Old 08-03-2002, 04:34 PM   #1
adamsrs
Member#: 3768
Arrow Link ECU and Emissions??
I am thinking about getting a LINK ECU.....but i think that Washington state is starting to test emissions via OBD2....will me car still pass emissions if i get a plug and play LINK? Please any info will be a HUGE help!
adamsrs
adamsrs is offline   Reply With Quote
Old 08-03-2002, 04:38 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
The car will not pass the OBD2 test.
Impreza Rider is offline   Reply With Quote
Old 08-03-2002, 04:42 PM   #3
adamsrs
Member#: 3768
So then i wont be street legal any more?
adamsrs
Old 08-03-2002, 04:50 PM   #4
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
You can look at it that way...
But, you could also say that suspension mods make the car not street legal also. The car wasn't sold with that stuff.
Old 08-03-2002, 05:08 PM   #5
adamsrs
Member#: 3768
Regardless i wont pass emeisions and i wont be able to get new tabs then rihgt?
adamsrs
Old 08-03-2002, 05:53 PM   #6
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
adamsrs
Right
Old 08-03-2002, 09:33 PM   #7
christoph1371
Member#: 1090
you won't pass because they won't be able to scan your link ecu. swapping out ecu's link vs stock takes like 10 min. So don't worry about it passing, just swap it out before you go.
christoph1371 is offline   Reply With Quote
Old 08-03-2002, 10:04 PM   #8
adamsrs
Member#: 3768
Really? I can do that?
adamsrs
Old 08-03-2002, 11:36 PM   #9
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I've been trying to get around that too, with no real luck. I think the best bet would be to have some sort of "ghost file" of the obd2 settings available from that port. They don't jack into it while the car is running, at least here, so they aren't datalogging what your computer is doing. Does anyone know if SEMA is working on something in regards to this? (Shiv...anybody?) If there was some standard to judge these systems by, it makes sense that laws would be workable. You'd think they'd get wise and start thiinking of state licensing for these systems, and offer tuning at emissions repair shops. The only thing not making them street legal is lawyers, paperwork, and cops enforcing the laws. You can run one Cat with good tuning and still beat requirements for LEV vehicles. The computers just don't speaky OBD's engr-ish! If someone knew more about obd standards, they could build and program what they needed into the system. (Drunken post whoring rules! ) Mel
HamFist is offline   Reply With Quote
Old 08-04-2002, 12:44 PM   #10
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
I think the problem wiht aftermarket ecu's is the fact that the end user can change the settings. You can go and pass emissions and then go home and crank everything up so that you make more power.
adamsrs: You can get the adapter harness and simply unplug the Link 2 and plug in the stock ecu and go pass emissions. It takes maybe 20min to swap em out. If you dont get the harness you can do like I did and wire in the Link harness with the stock harness so you can still go back to stock if you want.
-Chav
Chav is offline   Reply With Quote
Old 08-04-2002, 07:05 PM   #11
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
The problem that I see is getting to the test site. You can't realy run the stock ECU if you are bootsing to get to the shop.
PunKidd is offline   Reply With Quote
Old 08-04-2002, 07:25 PM   #12
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
So don't go into boost
Old 08-04-2002, 07:33 PM   #13
adamsrs
Member#: 3768
Good idea!
adamsrs
Old 08-04-2002, 09:08 PM   #14
PunKidd
Member#: 8533
2002 2.5 RS-T
I guess you could just swap it out around the corner from the site and then just creep over carfully.
Old 08-04-2002, 09:35 PM   #15
N/A
Member#: 133
TBA TBA
TBA
Man another good reason I like the upstate NY no emissions test.
N/A is offline   Reply With Quote
Old 08-04-2002, 09:50 PM   #16
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
adam, get a cheap apt up in Bellingham you don't need emissions there.
david2z4 is offline   Reply With Quote
Old 08-04-2002, 10:36 PM   #17
Ethan
Member#: 246
Someone else, last week posted that they couldn't pass emissions so they had to buy $400 worth of emission parts and then the state would just pass them.
Or you can just get a PO box in a county that doesn't require emissions then register the car there (but I don't know how that would fly with the higher ups )
Ethan is offline   Reply With Quote
Old 08-04-2002, 10:55 PM   #18
david2z4
Member#: 1838
2000 Impreza RS BRP
Vishnu Turbo/Tec3
Damn Ethan, what is this "vibe" I am getting from you, every were I go you follow me around posting.
your on "my" list now
Old 08-04-2002, 10:56 PM   #19
PunKidd
Member#: 8533
2002 2.5 RS-T
I tried the PO box thing when I lived in Reno way back, but they required a resadentail address. They were just like "so you live in your PO box?" Didn't quite fly
Link ECU and LM1 Users dunk Engine Management & Tuning 0 10-11-2004 04:42 PM
Is there still and issue when using a LINK ECU and a Walbro fp ? EJ20K Engine Management & Tuning 5 12-22-2003 02:13 PM
Link ECU and CEL? Drac9 Engine Management & Tuning 7 11-28-2002 01:22 AM
Link ECU and STI injectors LAWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-22-2002 03:24 AM
Link ECU and Temperature changes annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-12-2001 03:50 PM
