Old 09-24-2011, 06:35 PM   #1
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
Default Footwell Illumination install 2011 WRX
Hey Forum,
Today I did a quick mod to the interior of my new WRX limited.
If you are interested in more write-ups, mods and installs, check out my build thread here!
The footwell illumination kit was inexpensive and easy to install. It gives a nice glow and matches the stock console tray perfectly.
I bought it from Subaru Parts Mall found here. It was $37.23
I give it a 2 out of 10 for install difficulty. and it took about 20 minutes to install not counting taking pictures.
Here's the install
I started by removing the radio trim. you can easily remove it by hand starting on the lower sides and work you way around to the top.
I removed the center heating ducts. it makes the install a lot easier and give you access to every thing you need. To remove, unscrew the 2 Phillips screws on the side and push the side ducts out of the way and lightly pull out.
These are the parts that come with the kit.
I also removed the center console cover to reveal the stock light. Please see my kartboy install for directions on how to remove the console.
Once the console is removed, push the stock light with your thumb from inside the dash below where the duct was.
Then run the harness as follows: The two male and female connectors that are close to one another go into the hole where the light was. The longest wire on the harness gets threaded to the passenger footwell and the slightly shorter wire goes to the drivers side footwell. I did the best I could to explain this in the busy picture below.
Install the passenger side light using the supplied screw, nut, and washers. There is a hole drilled already under the glove box that the bolt went into. It's a Phillips screw and a 3/16" nut.
The drivers side is similar to the passenger. There is a hole but it's horizontal instead of vertical. Use the screw, nut, and washers that are supplied to mount.
Zip-tie the harness out of the way and install the stock light back into its original location. Once you put the console, duct, and radio trim back on, turn on the lights and enjoy the cool red (or blue) glow!
Use the center console light as a gauge to how bright these are. In this picture I used a long shutter speed to show the lights but they are not this bright in person.
Thanks for reading!!
Overland04 is offline   Reply With Quote
Old 09-24-2011, 07:51 PM   #2
brandlee
Member#: 254676
2011 WRX Limited
Satin White Pearl
Nice write-up!! And very high quality pictures.
I installed it too, but I didn't remove anything though. It was a pain but patience works out just fine.
brandlee is offline   Reply With Quote
Old 09-24-2011, 08:07 PM   #3
NJJer
Member#: 288369
2011 STI Limited
My car came with them stock (STI Limited) and they only work when I open the doors. The console one works with the headlights, but not the footwell ones. That is how it is supposed to work I am told.
I wonder how yours work with the headlights, as I would like to change mine around that way.
NJJer is offline   Reply With Quote
Old 09-25-2011, 08:14 AM   #4
Overland04
Member#: 293311
2013 FXT 6-Speed
This kit works with the headlights and the dashboard dimmer.
I've heard the the STI has it wired to the door switch. I would assume that a simple re-wire could fix that if desired.
Worst case, you could purchase this kit for $37 and do a re-install. I like this kit just because its all red, I've seen a lot that have the contrasting blue.
Thanks for reading!
Old 09-25-2011, 08:31 AM   #5
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
Great write up with some great pictures..I was considering purchasing these but was nervous about the install.
daigledangle8 is offline   Reply With Quote
Old 09-25-2011, 11:29 AM   #6
D-rock240
Member#: 284221
2011 WRX GV SSM
2001 Legacy BH 5MT DD
Nice pics and writeup.
D-rock240 is offline   Reply With Quote
Old 09-25-2011, 01:28 PM   #7
phelan
Member#: 282913
2011 WRX Hatch
Thanks for reading!
I wonder if it's a PITA to wire it to the door switch? I rather like the idea of having it linked to only when the door opens and closes.
phelan is offline   Reply With Quote
Old 09-25-2011, 08:27 PM   #8
Overland04
Member#: 293311
2013 FXT 6-Speed
I haven't done one on this car before but it's really easy. Instead of using the power form the console light, you can grab a positive power source under the drives dash and the negative trigger from the door switch in the drivers kick panel. If you use a diode to isolate the light from the rest of the car, you'll be all set.
