#1 |
Member#: 153578
Vehicle:03 WRC WideBody 04 Forester XT |
Hey guys I picked up a 97 impreza with an EJ22e (sohc), and have an EJ25d (dohc) from a 97 legacy. I would like to put the EJ25d in it and would like to get some information about a few things.
1. can I use the 97 EH22e harness and ECU? 2. If yes to 1 is there any sensor changes or splicing that needs done? 3. If the Harness will work could I just swap the ECU? This will be a complete engine swap not just heads. I do have the opportunity to get the ECU and harness from the legacy but if its not necessary I would like to know up front before I waist the time and money. Thanks Again for any help or info
#2 |
Member#: 159682
NESIC
Vehicle:1995 WRX |
Wrong section.
But the wiring just plugs in and it will run on the existing ecu ok. You need to get the dual port header from the legacy. |
#3 |
Member#: 153578
So it is. Sorry about that. Moderators please move.
I have a turbo manifold, UP, and DP from my Forester XT that I plan on using. I'm sure it will run better with the correct ECU can I plug the Legacy ECU into my harness? |
#4 |
Member#: 206851
Vehicle:99 V4 EJ20K RS |
the 25d will run fine on the 22e ecu
#5 | |
Member#: 153412
Vehicle:1998 Impreza wrxRS Black |
#6 |
Member#: 153578
I have all the stock parts from a 35R set up I did on my other impreza and the up, dp, turbo and ic from things I have upgraded on the Forester XT. I plan on modifying the stock 97 cross member to make room for the up pipe.
#7 |
Member#: 267429
Vehicle:96 Legacy Wagon |
#8 | |
Member#: 153412
#9 | |
Member#: 46248
RMIC
Vehicle:2012 outback 2.5 sky blue |
Yes, the engine is a direct swap. You need to change nothing except the header. I have done it several times. |
#10 |
Member#: 153578
This I know. I guess its a good thing I have a newer phase 2 sti crank, sti rods and pistons sitting around.($50 invested BTW) Before you get all worked up about the crank my father in law has a machine shop. So machining a number 5 thrust will cost me a big fat 0! So all said and done including machine work I will have about $350 in this complete engine. This is for a rally cross car I'm looking to spend as little as I can and have as much fun as possible. So far including cost of the car, the ej25d, full 5 speed swap and a RS hood I have about $1500 invested plus crap I had sitting around collecting dust.
#11 |
Member#: 153578
Here is a guy that did a somewhat similar build. Now I'm not looking to run 20+ psi more like 7ish, but interesting none the less.
http://www.rs25.com/forums/f7/t39629-boosted-ej25d.html |
| Thread Tools | |
| Display Modes | |
| ej18 to ej25d ECU question | g-rider | Subaru Conversions | 6 | 03-20-2011 10:01 PM |
| Going from a 99 EJ22 to a 97 EJ22 | BlueLegacy | Legacy Forum | 3 | 01-11-2010 01:21 PM |
| EJ22E SB + EJ25D Head + JDM WRX ECU? | napphappy | Subaru Conversions | 12 | 12-14-2009 09:52 PM |
| Ej22 to Ej25D conversion | scoobydude4321 | Subaru Conversions | 3 | 05-07-2009 07:34 PM |
| 200k 93 EJ22 to 88k 94 EJ22? | gto7419 | Subaru Conversions | 4 | 12-13-2006 04:14 PM |
