Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 11-16-2012, 04:47 PM   #1
subaru5614
Member#: 159072
Default 86 4wd Gl Hatch Brake issue
Ok...About to give up on the old girl but trying here before I throw in the towel.
I have a brake locking up issue. After about 5 minutes of driving the brakes will gradually start to apply. Within 2 miles they are braking so much I cannot maintain speed. When I stop all four corners have heat from the brakes being on. The pedal is VERY firm when they are locked because obviously they are applied and have nowhere to go to compress more. Cable for the hill holder has been disconnected to rule that out. It was connected before but it should only apply two brakes right?...and all 4 get hot.
I put a master cylinder on it last year because of a soft pedal. It helped. I ordered a new master and tore it all apart to put in and Autozone has the wrong Fenco brand master on file so I got the wrong part.
Now....should I order a master and a booster? If its not those two things...what could it be. Best place to order parts? I want to do Autozone because of lifetime warranty and I can just go to the corner to get my cores refunded but I can't find the right part number. I have an M52316 and that's not it.
Suggestions and any help. This is my daily driver (by choice not necessity) and I really want it back up for ski season. It makes me sick to see her sit! I just put new exhaust on before the brakes and I want to enjoy it!
Help please!?
Rob
Maple Valley, WA
subaru5614 is offline   Reply With Quote
Old 11-17-2012, 02:42 PM   #2
TurboneX
Member#: 21676
RX 02Foz,05OB
I would go with Rockauto.com. I have yet to get a wrong part from them and if you do, they will get you the correct one right away.
This is a issue I've never heard of. Make sure the hill holder lever isnt moving by itself somehow, maybe wire it up so it doesnt move. Is it leaking brake fluid?
Why did you disconnect it?
TurboneX is offline   Reply With Quote
Old 11-19-2012, 02:40 PM   #3
subaru5614
Member#: 159072
I didn't see any fluid leaks but there is evidence of leakage at some point below the pushrod that comes out of the booster into the master cylinder. The paint is bubbled away but who knows how longs that's been like that!?
It was doing the brake locky uppy thingy before I disconnected the hill holder. I disconnected it just to rule it out. If I can get it to not lock anymore I would reconnect it but I just wanted one less thing to blame for the issues.
Old 11-24-2012, 12:26 PM   #4
TurboneX
Member#: 21676
RX 02Foz,05OB
When it locks up does the brake pedal feel like its sticking?
Old 11-27-2012, 02:09 PM   #5
subaru5614
Member#: 159072
ehhh....not really....the pedal becomes hard.
Normal braking it gradually engages and the brakes apply harder obviously.
When the brakes are locking the pedal skips the initial braking feel....when it hits the already engaged brakes it feels very firm. It makes sense because something is clearly not disengaging. The locking gets progressive worse until the car is not drivable. letting it sit for a moderate timeframe will allow them to disengage and youre good for another couple miles.
Its a pain in my rear i know that.
Old 11-28-2012, 11:33 AM   #6
TurboneX
Member#: 21676
RX 02Foz,05OB
Try disconnecting the brake cables at the calipers. You need to move the lever to slip off the end, kind of a pita to do. This will rule out any issues with that part. I cant see how there can be hyd pressure applied without you using the brakes, so I'm assuming mechanical.
Old 11-28-2012, 11:54 AM   #7
subaru5614
Member#: 159072
I hadnt thought about the ebrake.....thats just the front wheels on this car correct? Can't look right now as I am at work.
Old 11-29-2012, 11:41 AM   #8
TurboneX
Member#: 21676
RX 02Foz,05OB
Yeah, its just for the front wheels.
