Old 09-28-2011, 12:42 PM   #1
ColtonEckert
Member#: 259831
2005 STi
Default Spoiler leak (not into the trunk)
Does anybody else with the sti wing have the issue of water going under the wing and leaking out down the trunk. I am sure it just means it needs to be resealed, but with what I don't know. Foam auto tape? The water runs from the top of the trunk, under the wing, then out the little groove in the trunk. This happens on both sides.
ColtonEckert is offline   Reply With Quote
Old 09-28-2011, 01:48 PM   #2
WTFWJD014
Member#: 226468
2005 Impreza WRX
you can try a putty apoxy like this:
http://www.tapplastics.com/shop/product.php?pid=283
Worked when I used it on my dad's lexus door panel and it's still on there. It's been 6 years since I did it, and it's still holding on strong. But follow the directions of setting it and wear some disposable gloves while using it; some of it will come off on your hands.
WTFWJD014 is offline   Reply With Quote
Old 09-28-2011, 05:10 PM   #3
ColtonEckert
Member#: 259831
2005 STi
Nvm found out the holes were supposed to be there, thx for the help WTFWJD014
Old 09-28-2011, 06:06 PM   #4
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Glad you figured this out.
Yes, it's so your trunk lid in front of the wing does not turn into Lake Mead when sitting in the rain for some hours and then you perchance have to open it thereafter.
Old 09-29-2011, 01:17 AM   #5
WTFWJD014
Member#: 226468
2005 Impreza WRX
No worries man glad it isn't a big issue
exhaust leaks coming into the car through hvac gto7419 Interior & Exterior Modification 6 09-22-2009 10:41 AM
'02 WRX: Water leaks into the trunk via wing screws Padge Interior & Exterior Modification 2 01-28-2008 08:04 AM
Oil line ruptures under the barnet, leaks into the inlet. Predwolf Vancouver Impreza Club Forum -- VIC 7 07-25-2007 02:05 AM
Water Leaking into the trunk? DVN428 Service & Maintenance 2 08-26-2006 11:29 PM
Question about possible water leaking through the hood scoop into the engine bay? bambams247 Interior & Exterior Modification 2 08-28-2003 11:20 AM
