Old 09-22-2011, 10:34 AM   #1
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Default Best way to prep wheels prior to having them professionally painted?
I am a DIY and perfectionist and feel I will do a much better job at prepping my wheels than any bodyshop or the like. I will have them professionally painted but the prep would like to do myself.
The wheels are 2004 BBS STi wheels that I bought online with rock chips and blemishes. I will have them painted satin Black (a la Advan RS-D).
Questions about painting:
1) Do I have to have the entire wheel painted or just the visible surface?
2) If just the visible surface, where the parting line should lie between new and old paint.
About Prepping:
1) What is a better removal process, bead blasting or paint stripping or both?
2) What media for bead blasting?
3) Will blasting remove Aluminum material like the tiny casted raised lettering on the wheels: BBS, 17x7.5, 53 offset
4) What paint stripper? Aircraft stripper?
Looking forward for feedback, I want perfect refinished wheels.
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 09-22-2011, 02:32 PM   #2
sb04wrx
Member#: 204541
2006 STI
World Rally Boo
In all honestly, if you are paying a company to paint your wheels then let them do their job. I can understand being a perfectionist, because I am one myself, but if anything happens to the wheels during the process, they could potentionally use that against you.
Prepping wheels before paint is part of the painting process, and a very important one. I can just see something going wrong and them blaming the customer (you) because the prep process wasn't done their way.
Unless you have experience doing this, let them handle everything. It's your money, make them earn it. Just some food for thought.
sb04wrx is offline   Reply With Quote
Old 09-22-2011, 02:57 PM   #3
AspenScoob255
Member#: 217405
2006 WRX
First off, if you don't trust the shop to prep properly then why are you going there in the first place?
The only benefit I see to doing some of their work for them is to reduce labor hour charges. I say let them do their job.
If you do want to do something, remove the old paint and clean them thoroughly. Aircraft stripper works very well for this process followed by a dawn bath.
And yes have the entire wheel painted inside and out. No sense in running the risk of flaking when the tire contacts the wheel and or when they mount your tires.
AspenScoob255 is offline   Reply With Quote
Old 09-23-2011, 11:44 AM   #4
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
bump, looking for tips on how to remove original factory paint from wheels.
Old 09-23-2011, 01:48 PM   #5
MattTHEpainter
Member#: 284046
2000 Impreza w/ WRX
Get aircraft stripper and apply copious amounts to the wheel. Place in industrial trash bag and seal. Let sit for 30 minutes. Scrape off any loose paint. Repeat until no factory paint remains. If some stubborn paint does not lift, use 400 grit to sand.
MattTHEpainter is offline   Reply With Quote
Old 09-23-2011, 03:57 PM   #6
vms150
Member#: 172917
2004 WRX
I would say to strip them yourself with aircraft remover and a power washer (it's very helpful when using aircraft remover) and then get them POWERCOATED instead of painted because if you're paying professionals to paint them you are better off getting a product that will last longer and stand up to the abuse.... paint is not that product.
vms150 is offline   Reply With Quote
Old 09-23-2011, 05:43 PM   #7
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Not sure if urban legend but powercoating makes aluminum more brittle, no?
Old 10-03-2011, 12:09 PM   #8
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
If you are a perfectionist why are you even asking this? Have the inner wheel painted as well.
I've painted a number of sets of wheels and never stripped the old paint. Scuff it up, smooth the edges of any nicks and off you go.
Snowphun is offline   Reply With Quote
best way for an '11 sti to get 300whp ? krypton Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 46 05-11-2011 09:58 PM
Looking for shop to insepct vehicle prior to purchase OFake Vancouver Impreza Club Forum -- VIC 1 06-05-2010 11:26 PM
Best ways in learning on how to work on subaru's (or cars in general) sizzflair Newbies & FAQs 33 02-04-2010 10:22 PM
anyone have experience to send wheels/tires to US? etam Canada Region Forum 5 09-30-2004 02:52 PM
Best way to transport wheels/tools to/from track cdraayer Motorsports 15 02-17-2004 01:08 PM
