Old 08-02-2002, 10:09 PM   #1
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Default SS braided power steering lines
Iím trying to find out what parts/fittings I need to replace my power steering lines w/ stainless ones. Do I have to by a pre-maid power steering line to handle the pressure or can I use AN fittings and line.
What do I need and where do I get it???
Thanks,
Jared.
PunKidd is offline   Reply With Quote
Old 08-03-2002, 08:38 AM   #2
Ethan
Member#: 246
Well on my '99 the hoses are built into these solid lines. I don't think you can use AN fittings. BUT what I did was I took it to a shop that custom makes SS lines and stuff, gave them my old lines and they attached those solid lines to the SS. COnsufing?
Ethan is offline   Reply With Quote
Old 08-03-2002, 02:18 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I believe you can replace them with AN fitting lines and whatnot, but they have to be able to handle a decent amount of pressure, otherwise it'll make a damn big mess when the power steering is pressurized.
JC Sports (don't groan... they had some good products, just horrid service) made stainless power steering lines for those that actually got their kits on the GB they did a year and a half ago because the lines were heavily in the way.
Old 08-03-2002, 02:30 PM   #4
PunKidd
Member#: 8533
2002 2.5 RS-T
Anyone know if typical AN fittings and hose can handel power steering pressure?
Old 08-03-2002, 07:37 PM   #5
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default JC Sports lines
I have some of these JC Sports lines that came with my kit and they are pretty skettchy. I don't think they would even work. I am installing my kit on a differant car though and I am going to give them a shot this time for a cleaner install than on my last car. I have a feeling that the threads on the line won't be correct for bolting to the steering rack, will find out soon. But on the top end for the pump I will have to get creative for how they connect.
Joshua
yebokmj is online now   Reply With Quote
Old 08-04-2002, 01:06 AM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I don't see why stainless a/n lines would'nt take the pressure, The material is pretty much the same as a brake line, and stock ones are rubber.
Tim Sanderson is offline   Reply With Quote
Old 08-04-2002, 01:48 AM   #7
PunKidd
Member#: 8533
2002 2.5 RS-T
I was just woried about the hose slipping off of the fittings under high pressure.
Old 08-04-2002, 02:14 AM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You said a/n right? those are npt on one side & a pressure fitting on the other. The powersteering only has major pressure on the pump outlet side, The other side is pressurized but clamps should be fine.
Old 08-04-2002, 02:58 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default Re: JC Sports lines
Joshua
I knew a guy with one of those kits and those lines, he ran them for a good 9 months without problems. Then he sold the kit to another friend of mine who installed them and has had them on for another good 6 months without problems. *shrug*
Old 08-04-2002, 04:14 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
power steering pressure prolly don't climb much over 200 psi in the pressure hose anyhow.
jeremy
Old 08-04-2002, 08:22 AM   #11
yebokmj
Member#: 2213
Brilliant Red
Default Any Ideas
Do you remember how he connected them at the pump? With my set one has threaded fittings on both ends and the other has threaded fittings on only one and then just a clamp on the other end. I looks to me like you would have to cut the rubber hose off of the hard metal part and then clamp the lines on? This would mean removing the threaded fitting off of one end of one of them.
Joshua
Old 08-04-2002, 01:21 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Default Re: Any Ideas
Joshua
all the fittings cam with the lines, one of them actually replaces the stock pressure line fitting into the pump.
jeremy
P and L motorports SS braided power steering line - BRAND NEW WrXtaCy2003 Engine/Power/Exhaust 12 12-21-2009 11:49 AM
WTB. Vendors Braided power steering lines 03 WRX ljaviation Private 'Wanted' Classifieds 2 08-24-2009 01:57 PM
Stainless braided power steering line help skate enjoi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 09-25-2008 08:40 AM
Braided Power Steering Lines dunk Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-17-2005 10:11 PM
