Old 10-26-2012, 07:41 PM   #76
shamrocker
Member#: 258219
2011 WRX Limited
WR Blue Pearl
I just installed my red footwell kit. I was surprised at how easy it was. Besides removing the glovebox and popping out the cubby hole light, I didn't have to remove any trim or anything. I just pushed the entire wire harness from the driver side through the cubby hole light opening, connected it, then pulled the passenger side hardness into the glovebox area. 20 minute install, tops. Plenty of wire length, too.
Removing the glovebox was the hardest part, so I replaced the cabin filter while I had it out.
shamrocker is offline   Reply With Quote
Old 10-27-2012, 09:56 PM   #77
xDRAN0x
Member#: 163085
2009 3.0R Legacy
'15 FXT
Wow really wish I saw this... just did the same install on my WRX, except I didn't remove teh console and took an hour to run the wires behind the console.
In the end, I am disappointed with the amount of light it produces, totally looks weak when compared to your picture. I should try take one and compare.
xDRAN0x is offline   Reply With Quote
Old 10-27-2012, 09:59 PM   #78
Overland04
Member#: 293311
2013 FXT 6-Speed
Obsidian Black Pearl
That sucks man, are your sure they're turned all the way up? Mine are usually too bright and I turn the a couple clicks down.
Overland04 is offline   Reply With Quote
Old 10-28-2012, 01:30 AM   #79
httpNick
Member#: 334503
2004 WRX
Rally Blue
So sick!!! Want for my 2004
httpNick is offline   Reply With Quote
Old 10-28-2012, 01:43 AM   #80
SparkSilver10NM
Member#: 302438
10 WRX
SS DMrally tuned!
So I just checked your build thread out and DAMN! your ride is wicked dude! much props! I'[m gonna look into the stance setup now cause you say they ride decently well on the softest setting and you can swap the stock units in quick if something goes wrong. Once again, well done sir!
SparkSilver10NM is offline   Reply With Quote
Old 10-29-2012, 02:45 PM   #81
aaronn
Member#: 275418
2010 WRX Hatch
Default footwell w/bluetooth?
Sorry to hijack the thread (freaking sweet pictures btw ),
but does anyone know ANYTHING about the blueconnect bluetooth for the 2010 WRX? Mine was installed when I purchased it, and for the life of me I can not find any information on it anywhere. I've searched online and can only find install instructions for the Forester and other nonsense. It blocks the cubby and therefore installation of my footwell illumination kit.
I've even called Subaru and gone in and they are no help. They just want to overcharge me to get it installed.
Help??
aaronn is offline   Reply With Quote
Old 10-30-2012, 12:38 AM   #82
PhillyWReX10
Member#: 253625
2010 WRX
Dark Grey Metallic
Thanks for the post and writeup- I just ordered the blue kit to go in my 2010 WRX to match the blue center light. I'll install in a couple weeks when I put in my kartboy shorty and do a double whammy!
PhillyWReX10 is offline   Reply With Quote
Old 10-30-2012, 10:33 AM   #83
xDRAN0x
Member#: 163085
2009 3.0R Legacy
'15 FXT
You can turn them up? what? how?
Old 10-30-2012, 10:38 AM   #84
Overland04
Member#: 293311
2013 FXT 6-Speed
Oh, mine work off my dimmer for the dashlights. I just adjust the dimmer by the power mirror/headlight dip switch.
Old 10-30-2012, 10:47 AM   #85
xDRAN0x
Member#: 163085
2009 3.0R Legacy
'15 FXT
Same wiring as OEM product? I might try this then.
Old 10-30-2012, 10:52 AM   #86
Overland04
Member#: 293311
2013 FXT 6-Speed
Yeah, no special wiring. I just plugged it into the OEM console plug that is controlled by the OEM dimmer. I wonder if there are differences between mine and your kit.
