#1 |
Member#: 291786
Vehicle:2011 Impreza WRX Satin White Pearl |
Hi guys, so i plan on doing my first detailing of my WRX (ill take some pics)....just got it last week. I was just curious in how you guys cleaned that scotchguard material on the door. Can I use paint sealant or wax? Also what about the headlights, can paint sealer or wax be used on the lights. Thanks for those that answer.
#2 | |
Member#: 217405
Vehicle:2006 WRX |
#3 | |
Member#: 25187
Vehicle:'08 Foz Prem TGM '10 Challenger R/T Blk |
The following contains a collection of links to articles, videos, etc. on the subject of detailing that you may find useful:
http://forums.nasioc.com/forums/show....php?t=1877117 Quote:
Opti-Seal is probably one of my most used sealants for trim if the surface is in good condition. ....I sometimes even apply via airbrush. For some oxidized finishes I will use an AIO like Klasse or ZAIO (although the latter can be a little aggressive on some finishes). I also had really good success with Fuzion for this purpose but never bought another jar after my sample ran out. Anyhow, I've been using G/Techniq C4 on the trim of my Challenger since April. So far, I haven't had to re-address those areas (it's been holding up great). ....the same wasn't true on the Forester since I did have some performance issues in a couple of areas (trim was older and I'm still not ruling out prep as the cause). My next product to try will be Valugard ETR. I'm actually really interested after talking to the man that helped develop it. C4 is good but it's really not a restorative product IMO. ....in my case, I would only consider it for trim in new or like-new condition at this point. I just recently (couple of months ago) applied Opti-Coat to most of the Forester including most of the trim. So far, I like the result. |
#4 |
Member#: 217405
Vehicle:2006 WRX |
Interesting, I will have to give some of those products a try as I really like sealing everything (so much easier to clean that way). I have actually been eyeing that valugard system for a few months now just haven't had the need for it yet. Actually, I read your review of the G4 product it look really good post application.
So you actually airbrush opti-seal on? Interesting...I am sure that cuts application time down tremendously. I suppose I am still in the "wax stains trim" mindset...need to get out of the box. ![]() |
#5 | |
Member#: 25187
There are a lot of non-staining wax/sealants out there but there are also some surfaces/situations that are simply not optimal for these types of product. ….especially when you’re talking about old, faded, oxidized finishes. Unless restored prior to application, I have never had as good of a result with a sealant as I would have with a “restorative” protectant/dressing. I mentioned this before, but I really liked Wolfgang Fuzion for this. It is a WOWO (wipe on, wipe off) paste that doesn’t need to be left on after application (you immediately wipe it off). It goes on buttery smooth and comes off just as easy without streaking. It also doesn’t stain trim or leave a white residue in crevices. It worked well even on some textures I was unsure of. The downside is the cost (but that’s not to say there are not others that perform similarly for less). ….and then there are the newer nano/semi-perm/permanent coating like the C4, ETR and Opti-Coat I mentioned. Those are definitely products I can see using more often going forward (at least in my case). |
| Thread Tools | |
| Display Modes | |
| Michigan Scoob Noob with CV troubles | szkud | Mid West Subaru Owners Club Forum -- MWSOC | 4 | 05-08-2007 08:13 AM |
| Heat Idle Issues, Help This Scoob Noob | Tripinray | Factory 2.0L Turbo Powertrain | 1 | 03-09-2007 09:14 PM |
| Scoob Noob needs pre-purchase advice | Till | Newbies & FAQs | 3 | 03-09-2006 03:50 AM |
| Scoob Noob need help | Norcalrallyist | Newbies & FAQs | 9 | 03-05-2006 03:10 AM |
| ('93-'01) Help a Scoob Noob.. er.. Noob for that matter | iemonslice | Impreza Forum | 1 | 08-02-2001 12:10 PM |