P.M. me if you decide to do it, I'll guide you through.
Cheers!
Old 09-25-2011, 08:52 PM   #9
fl4tpower
Member#: 282664
2011 STi ltd Stage 2
There are 2 different light set ups. There are what Subaru calls "courtesy" lights which light up red or blue when doors open and will shut off about 3-4 seconds after doors close. Then there are the footwell illumination kits that DO NOT come stock on any model. They are Subaru aftermarket kits that can be installed by them and those simply wire up to the headlight switch.
And for all who are thinking about re-wiring the the footwell illumination kit to work with just door operation be careful. Those switches are not a regular +/- power setup. They run off of constant + and ground out to operate when doors open. They run off of a relay as well and resistor to give you those 3-4 seconds of light after doors close. I had 2 friends try this on there 11' hatches and BOTH of them grounded out their entire interior fuse panel and caused crazy interior illumination issues. Word to the wise is all!!
fl4tpower is offline   Reply With Quote
Old 09-25-2011, 09:40 PM   #10
theSTIgdrivesanSTI
Member#: 294359
1993 MX5 Miata
Red, BCs, Hard top, C1Ms
Awesome! and I'm loving the high quality photos.
theSTIgdrivesanSTI is offline   Reply With Quote
Old 10-10-2011, 05:00 PM   #11
STINY11
Member#: 285661
2011 STI
Dark Grey Metallic
Do you know of anyone with an STi that has rewired theirs to work like the footwell illumination kit is supposed to, or is that also a bad idea? I would like to do that, and if anyone wants to take a crack at it and post a DIY that would be awesome...I have almost no electrical know-how, so I definitely shouldn't be the guy to try it.
STINY11 is offline   Reply With Quote
Old 10-10-2011, 05:34 PM   #12
fl4tpower
Member#: 282664
By no means am I a professional electrician but I have some experience with car harnesses and I think turning the stock courtesy lights to work with your lights is very easy. You would lose the "door open" function but whatever suites the driver. Simply just cut the harness close to the light and connect the car side of the harness together to complete the circuit and keep the harness from grounding out. Then wire the light... One wire to ground and the other to an illumination source. ie clock, cluster, fuse box, etc. Once again be careful as to that switch wires to the fuse box and you don't want to mess with that.
Old 10-10-2011, 09:12 PM   #13
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
If you want to change it up, but you don't have much wiring expertise, just buy the Subaru kit.
Then you can just run the harness to the existing lights, and done, leave the stock plugs for the lights unhooked and keep the spare footwell lights from the kit. You could also install both, I have read about someone with an STI doing that, one side has a hole usable for a second footwell lamp, the other side he drilled a hole, the attachment method is very simple.
Power6 is offline   Reply With Quote
Old 10-10-2011, 09:14 PM   #14
STINY11
Member#: 285661
2011 STI
Dark Grey Metallic
That's a thought...I actually might do that. Then I get the joy of having them turn on when I unlock the car/open the door, and also have the other lights turn on when the lights are on...GENIUS! Plus it's pretty cheap.
Do you happen to know who it was that did that in their STi? I would love to PM them about it.
Old 10-10-2011, 10:03 PM   #15
fl4tpower
Member#: 282664
I did it. The door lights work when you get in and then the footwell kit lights come on when my lights go on. Overall an extremely easy process. Helped a guy do it the same way as me at a local Subie meet. Took about 20 min.
Old 10-11-2011, 02:06 PM   #16
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
Great writeup. Knowing to remove the radio and stuff really helped. I did this at twilight and ALMOST dropped a screw into the ventilation ducts. Glad I didn't, but people should be careful of that or it will be a major headache to get that screw back.