Old 10-30-2012, 12:39 PM   #87
xDRAN0x
Member#: 163085
2009 3.0R Legacy
'15 FXT
ah ha it does the trick indeed, way brighter the reason I didn't notice its because my lights are usually very dimmed because I got lasik eye surgery 2 years ago and my eyes are still pretty weak/sensible at night - so I dimm everything to its lowest
thanks Overland!
Old 10-30-2012, 12:40 PM   #88
Overland04
Member#: 293311
2013 FXT 6-Speed
Glad it worked out, cheers!!
- Jason
Old 10-31-2012, 01:53 PM   #89
PacoBJuarez
Member#: 259127
2011 Impreza WRX
Quick question: I have the OEM footwell lights for my '11 WRX, but I got the blue lights (sigh) because either I didn't speak clearly enough or the guy handling the order for my car is deaf. Either way, I've been too lazy to deal with it until now. Does anyone know where I could get the red lights to swap them, how much they are, and how long that would take? Thanks!
PacoBJuarez is offline   Reply With Quote
Old 10-31-2012, 11:08 PM   #90
jdreisinger
Member#: 127138
2015 Nissan GT-R
2000 2.5RS Sedan
So I found this thread and ordered these things. I just went to go to the store, and I don't have any lights in my footwell currently... Is this normal? I was expecting they would be replacing white lights or something? Or am I just an idiot?
jdreisinger is offline   Reply With Quote
Old 10-31-2012, 11:16 PM   #91
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
the only light you have is the red light in the cubby in front of the shifter
BigRob74 is offline   Reply With Quote
Old 10-31-2012, 11:32 PM   #92
jdreisinger
Member#: 127138
2015 Nissan GT-R
2000 2.5RS Sedan
And so this kit taps into the existing harness for that light, then?
Old 10-31-2012, 11:40 PM   #93
shamrocker
Member#: 258219
2011 WRX Limited
WR Blue Pearl
Correct
Old 11-01-2012, 06:55 PM   #94
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
added to my list of things to do! very nice job. does it still light up when you shut all the doors?
JAMM0N is online now   Reply With Quote
Old 11-01-2012, 07:20 PM   #95
Overland04
Member#: 293311
2013 FXT 6-Speed
Yupp, they are on the same time as the center console light which is anytime the parking lights are on.
Old 03-03-2013, 12:31 AM   #96
matsayz
Member#: 316693
2012 WRX
So does this thing work on a 2012 WRX or not? A guy above posted yes for a '13 so wtf?
matsayz is offline   Reply With Quote
Old 03-03-2013, 09:06 AM   #97
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
Yes... 11-13 WRX are the same...
Navendra94 is offline   Reply With Quote
Old 03-07-2013, 04:28 PM   #98
sti_will037
Member#: 293878
2012 WRX sedan
SWP Top Speed Tuned
Thanks for the great write up just got finished installing this and the kartboy short shifter using both of your write ups
sti_will037 is offline   Reply With Quote
Old 03-07-2013, 04:29 PM   #99
Overland04
Member#: 293311
2013 FXT 6-Speed
Glad they both worked for you, cheers!!
- Jason
Old 03-11-2013, 10:23 AM   #100
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Originally Posted by Blackmamba24kb View Post
does anyone know if these footwell lights will work and fit on a 2012 impreza 2.0i premium (non-STI/WRX)???
Red: http://www.subarugenuineparts.com/pr...oducts_id=2055
Blue: http://www.subarugenuineparts.com/pr...oducts_id=2054
MackDaddy is offline   Reply With Quote
How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI? GodWhomIsMike Interior & Exterior Modification 228 10-16-2015 06:21 AM
Stance Coilover Install 2011 WRX 5dr. Overland04 Brakes, Steering & Suspension 82 10-27-2014 10:17 PM
Satelite Radio install 2011 WRX Overland04 Car Audio, Video & Security 22 12-05-2012 11:15 AM
Blue Footwell Illumination Kit in a 2011 WRX? GodWhomIsMike Interior & Exterior Modification 42 10-01-2011 11:28 AM
2011 WRX Interior Illumination Installed Bruins1982 Interior & Exterior Modification 19 12-31-2010 03:34 AM
