Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 09-24-2011, 10:50 AM   #1
EJ20(GDB)
Member#: 85507
1995 WRX STI
Default Should i put HKS BOV on 20g?
Stock ECU and stock intake should I change it to HKS BOV .. or do I need tuning?
EJ20(GDB) is offline   Reply With Quote
Old 09-24-2011, 11:15 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
It will release unmetered air to the atmosphere, so it'll run a little rich on shifts, not the end of the world, there's no way to tune for it, short of running a standalone with speed density. Why do you want it? For the sound?
Old 09-30-2011, 01:54 AM   #3
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Run it if you like it... It wont hurt anything at all. Been running open bov for years with same motor. Should perform well since the hks design will absolutely stay closed under boost.
blkgm8 is offline   Reply With Quote
Old 09-30-2011, 02:02 AM   #4
07wrx84
Member#: 252195
07 WFC #900
@ 451awhp-404awtq
R I C E... Lol jk bro
07wrx84 is offline   Reply With Quote
Old 09-30-2011, 03:09 PM   #5
EJ20(GDB)
Member#: 85507
1995 WRX STI
Thx for the answer I'm also thinking put Hks intake back since the original owner had it installed
Old 09-30-2011, 04:31 PM   #6
Jarrod164
Member#: 253937
1995 WRX
I kind of want a blow off valve but got scared of all the talk around here about "don't do it" etc etc. But as I hear my friends' turbo cars and then my lame turbo chug sound... makes me want to change it up a little. I heard 50/50 recirc valves kind of are the best of both worlds. They don't make noise under daily driving but only under higher rpm/boost, not sure if that's accurate though?
Jarrod164 is offline   Reply With Quote
Old 10-01-2011, 01:15 AM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Do it. **** yeah.
i_c_the_light is offline   Reply With Quote
Old 10-11-2011, 02:12 PM   #8
Subbiespeed
Member#: 276493
2005 STI
i have a hks ssqv but i also have power fc
Subbiespeed is offline   Reply With Quote
Old 10-11-2011, 09:02 PM   #9
Turbocrazy1
Member#: 297489
it wont throw a cel? i know evos have huge problems with this... subarus have blow through mafs or something?
Turbocrazy1 is offline   Reply With Quote
Old 10-11-2011, 11:32 PM   #10
Strider327
Member#: 131280
2004 Impreza WRX
No its not worth it unless you have a blow through pipe or running some kind of standalone, which I doubt you have. Your car will run like crap.
Strider327 is offline   Reply With Quote
Old 10-12-2011, 06:43 AM   #11
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Dear sir. Take your misinformation back to the General forum. You obviously have no clue about the subject.
Old 10-12-2011, 11:39 AM   #12
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Been running a blitz bov since i got my jdm ej20g wrx. The previous owner had it fabbed up to an sti intercooler. I dont have so much of a choice in the matter without spending some money. Personally I would have prefered a 50/50 recirc. But i honestly dont think it matters. Jdm ecu's are pretty slick about adjusting to the briefly freak a/f. Unless your a jackass your not going to blow anything up. And if you do blow something up it wont be because of a bov. I tell people who ask about it that atmos venting bov's are as much an engine performance upgrade as a high output stereo amp.
Does not make you go faster. They can be adjusted for epic rice venting if thats your thing but its completely pointless.
TommyAtomic is offline   Reply With Quote
Old 10-12-2011, 01:35 PM   #13
luka
Member#: 194742
1993 Impreza WRX JDM
that's not _entirely_ true. the higher end BOV's hold more boost and don't leak under low pressure so there is _some_ performance enhancements above & beyond the stock, leaky BPV.
but yeah, with a topmount you're not venting all that much metered air. I've been running vented for years with no issues.
if you had a front mount however I'd maybe think twice about going full vented simply because of the volume of metered air you'd be dumping, probably doesn't matter either but I don't have any experience with a FMIC + venting (will soon though )
luka is offline   Reply With Quote
Old 10-12-2011, 02:53 PM   #14
Subbiespeed
Member#: 276493
2005 STI
not sure if this helps but i have a ej20g in my 2000 rs and i have a front mount, mbc, downpipe and catback, power fc, afpr, deaustchwerks fuel pump and the hks and i have no issues as all including leaking and im running 15 psi which should be the lowest possible and im not happy with this but i don't have a tune at all just put the ecu in the car and ive never had any issues at all(also have the coilpack conversion)
Old 10-14-2011, 03:45 AM   #15
lollipoptian
Member#: 297815
lollipoptian is offline   Reply With Quote
Old 10-17-2011, 12:46 AM   #16
ltizzy
Member#: 241783
1995 Impreza Outback
ej20g
Putting a HKS on mine was great for drivability. Stopped the lurching and surging when shifting. Stock ECU had no issues ('93 U8 ECU).
ltizzy is offline   Reply With Quote
Old 10-24-2011, 01:59 AM   #17
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
LOL... Where did you read that? As said earlier... And backed by others like myself who actually have ej20g with BOV's in our cars... You CAN pretty much run whatever blow off valve you want and the car will still run fine.
Can I put a HKS BOV on a stock Leggy Gt??? VeryImprezive Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 11-06-2008 05:55 PM
Should I put my house on the market on labor day weekend or the weekend after? WRXVT Off-Topic 21 11-20-2006 08:28 PM
should i put sedan fenders on my wagon? romoranger Tri-State Area Forum 3 04-19-2003 01:35 PM
Should I put STi7 wheels on a WRX wagon (WRB)? Frederf Interior & Exterior Modification 9 10-18-2002 03:17 PM
Where should I put a sticker on my trunk? kevinsUBARU Interior & Exterior Modification 10 02-21-2001 06:04 PM
