Old 09-21-2011, 07:35 PM   #1
CAPTAIN1N5ANO
Member#: 252297
2002 WRX STI
MIDNIGHT BLACK PEARL
Default Tgv codes deleted still cel
So I had my Tgv's deleted and I am trying to get rid of the cel. I have the access tuner race and I unchecked all the tgv codes and uploaded the map into car. I still have cel but when I check for codes it says there are none????? Please help. Thanks.
CAPTAIN1N5ANO is offline   Reply With Quote
Old 09-22-2011, 10:02 AM   #2
Cobb Tuning
Member#: 4803
Make sure you follow these steps when disabling TGV DTCs:
1. Open your map in the AccessTUNER software and in the menu bar, go to Edit -> Advanced Parameters.
2. Under the "DTCs (Base)" tab, UNCHECK any of the following codes that are listed for your car regardless of what codes you are reading with the AP (Note: you will not have every code listed here - they can be specific by model/year):
P1086, P1087, P1088, P1089, P1090, P1091, P1092, P1093, P1094, P1095, P1096, P1097, P2004, P2005, P2006, P2007, P2008, P2009, P2011, P2012, P2016, P2017, P2021, P2022
3. If the AP is showing any additional codes active for TGVs other than those above, disable those as well.
4. For 2.0L cars, under the "Toggles (Base)" tab in Advanced Parameters, UNCHECK the three selections related to TGVs (ex. "TGV P1086/P1087/P1088/P1089 Fault Detection"). If you instead see "TGV Sensor High" and "TGV Sensor Low", you have an old version of the software. Update to the latest by submitting a request for it here:
http://accessecu.com/register/cobb.php
5. Save your map and upload the new map to your AP with AP Manager software.
6. REFLASH your new map with the AP (Disabling DTCs is NOT a real-time tuneable function and must be re-flashed).
Bill
Old 09-23-2011, 08:30 AM   #3
CAPTAIN1N5ANO
Member#: 252297
2002 WRX STI
Thanks alot Bill, It worked great, No cel
Old 02-01-2012, 12:24 AM   #4
djr408
Member#: 308311
Default codes p1091, p1089, p1088
will this help delete all of the cels if you use an accessport ??
djr408 is offline   Reply With Quote
Old 02-01-2012, 11:26 AM   #5
Cobb Tuning
Member#: 4803
If you have an AccessPORT version 2 (i.e. the current device with color screen) and the AccessTUNER Race software (free download with purchase of v2 AP), then you will be able to defeat any DTC (generally only legal for off-road applications).
Old 02-12-2012, 10:10 PM   #6
m1nus
Member#: 296328
04 Wrx wagon
do you also need a tune with the TGV delete? or can you just turn of the cel. mine is rusted open and i have a line on some deleted ones but i don't have the cash for a tune with it.
m1nus is offline   Reply With Quote
Old 12-11-2012, 11:09 PM   #7
IVGottaBDreamin
Member#: 203833
2004 JBP WRX
I did all of that to the T and I still get a CEL with no codes found and limp mode. Can you take your sensors out? I left my sensors out and gave them to a friend. Is that why? I don't understand why it keeps coming back
IVGottaBDreamin is offline   Reply With Quote
Old 12-12-2012, 10:56 AM   #8
Cobb Tuning
Member#: 4803
If this is an 04 WRX (as it shows in your sig), you can uncheck the three TGV fault detection toggles that are found under Edit -> Advanced Parameters -> Toggles (Base) menu. These are different than the listing of individual DTCs in the other tab. You'll want to uncheck those three, save the map (with a unique name) and then reflash that map. It has to be a reflash (not a realtime flash). A reflash requires that you connect the green test mode connectors (and initialization block) like you did when you first installed the AccessPORT (for older cars).
Bill
Old 12-12-2012, 09:22 PM   #9
IVGottaBDreamin
Member#: 203833
2004 JBP WRX
Ok I'm trying it now. But why would that work when I had those three unchecked and also the individual dcts unchecked as well?
Old 12-12-2012, 09:35 PM   #10
IVGottaBDreamin
Member#: 203833
2004 JBP WRX
Yes it still has check engine light and limp mode. I have only the three unchecked under toggles and I did a permanent flash and it still comes on as soon as the car warms up. And yea it's 04 wrx. So it IS ok to run the sensors UNPLUGGED? Or is that my problem?
Old 12-13-2012, 11:18 AM   #11
Cobb Tuning
Member#: 4803
You should be fine if the fault detection toggles are unchecked. Let's do the following:
1. Connect AP to car and run the memory snapshot feature found under the troubleshooting menu.
2. Run the AP Manager software and connect AP to computer. Transfer the memory snapshot file from the AP to your computer (same as you would do a log).
3. At cobbforums.com, start a thread (register if you need to) and click on "Go Advanced" and "Manage Attachments" and attach the memory snapshot and the current map that you have reflashed to the car. Write something in the thread to remind me that it is you.
The memory snapshot will allow me to determine what is causing your check engine light so hopefully we can get this solved.
Bill
Old 12-13-2012, 10:03 PM   #12
IVGottaBDreamin
Member#: 203833
2004 JBP WRX
Bill
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Old 12-14-2012, 09:51 AM   #13
Cobb Tuning
Member#: 4803
Posting Permissions
PM sent.
Bill
Old 10-21-2014, 03:13 PM   #14
izeahhh40
Member#: 404159
2002 Subaru WRX
red
Did you ever get an answer cause im in the same situation?
izeahhh40 is offline   Reply With Quote
Old 10-23-2014, 05:01 PM   #15
md2regul8
Member#: 371029
2011 STI Hatch Black
Rotated GTX3076
What year, and model and what code are you getting
md2regul8 is offline   Reply With Quote
Old 05-31-2015, 10:18 PM   #16
Titter
Member#: 416107
2002 WRX Wagon 4EAT
V8 EJ 207 Spec C
subbed
Titter is offline   Reply With Quote
TGV code cel fix KZYKIRBY Newbies & FAQs 6 05-12-2011 07:23 AM
04 STi - TGV cel code delete help Mactizen Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-09-2009 11:41 AM
TGV Delete Sensor CEL Question TheBlackRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 05-19-2007 09:19 PM
TGV deletes without cel can utec do that?? wrxdragger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 05-14-2007 03:23 PM
Crawford TGV Deletes, UTEC, CEL nitsuj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 07-03-2006 03:31 PM
