#1 |
Member#: 65296
Vehicle:1998 low turbo SF red / black |
Ej20g from 95 wrx ra, in 98 forester
Fuel pressure is right. Injectors ohm out and were cleaned and flow Tested. sparks plugs are new. Sparks on all four coils. No cracked Coils. Coolant temp sensor new and reading proper ohms at ecu. Maf clean. Timing and compression proper Might try to start if sitting for a while and dried out. Then floods out Help
#2 |
Member#: 65296
And I figured I burnt out the injector drivers in my z5 ecu, scored a supposedly good
used z4... alas still too much fuel/not enough spark. Melted a couple main relays years back before i found the o2 wires fried together on the uppipe. That was when this whole setup was in a 95 coupe Can a spark be too weak? |
#3 |
Member#: 65296
Suspecting a weak spark, I ohmed the ignitor. Odd that I read continuity
Only from #2 of the 4 pin side, to each of the pins of the 5 pin side. Each time it read 130k. I should mention that I believe this starting problem began some time ago in the coupe and became much worse to the point of not starting entirely Blah ![]() |
#4 |
Member#: 280926
Yes a spark can be too weak, however in the case I remember, the spark was weak because of old plugs, new plugs sorted it out.
Are the coils in the proper order? |
#5 |
Member#: 65296
hadn't thought of that. checked and they match up though.
Thanks for responding with an idea. I bet it's something silly. or maybe that pesky ignitor? |
#6 |
Member#: 112759
Vehicle:02 Srp STi...Yup! R ur Boltz to long???? |
^ I just dealt w/ a failed igniter, flooded cylinders & no start
#7 |
Member#: 65296
Well I have spark on all 4 coils, but I wonder if it's strong enough. I suppose the best info to have would be to measure the resistances across the circuits of a known good ignitor to compare to my numbers.
#8 |
Member#: 65296
1) just found a crack in the flat spot on the MAP
Would this cause rich/no start? 2) does ignitor ground itself through bracket to strut tower? Possible weak spark if poor ground due to loose bracket? 3) should my test mode connnectors be joined? Last edited by AsphaltsCry; 10-10-2011 at 11:06 AM. |
#9 |
Member#: 253937
W. Canada
Vehicle:1995 WRX White |
I don't know anything about the ignitor but when you say there is no continuity between wires on both sides, that somewhat sounds odd to me.
According to Rob's conversion wiring diagram, it looks like a straight connection. Unless the ignitor is an on/off switch then perhaps that is normal. Maybe someone can chime in on how it works? |
#10 |
Member#: 65296
So i'm testing my thought to be perfect coil packs. No cracks, no melty spots.
Subaru says 0.7 ohms between the two pins of the pigtail for the primary circuit. And that's good on all four. However for the secondary circuit, they want 13.8 kOhms between pin one and the contact portion where the spark plug goes. This is where I am getting no continuity. Again this is my finding for all four coils. As previously mentioned I am getting spark on all four and they arc quite a distance. Any thoughts community? |
#11 |
Member#: 225974
E. Canada
Vehicle:2012 Impreza WRX Plasma Blue Pearl |
depending on your ohm meter, some type don't go over a certain ohm value
do you have a multimeter that reads into the 20k ohm range? I remember a problem at work were the fluke hand probe didn't read above 2.5k ohm.. |
#12 |
Member#: 65296
My fluke 87 reads into Mohms. And I verified my readings with the nicer fluke at the dealer. Think i'm going to do the coil conversion.
Suspicious readings at the ignitor and bad readings on the coils. Maybe there is a break in the secondary windings that a spark is still able to jump, albeit weakly I can hear the eyes rolling to the ceiling, when I call a junkyard asking about wrx parts |
#13 |
Member#: 142447
South East
Vehicle:2002 WRX Banged Up Blue |
#14 |
Member#: 65296
Sorry that was a newb typo. I meant MAP sensor had a small crack, I hot glued it. I swapped MAFs already, but i'll try it unplugged
#15 |
Member#: 225974
E. Canada
the coil conversion is pretty easy to do.
now the car runs real good I would recommend it indeed. |
#16 |
Member#: 65296
Yup it was those ****ing g coils.
| Thread Tools | |
| Display Modes | |
| No Crank no start mmkay? | Trogasarus | Electrical & Lighting | 3 | 11-19-2009 11:45 PM |
| Crank/no start - no spark - ideas? | PeteDucati | Built Motor Discussion | 12 | 04-29-2007 04:29 PM |
| Crank.. no start.. severe flooding??? | PeteDucati | Factory 2.0L Turbo Powertrain | 7 | 02-10-2006 11:43 PM |
| Stock STi: crank, no start, flashing CEL. | cnstman | Factory 2.5L Turbo Powertrain | 2 | 03-28-2004 11:18 PM |
| XT6 (92), Does anyone have a illustration of the timing belt(s) Crank No Start. | munkis | Normally Aspirated Powertrain | 0 | 10-20-2002 11:25 PM |
