#51 | |
Member#: 154281
W. Canada
Vehicle:2002 V7 EJ207 Dom1.5 MBP |
Anyone have an MBP JDM STI grill they want to sell me? ![]()
#52 |
Member#: 154281
W. Canada
Picked these parts up today....
Blouch Dom 1.5XTR ![]() Untitled by zcherniawsky, on Flickr Garret Core ![]() Untitled by zcherniawsky, on Flickr 71mm XT compressor wheel ![]() Untitled by zcherniawsky, on Flickr 56.5mm turbine wheel and internally gated ![]() Untitled by zcherniawsky, on Flickr Its ported... that was a nice surprise ![]() Untitled by zcherniawsky, on Flickr Also in my order were Top Feed O Ring Kit ![]() Untitled by zcherniawsky, on Flickr Samco Afta Maf Hose ![]() Untitled by zcherniawsky, on Flickr I expect to be installing all this, headers and DW750's on Sunday. |
#53 |
Member#: 283189
I'm from Quebec, I know how you feel about winter. God it's horrible. But our subies wouldn't be love as much if we didn't plow through those snow banks and ice with them.
#54 |
Member#: 154281
W. Canada
Couple of pics from the progress of today's turbo swap and header/uppipe install
![]() Untitled by zcherniawsky, on Flickr and ![]() Untitled by zcherniawsky, on Flickr Yes, im aware the DP isn't torqued down properly. I just have to button a few things up, buy a couple bolts im missing and im good to go get tuned ![]() |
#55 |
Member#: 154281
W. Canada
Car is misfiring (no CEL) and has a low idle when warm (~700rpm). Going to go see my tuner today to see if he can figure out whats wrong. Im thinking one of the DW750 injectors I installed is faulty.
In other news, I got this last night. ![]() Carlabs X-Brace by zcherniawsky, on Flickr I need to track down the two bolts that attach the X to the strut tower braces and then it'll get installed. I've got the 12L Spec C tank in the trunk but I ordered a set of spacers from Oswald Performance so I can run both. Apparently the install is a PITA.... yay. :sarcasm: |
#56 |
Member#: 298020
SCIC
Vehicle:2002 RS-TI Whitey |
man....that sucks about the misfire :/...always harder too when no codes pop up...... on a brighter side, i LOVE that cross bar!!
#57 |
Member#: 154281
W. Canada
Ugh. I know. Tell me about it. I've been driving it with some injector cleaner in it... but still the same issue.
#58 |
Member#: 299687
RMIC
Vehicle:06 Impreza Wrx Track car in the making. |
Nice job.
#59 |
Member#: 154281
W. Canada
My tuner, Airboy, was concerned because everywhere in the engine bay that I measured, the voltage was steady, however the ECU was seeing varying voltage. He pulled the ECU out and started testing wires. Sure enough, all the ECU grounds had an extremely high resistance (4+ohms). Something was wrong with the grounds. I called Brian at iWire who did my wiring merge and he said that all the ECU grounds terminate at the Intake Manifold.
Fast forward a few minutes to this bolt: ![]() Bolt by zcherniawsky, on Flickr Somewhere along the line, this bolt was undone and not tightened back up which meant that the ECU wasn't grounded properly. Sunny cleaned up the grounds and the grounding point and tightened the bolt. Started the car... ECU is seeing steady voltage. Better than that, the Idle was normal. Better than that, no misfires when we revved the motor up. Huzzuh! The car is now ready to be tuned whenever Airboy has an opening. We did a couple of pulls, turbo should make full boost by around 4200rpm-ish (yay Altitude!). Once you get up there, it feels pretty damn powerful... but thats compared to me limping the car around with misfires and an unhappy ECU. Huge thanks to Airboy... amazing work as always. |
#60 |
Member#: 298020
SCIC
Very glad to hear that! Good info too for anyone having a misfire issue and has checked all other options!
#61 |
Member#: 154281
W. Canada
#62 |
Member#: 125580
Vehicle:2011 WRX 5dr OBP |
Great car.
#63 |
Member#: 154281
W. Canada
Thanks. I like it (most of the time).
I installed my Carlabs X-Brace today. The install wasn't as bad as I'd heard. Took me about 2 hours start to finish and I was working by myself. Sorry about the iPhone pics.... my DSLR battery was charging. ![]() Untitled by zcherniawsky, on Flickr ![]() Untitled by zcherniawsky, on Flickr |
#64 |
Member#: 154281
W. Canada
Might as well post these here too.
