Notices
Old 08-20-2014, 05:47 PM   #101
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
I've got several questions:
- I see these struts paired with both RCE blacks and yellow, yet those springs have different spring rates. So how is the Bilstein valved? Are there two available profiles? Or is the yellow "slightly underdamped" and the blacks "slightly overdamped"?
- what is the valve profile... is the compression stroke relatively higher than the rebound stroke?
- I'll pairing pairing these struts with King Springs for a slight lift. Any incompatibilities with this?
- how are you guys buying just top hats... don't you need the upper perch and conical washers?
- is there a difference between the black body and the yellow body strut?
- I have a 2011 WRX and -1.6 is a bit more camber than I want. (I've had wear at -1.3 with 0 toe, because I commute a lot too). Can I order the STI version of the Bilstein and use that instead since the track is the same as the 11+ WRX? What does this do for the valving profile?
I'm pretty anxious to buy these because they seem to be the best solution out available for me. I just need to get answers before pushing GO.
chimchimm5 is offline   Reply With Quote
Old 08-21-2014, 02:42 AM   #102
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The shocks are valved to handle BOTH rates. Damping % is in the 60's for both.
No difference between the yellow and black bodies other than color. The yellow body GTWORX/BILSTEINS came out because after waiting more than a year for production I wasn't about to send those back just to be painted black as we had asked for initially.
Most end users are using oem stock top mounts with all other oem hardware.
We have tested these with our springs that lower the car. I have no knowledge of how they would perform with raised springs.
Any other questions you can email me directly.
[email protected]
Mw.
RaceComp Engineering is offline   Reply With Quote
Old 11-13-2014, 11:31 AM   #103
Ikkitousen
Member#: 354304
2012 WRX
This question is for those that had coil overs prior to the Gtworx setup:
How are the body rolls? Obviously coil overs make it completely planted and that's where I'm at right now.
Ikkitousen is offline   Reply With Quote
Old 11-13-2014, 03:29 PM   #104
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The gas pressure in the shocks greatly reduces roll and acts as 70lbs of rate. So with Yellows this would feel like a coil over with 400lb springs. Not to mention these are valved for autocross and track day.
Myles
Old 11-27-2014, 02:30 AM   #105
MaxD
Member#: 93723
2013 WRX
Wanted to add to this thread as I also have the RCE Yellow+Bilstein setup.
Pic with blue wheels is 255/35/18 tires and pic with graphite wheels is 245/40/18 tires
I think for aesthetics I should have gone black as I typically DD
DGP_2288 by Max Denisevich, on Flickr
DGP_2224 by Max Denisevich, on Flickr
MaxD is offline   Reply With Quote
Old 06-03-2016, 03:15 AM   #106
chillwill007
Member#: 441189
2010 Impreza obs
2 tone silver
Sorry to bring up am old thread but I have a 2010 impreza outback sport which I know sits highet stock then a wrx or sti. How much of a drop would I get using this setup with the yellow springs? And could I still use my stock top hats?
chillwill007 is offline   Reply With Quote
Old 06-03-2016, 09:48 AM   #107
pw-
Member#: 402177
2013 WRX Hatch DGM
2015 Forester Ltd DGM
It's in the description of the product on this page for the WRX. For an OBS you'd likely have to call them and ask.
http://www.gtworx.com/index.php/gtwo...psportkit.html
pw- is offline   Reply With Quote
GTWorx Bilsteins/RCE Yellows or Coil-overs? Ginsubie Brakes, Steering & Suspension 10 10-03-2013 12:29 AM
2011 5 door GTWorx Bilstein Cup Suspension Install help Jaker Brakes, Steering & Suspension 21 11-14-2011 01:47 PM
ATTN '08+WRX owners-2 set of GTWorx Bilsteins/RCE Yellows in stock for $1250 dalesalignment&brake VIC Vendor Classifieds 2 09-29-2011 10:23 AM
2011 WRX - RCE/Bilstein Setup zmaster Texas Impreza Club Forum -- TXIC 7 06-22-2011 08:39 PM
GTWORX\Bilstein\RCE\Whiteline goodies installed fromario New England Impreza Club Forum -- NESIC 9 05-23-2011 09:29 AM
