Old 03-11-2013, 10:52 AM   #101
BSP671
Member#: 288190
2009 Impreza 2.5i
Spark Silver
Just wondering if anyone had done this. I was thinking if some way you could tap into the connection and hook up some LED's into the rear passenger footwells. I feel it would be incomplete if just the front footwells were illuminated.
BSP671 is offline   Reply With Quote
Old 03-11-2013, 03:49 PM   #102
motown
Member#: 308483
2013 WRX SWP HATCH
RIP 2011 WRX-SANDY VICTIM
Anything is possible w/ time and patience. While you have the dash apart make it happen. 95% of the time however its just me and 1 other person. Use the led strips from an auto parts store and hide them well.
motown is offline   Reply With Quote
Old 03-12-2013, 08:54 AM   #103
black_subie730
Member#: 193074
2002 WRX SW
did something like this on my 06 foz before i even saw this thread.. i wired 4 leds with 3 bulbs on my front foot wells then put the other 2 under the front seats..but ended up burning the FET on the BIU the way i wired it was using the key ring light mod..so ended up doing the BIU fix after..but mine lights up when u open the door or unlock the car and dims when i turn the car on..works great!
black_subie730 is offline   Reply With Quote
Old 03-13-2013, 04:59 PM   #104
wirthless
Member#: 151783
2013 WRX 5dr
DGM 5dr
just got my red kit in the mail, cant wait to install them
wirthless is offline   Reply With Quote
Old 04-03-2013, 04:10 AM   #105
c3ywut
Member#: 226603
2009 WRX Premium
Satin White Pearl
install complete. thank you good sir for sharing!
c3ywut is offline   Reply With Quote
Old 04-09-2013, 12:56 PM   #106
spiderman.666
Member#: 325009
Very nicely done
spiderman.666 is offline   Reply With Quote
Old 09-28-2013, 04:41 PM   #107
CrusherPrime
Member#: 231664
2013 WRX STI
I did this install this weekend, took about 15 minutes. A few notes:
The 2013 STI is advertised at coming with foot well illumination, but it actually comes with courtesy lights – they don’t stay on when the car is running. The Imprezza has weird, dark foot wells. This foot kits adds subtle light into the cab.
…Don’t tear your dash apart. You don’t even have to have patience for this install. A wire hangar is all you may need.
This is the plate that holds the cubby light in place, you remove it, unplug the cubby light (remove the corny difuse cover so you can actually see something in your cubby – that’s what that little red thingy is on my traction control knob)
Don’t even worry about being neat, it’s out of sight, behind the dash.
The female end doesn’t come out too far and I wouldn’t yank on it too hard.
Shove the kit up there and start threading it through. Open the glove box and thread the passenger side, taking care to open and close, making sure that the door doesn’t pinch the wiring.
The courtesy lights and the kit mount to different holes, so I didn’t bother taking a pic. On the driver side, you may need the wire hangar to help thread the cabling through the dash. Pop out the courtesy light, you’ll need that hole to mount the cable. I used the supplied 3M tape to re-secure the courtesy light anywhere along the dash. This isn’t a great pic but you get the idea
Hook everything back up and you are done.
CrusherPrime is offline   Reply With Quote
Old 09-28-2013, 06:02 PM   #108
spiderman.666
Member#: 325009
Cheapest place to get this kit in red for wrx hatchback?
Old 09-28-2013, 06:16 PM   #109
corvid
Member#: 300097
$37 at subaru genuine parts is the best Ive seen
corvid is offline   Reply With Quote
Old 09-28-2013, 06:38 PM   #110
kabz
Member#: 351744
2016 STI
CWP
I installed the Subaru kit, but they utterly suck (far too dark), so I disconnected and removed the light fittings in each footwell, cut them off the connector and soldered in one of these on each side, and reconnected:
Available: http://www.vleds.com/featured/univer...twell-kit.html
All you need is the Subaru kit connector, so just order the 2 leds for about 8 bucks. These are pretty bright, but work with the dimming, so they are good at night, and also noticeable anytime it's not really daylight. They have strong double-sided tape on the flip, so they are easy to install. Just get them in the right place first time.
Highly recommended, and I really dig the red footwell illumination. 90% of the time, the Subaru kit is completely unnoticeable. This is a pretty good way to fix that.
kabz is offline   Reply With Quote
Old 09-28-2013, 10:05 PM   #111
willowlee
Member#: 358533
2013 sti sedan
wrb
The 2013 STI is advertised at coming with foot well illumination, but it actually comes with courtesy lights Ė they donít stay on when the car is running. The Imprezza has weird, dark foot wells. This foot kits adds subtle light into the cab.
ÖDonít tear your dash apart. You donít even have to have patience for this install. A wire hangar is all you may need.
This is the plate that holds the cubby light in place, you remove it, unplug the cubby light (remove the corny difuse cover so you can actually see something in your cubby Ė thatís what that little red thingy is on my traction control knob)
Donít even worry about being neat, itís out of sight, behind the dash.
The female end doesnít come out too far and I wouldnít yank on it too hard.
Shove the kit up there and start threading it through. Open the glove box and thread the passenger side, taking care to open and close, making sure that the door doesnít pinch the wiring.
