Old 09-20-2011, 02:36 PM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default plumbing for the 20G water box
Yes, yes, I have tried searching with logical terms, but I have not found a comprehensive visual thread on how the stock plastic water box is plumbed.
I figured out the turbo to box, the top inlet towards the turbo.
I figured out the line coming from the water pump, the inlet in the center most section.
I am stuck on the last used inlet, the one that faces towards the radiator and is directly below the nipple for the cap overflow.
Any visuals would be very kind. I got my stuff in pieces, so it isn't that I am a derp
eg33GC is offline   Reply With Quote
Old 09-20-2011, 02:45 PM   #2
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Search AWIC and that may yield more results. Wish I could be more help.
Psychoreo is offline   Reply With Quote
Old 09-20-2011, 02:45 PM   #3
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Are you talking about the small radiator return? You have the two forward facing nipples on the waterbox. The one near the cap goes to the coolant overflow. The one below that is a return line from the radiator.
TommyAtomic is offline   Reply With Quote
Old 09-20-2011, 02:54 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
so if I am using a usdm radiator with a cap, what shall I do with that line, given it has nothing to do now?
I can just plug it with no ill effect, correct?
Old 09-20-2011, 03:23 PM   #5
Psychoreo
Member#: 79643
2015 WRX STI
Ahhh... that water box. Disregard my previous post.
Old 09-20-2011, 04:01 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
appreciate your willingness to help
Old 09-20-2011, 08:08 PM   #7
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Is this is a usdm radiator from an 02 or newer wrx that your trying to make function with a JDM engine and plumbing?
You may want to check the plumbing on a usdm waterbox. It may lack the line that your trying to find a home for. It may work better with the radiator that you are using.
Old 09-20-2011, 11:39 PM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
it is a 95l radiator
how much is too much for the stock gear box? WildBlueWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-11-2008 10:36 PM
plumbing for the boost soleniod? takumi Subaru Conversions 3 01-26-2007 11:30 PM
Who makes a kit for the 20G turbo upgrade? cditch13 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 11-23-2005 03:21 PM
Dear Lord, for the sake of Boxing, let James Toney knockout John Ruiz Snoopy Off-Topic 13 05-01-2005 09:07 PM
Diagram for the 2001 RS intake plumbing bigbird General Forum Archive 1 03-06-2001 12:13 PM