Jonnyfilmboy is offline   Reply With Quote
Old 10-11-2011, 11:49 PM   #17
yanj88
Member#: 290520
2011 wrx 5 door
wrb
awesome write up going to order it now but going to try my local dealer to save on shipping
yanj88 is offline   Reply With Quote
Old 11-11-2011, 08:10 PM   #18
WRX_fever
Member#: 296630
2011 WRX
Dark gray metallic
Great write up on this! Purchased and installed today in about 25 minutes without removing anything. Dealer quoted 2hr install and I looked at them like they were crazy!
WRX_fever is offline   Reply With Quote
Old 12-27-2011, 04:30 PM   #19
Enviedsvt
Member#: 192044
2013 STI
hey overland, I know you have helped me out quite a bit with my questions i've had and always contribute to this forum so i thought i would do alittle bit of researching and put forth my savings to some of the new combers that want to try out this mod!
Through subaru parts mall the part comes out to be $52.85 shipped for me.
There is actually a dealer in colorado that sells most oem subaru products for 25% off msrp. Heuberger Subaru is a great site to purchase oem parts from! Heuberger is selling the footwell kit shipped for $45.91 to my door! I will be purchasing my V limited sti lip from t his site as well as its only 300 shipped!
http://parts.subaru.com/?siteid=215892
Enviedsvt is offline   Reply With Quote
Old 12-27-2011, 11:15 PM   #20
Overland04
Member#: 293311
2013 FXT 6-Speed
I just spent some time on there site, what a great find, thanks!!
Old 12-29-2011, 09:32 PM   #21
chavisan
Member#: 300506
2011 Impreza WRX
WR Blue
I got these lights for my car and will install them as soon as they arrive using your guide. Thanks !
chavisan is offline   Reply With Quote
Old 12-29-2011, 10:50 PM   #22
Overland04
Member#: 293311
2013 FXT 6-Speed
That's great, good luck man!!
If you run into any questions let me know!
Old 12-30-2011, 07:17 PM   #23
chavisan
Member#: 300506
2011 Impreza WRX
WR Blue
Done...it was pretty easy. Thanks.
Old 01-01-2012, 05:45 PM   #24
STINY11
Member#: 285661
2011 STI
Dark Grey Metallic
I used your instructions for the install with a 2011 STi and it worked great. Although, for an STi, I don't know how necessary the removal of the center console was (i just ran all the wires behind the HVAC controls up above the stock light)...but either way, the instructions were very good.
I didn't need to drill any holes by using the adhesive that came with the package to just mount the courtesy lights on top of the Kit Light mount where it's peeking over the edge of the Kit Lights.
I put a little more instruction for any STi owners that wanted to try it out.
See post #10: http://forums.nasioc.com/forums/show....php?t=2253407
Here's a pic of what it looks like with both installed under the driver side.
Old 01-07-2012, 12:38 PM   #25
TheSage
Member#: 293504
2011 WRX
Ive got a 2011 rex. Just finished mine. Nice clean, easy install. Didn't remove the center console. Was able to get the stock light to pop out by reaching down through the vent space and pushing it through from the bottom. Thank you very much for the write up. Saved me a lot of time and headache. Also installed the SPT heat shield. Easy installs thanks to people who do it and post on here :-)
TheSage is offline   Reply With Quote
How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI? GodWhomIsMike Interior & Exterior Modification 228 10-16-2015 06:21 AM
Stance Coilover Install 2011 WRX 5dr. Overland04 Brakes, Steering & Suspension 82 10-27-2014 10:17 PM
Satelite Radio install 2011 WRX Overland04 Car Audio, Video & Security 22 12-05-2012 11:15 AM
Blue Footwell Illumination Kit in a 2011 WRX? GodWhomIsMike Interior & Exterior Modification 42 10-01-2011 11:28 AM
2011 WRX Interior Illumination Installed Bruins1982 Interior & Exterior Modification 19 12-31-2010 03:34 AM