The courtesy lights and the kit mount to different holes, so I didnít bother taking a pic. On the driver side, you may need the wire hangar to help thread the cabling through the dash. Pop out the courtesy light, youíll need that hole to mount the cable. I used the supplied 3M tape to re-secure the courtesy light anywhere along the dash. This isnít a great pic but you get the idea
Is there a difference between the courtesy light and this kit? I just noticed too that my car has the illumination light. I'm thinking about buying the kit, but if my car already comes with it, I don't want to waste money buying it again.
willowlee is offline   Reply With Quote
Old 09-28-2013, 10:27 PM   #112
Dale2011WRX
Member#: 304299
2011 WRX, white
2014 Crosstrek, tangerine
Seriously? The answer to your question is in the post you quoted.
Dale2011WRX is offline   Reply With Quote
Old 09-29-2013, 12:55 AM   #113
CallMeSavage
Member#: 368258
2002 WRX Wagon
World Rally Blue
Default Nice!
Dude this is awesome. I love all your write ups they are absolutely beautiful..looking forward to doing some of my own!
CallMeSavage is offline   Reply With Quote
Old 09-29-2013, 02:49 AM   #114
willowlee
Member#: 358533
2013 sti sedan
wrb
Yes seriously. I thought there might be a different kit.
Old 09-29-2013, 10:52 AM   #115
CrusherPrime
Member#: 231664
2013 WRX STI
Nope, it's the same footwell kit you install on the WRX / Forrester - there's blue or red - there's no "STI" version..
Old 09-29-2013, 02:46 PM   #116
SnowKing
Member#: 282260
2002 WRX Sedan
So anyway I could get some Red LED illumination in my Bugeye sedan? would really love to do this along with changing the lights in my dash to be red
SnowKing is offline   Reply With Quote
Old 09-29-2013, 03:35 PM   #117
willowlee
Member#: 358533
2013 sti sedan
wrb
I thought there was because my does not shine as bright as the ones pictured on this thread. Maybe its just how the camera is. Thanks for the clear up.
Old 09-29-2013, 10:53 PM   #118
Strmtpr
Member#: 362350
2013 WRX Limited
Nice pics and writeup man! I think I'm going to look into some of these for myself!
Strmtpr is offline   Reply With Quote
Old 09-30-2013, 11:54 AM   #119
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
Can anyone tell me the name/size of these connectors? Or if these are standard parts, or Subaru only? These would be the connector to the cubby hole light/glove box light.
I'm thinking of installing aftermarket LED's, and would like to wire them in the same way. It would be nice to just be able to plug them in, if possible, rather than tapping into the existing wire.
foghelmut is offline   Reply With Quote
Old 09-30-2013, 02:05 PM   #120
WhatsASubie
Member#: 362544
2013 Wrx
satin white pearl
anyone have the blue lights?
WhatsASubie is offline   Reply With Quote
Old 01-03-2014, 03:57 PM   #121
BMAN130
Member#: 345020
2014 STI
i might be slightly retarded, but can someone point me in the direction of having the factory STI "courtesy lights" and turning them into footwell lights that come on when the headlights r on?
everyones buying kits and what not.. I'm assuming if the lights/wiring is already there, should be fairly simple
BMAN130 is offline   Reply With Quote
Old 01-03-2014, 04:27 PM   #122
gemiller
Member#: 361516
2013 WRX Premium
Pearl White
BMAN, I don't really know what your asking? That's what the kit this thread was discussing does. It taps into the headlight/dimming circuit without t-taps and allows the headlights to turn the LED's on and the gauge dimming switch controls their brightness in tandem with the gauges. If you're asking where the wires are the simplest thing for you to do would be download the manual for the light kit. It's on the subaru website for the part number somewhere.
gemiller is offline   Reply With Quote
Old 01-03-2014, 06:53 PM   #123
dezs3028
Member#: 152500
2007 WRX STi
Has anyone tried to install the OEM kit into an 07 STi? My guess is that there will be some wire cutting and such involved. Does the kit work on a switched 12v?
dezs3028 is offline   Reply With Quote
Old 01-03-2014, 08:08 PM   #124
blkstar15
Member#: 363892
2013 WRX Hatch Prem
+1 on this question
blkstar15 is offline   Reply With Quote
Old 01-03-2014, 08:13 PM   #125
blkstar15
Member#: 363892
2013 WRX Hatch Prem
any picture show the birghtness of these LED's? I would like to have them brighter than the subaru kit, but nothing ridiculous...
How do you install the Footwell Illumination Kit (H201SSC000) in the '09 FXT/WRX/STI? GodWhomIsMike Interior & Exterior Modification 228 10-16-2015 06:21 AM
Stance Coilover Install 2011 WRX 5dr. Overland04 Brakes, Steering & Suspension 82 10-27-2014 10:17 PM
Satelite Radio install 2011 WRX Overland04 Car Audio, Video & Security 22 12-05-2012 11:15 AM
Blue Footwell Illumination Kit in a 2011 WRX? GodWhomIsMike Interior & Exterior Modification 42 10-01-2011 11:28 AM
2011 WRX Interior Illumination Installed Bruins1982 Interior & Exterior Modification 19 12-31-2010 03:34 AM
