself and saving $$ where you can. helps pay for other stuff, lol!
--keith
Old 10-23-2011, 10:22 PM   #14
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
Op, did you have any evidence of coolant in the oil, or oil in the coolant?
i may or nay not be having some HG issues
Meat Supply is offline   Reply With Quote
Old 10-24-2011, 03:25 AM   #15
thoughto
Member#: 29145
1998 Version 4 STI
White, gold wheels
MS, no sign of oil in coolant or vice versa. The overflow bottle was the key. Normally never did anything on my car, but there was bubbling there. That was the first thing I spotted.
Also idling the car may not reveal the problem, due to these engines not sucking in coolant so much as blowing gas out through the coolant.
I hope you are lucky! Tom
Old 10-24-2011, 04:18 AM   #16
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
The gaskets always blow from exhaust side into coolant. There alsmost never is oil in the coolant or vice versa unless you would really continue drive it hard with failing gaskets.
Marnix is offline   Reply With Quote
Old 10-25-2011, 11:07 PM   #17
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
hey OP. glad to hear you got it out. do you have it running yet? i'm about to do the same project. i'm pretty good at working on cars, just haven't done anything this big yet.
EJ20K Head Gasket Thickness and Cometic Thickness nicbinc Pre-2002 Factory Turbo Powertrain 3 12-25-2010 04:41 AM
EJ20G v. EJ20K deck height/Head Gasket? d00f Pre-2002 Factory Turbo Powertrain 18 10-18-2010 10:21 PM
Another Head Gasket Gone! kbrate Legacy Forum 28 08-31-2004 12:49 AM
Head gasket gone bad? SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-29-2004 01:58 AM
well i am sure my head gaskets are gone jslegacy Legacy Forum 20 07-15-2003 11:18 PM