![]() DSC_3316 by zcherniawsky, on Flickr ![]() DSC_3320 by zcherniawsky, on Flickr ![]() DSC_3323 by zcherniawsky, on Flickr Sigh. Winter mode sucks. I updated my mod list. I think I've got everything now... Power V7 EJ207 Swap - 2001 JDM STI Motor (2.0L Turbo, 8000rpm redline) Maddad Unequal Length Headers, coated by Top Gun Coatings and wrapped in DEI Titanium Wrap Blouch Dominator 1.5XTR Turbo with PTP Turbo Blanket Tuned by Airboy - 280whp/240tq limited to 18psi, full tune soon DW 750CC Injectors Walbro 250lph Fuel Pump Perrin Turbo Inlet KS Tech 73mm Short-Ram Intake (to be installed prior to next tune) Perrin Divorced Downpipe wrapped in DEI Titanium Wrap Maddad Whisperback 3" Cat-back Exhaust Aquamist HFS-6 Water-Meth injection (to be installed) 12L Spec C Tank with 2qt Surge Tank (to be installed) Suspension and Drivetrain V7 (2001) JDM STI 6 speed Transmission V7 (2001) JDM STI R180 Rear Diff V7 (2001) JDM STI Brembo Brakes (Fronts painted black with Gold RSTI Custom Decals) OEM Rotors with Hawk HPS Pads ST Coilovers (made by KW) wrapped in Neoprene covers Whiteline Lowering Camber Plates (Front) and Group N Rear Tophats Ebay Strut Tower Bar (Front) Kartboy Front Endlinks (to be installed) JDM STI Front Swaybar (21mm) Whiteline Adjustable Rear Swaybar Whiteline Rear Endlinks (C-Style) V7 (2001) JDM STI Aluminum Front Control Arms Exterior V7 (2001) JDM STI HID Headlights Sonic Tuning ST8 (18x8.5 +35)w/ Bridgestone RE760 Sport (245/35/18) – Summer Wheels Gold Rota G-Force (17x8 +45) w/ Nokian Hakkapalita R (225/45/17) – Winter Wheels Velocity Carbon FRP Trunk with molded Mines rear lip JDM STI Hood/Hood Scoop JDM STI Sedan Front Grille Prodrive Front Lip 04/05 Tail Lights Hella Supertone JDM Power Steering Cooler 35% Tint on back 3 windows LED Reverse and License Plate Lights WRX Sideskirts JDM Vent Visor Kit (Window Rain Visors) Custom Made Rad Shroud (from WRX_RA) JDM STI CF Side Marker Deletes JDM Aero Pieces (front and rear spats) WRX Side Mirrors Interior / Sound Defi Link Gauges in ATI Clock Gauge Pod - Boost, Oil Temp, EGT AEM Wideband O2 in Subie Gal Pod 05+ Centre Console Swap painted black JDM V8 STI Cluster JDM Hazard Switch LED Dome Light Kenwood Double-DIN DNX5100 w/ Ipod in Glove Compartment and Bluetooth Handsfree Phoenix Gold Speakers MTX 2 Channel Amp for Sub MTX 4 Channel Amp for Speakers HVAC Colour Change to Red WRX Auto-Dimming Mirror Oh, and here's the current tune, limited to 18psi. I hope to get onto the dyno for the full tune soon, but its been hard to find times when both myself and my tuner are free. ![]() |
#65 |
Member#: 234591
NWIC
Vehicle:2003 Swap Needed White TS |
Sweet new grill dude
![]() Nice dyno as well |
#66 |
Member#: 154281
W. Canada
Thanks. I love the grille. Too bad its covered in dirt and slush right now
![]() I think im going to paint the single supertone and repaint the power steering cooler. With the new grille, they're even more visible and it kind of ruins it a little for me. Hopefully the dyno graph improves a fair bit. The extra 40whp right now isn't worth the increased lag... better get some more top end once we up the boost to 21-22psi. |
| Thread Tools | |
| Display Modes | |
| Super epic day for Cyclops' Project RSTi | Cyclops | North West Impreza Club Forum -- NWIC | 67 | 08-27-2010 10:17 AM |
| Impreza RSTI Project advice pls | Gymkhana~S7i~ | Newbies & FAQs | 1 | 11-04-2009 05:34 PM |
| Need the finishing touches! Project RSTi | CoBB_tHiS! | Tire & Wheel | 1 | 04-10-2008 07:36 PM |
| Suggestions wanted RSti hybrid project | rst4me | Normally Aspirated with bolt-on Forced Induction Powertrain | 5 | 03-02-2007 07:12 PM |
| Perrin FMIC on project RSTi | punkrocksailor | North West Impreza Club Forum -- NWIC | 7 | 04-28-2005 09:29 AM |
