Old 09-21-2011, 05:37 PM   #1
crimson ghost
Member#: 243867
59 Karmann Ghia EJ
Default Opinions on no IC but water/meth only ?
Mods , please let me know if this would be better suited to the swap, or water/meth forum.
I haven't found quite what I want to know through the search and was hoping you all would chime in.
I have a stock EJ20K with a t3/t4 that will be going in my 1959 VW Karmann Ghia. I don't plan to run huge boost and wondered if I could get away with just water meth and no intercooler ????
Would I need to run E85 plus water/meth for it to be safe ????
What boost would be considered safe with matching injectors ?
The rear of the car doesn't get much air flow and it would help not to cut up the engine compartment of a old rare car.
Thanks for your help !
crimson ghost is offline   Reply With Quote
Old 09-21-2011, 09:36 PM   #2
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
How much boost? Safe? Sure, if properly tuned and prepared. You wouldn't want to run a lot of boost. E85 would certainly make it much safer than pump gas...
thefoos is offline   Reply With Quote
Old 09-22-2011, 12:56 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I wouldn't do it. If you are worried about cutting up the tub, go with an AWIC and find somewhere to put a small radiator out in the air flow away from the engine bay.
Old 09-22-2011, 03:05 PM   #4
pheonix991
Member#: 154173
2006 STI
I'd run a AWIC before I ran meth on that thing.
pheonix991 is offline   Reply With Quote
Old 09-23-2011, 01:20 PM   #5
tablesandchairs
Member#: 294641
I did this, no real power gain so I went back to the stock intercooler and meth.
tablesandchairs is offline   Reply With Quote
Old 09-23-2011, 04:47 PM   #6
kahunaking
Member#: 183497
1998 V4 RHD STi
On my friends old RX7 he did it for fun one time and logged the IAT's and it turned out that he was able to get sub ambient temps but every application is different.
kahunaking is offline   Reply With Quote
Old 09-23-2011, 04:49 PM   #7
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
My old 93 legacy turbo had no intercooler from the factory.
And a puny turbo.
I have nothing to really offer here.
Psychoreo is offline   Reply With Quote
Old 09-24-2011, 12:18 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Maybe. A big turbo running low boost won't need as much charge cooling as a small turbo with high boost. Only way to know for sure is try it and monitor your IAT.
Old 09-26-2011, 08:43 AM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
there are water/meth kits out there and can be configured
to spray low positive manifold pressure (boost).
look for kits that run off of MAP sensor readings
Max boost/power on NO intercooler but E85? reddevil Built Motor Discussion 14 04-09-2010 03:48 PM
Water only or Water/Meth? Krang Water/Methanol Injection, Nitrous & Intercooler Cooling 10 04-10-2009 03:05 PM
STI 12liter Water/Meth/IC tank pszydlik Engine/Power/Exhaust 5 03-23-2007 08:30 PM
Anyone using water or water/meth inj. on V8 JDM ecu?? chudlo Water/Methanol Injection, Nitrous & Intercooler Cooling 6 05-31-2006 03:02 AM
Water/Meth/Alc Injection Good Mod for STi with Turboback/EM Only? klattery Water/Methanol Injection, Nitrous & Intercooler Cooling 66 04-20-2006 04:30 PM
