Old 09-28-2011, 05:11 PM   #1
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Default No Limit - GRB STI Precision 6266 full build
Whats up guys? I thought I would journal a build we are doing for a customers car as it is happening really fast, and I have not seen many GRB's with a engine build like this one. Goal is to have the car done by end of October as long as everything goes according to the plan.
It is a 2009 GRB STi stock besides an Invidia Q300. It came to us with a spun rod bearing. (not sure of the details of that, don't care).
Here are the mods that are getting done. Goal of the car is 500whp or more on pump gas using Precision Turbo's new 6266. Customer did not want to do E85 fuel (unfortunately), nor did he want to port the heads or sleeve the motor. No good stand-a-lone exists for the 08+ cars so we are going to try it on MAF and POSSIBLY new Cobb speed density. I think it has it in it, but we will find out
Engine (bottom end)
EJ257 Nitride Crankshaft
Manley 8.5:1 Pistons
Manley Turbo Tuff I Beam Rods
ARP Headstuds
ACL Race Bearings
New 11mm Oil Pump
New OEM Oil Cooler (always replace these on blown engines)
Denso IKH24 Spark Plugs (2 steps colder)
Heads
GSC Beehive Springs/Retainers
GSC S2 Camshafts
Supertech Inconel Valves
Cosworth Head Gaskets .78mm
Torque Solution Air Pump Delete
Grimmspeed TGV deletes
Fueling
Agency Power Fuel Rails
Fuel Injector Clinic 1100cc top feed injectors
Full Blown Motorsports 340LPH Fuel Pump
Aeromotive Fuel Pressure Regulator + Fuel Pressure Gauge
Turbo/Exhaust
Extreme Turbo Systems Rotated Turbo Kit - V-band up-pipe/V-band Downpipe
Extreme Turbo Systems FMIC
Precision Turbo 6266 CEA Ball Bearing V-Band Inlet/Outlet .82 A/R
Tial 44 MV-R Wastegate
Tial Q Blow Off Valve
HKS Equal Length Headers
Invidia Q300 Cat-Back
Driveline
Torque Solutions Pitch Stop Mount
ACT Heavy Duty Clutch - 6 Puck Sprung Disc
ACT Streetlite Flywheel
Misc.
Crawford V2 Air Oil Separator
SMY Dual Gauge Cluster
AEM Boost Gauge
AEM UEGO Wideband
Hallman Pro Manual Boost Controller
Cobb Accessport V2
Here are some pictures of how it sits right now. Motor will be back from getting bored out in a couple days than assembly starts. Turbo kit won't be here for about 3 weeks.
No Limit Motorsport is offline   Reply With Quote
Old 09-29-2011, 03:08 PM   #2
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Here is a look at the fuel system components we are going to be using. (except for the rails)
We have been having great luck with the Full Blown fuel pumps. We have found that they run cooler than the competition yet flow the same. They clip right into the factory harness and include a new filter.
Notice the unique look of the Fuel Injector Clinic 1100cc injectors. For a high horsepower pump gas Subaru look no further. They have that extra bit of edge over 1000cc, they tune and run excellent and easy, and the price is great. A decent bit below the competition.
Lastly wrapping it up is the Aeromotive compact regulator. Nice and small which makes it very easy to find a mounting place, and includes the fittings pre-installed to boot. Helps us dial the fuel pressure exactly where we need it, and help keep it rock solid. The Marshall liquid filled fuel pressure gauge helps us when setting pressure and make sure all is functioning as it should.
Old 09-29-2011, 04:37 PM   #3
Unrivaled
Member#: 296234
That looks awesome. I love that New NY licence plate with the mets colors
Unrivaled is offline   Reply With Quote
Old 09-29-2011, 04:52 PM   #4
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Change of plans. Decided 6266 would be more fitting for this. We are finding the spool difference between the 6262 and 6266 to be minimal
Old 09-30-2011, 05:09 PM   #5
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Lets take a look at the internals we are using for this build
We love the 2618 forged Manley pistons with there uber-thick ultra beefy design, and skirt coating. They also include premium piston rings that gap just right.
In addition we are using Manleys made in USA "Turbo Tuff" I beam rod. We recommend these for builds going over 550whp
You can see the difference between the H beams (which are also a very good rod if you are on a budget) and the more expensive stronger I beam
Old 10-04-2011, 06:00 PM   #6
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Our turbo came in today from Precision. It is there brand new ball bearing 6266 billet CEA. What is interesting about Precision's ball bearing center section vs a brand like Garrett is that it is ONLY oil cooled. No need for extra water lines.
The turbo we are using is with a ported S cover (4" inlet, 2.5" discharge) and features there V-band inlet with 3" V-band outlet. A/R is .82
...and now for the pictures
Comparison to VF39
Old 10-04-2011, 06:30 PM   #7
xilles
Member#: 147056
hope to see this at some of the weekly lisc meets..
xilles is offline   Reply With Quote
Old 10-19-2011, 11:17 PM   #8
fourmicah
Member#: 128760
2015 STI
So what's the deal with the 6266, what makes it different than the 6262?
fourmicah is offline   Reply With Quote
Old 10-20-2011, 08:55 AM   #9
benit0
Member#: 202204
02 WRX
6262 is 62mm compressor, and 62mm turbine.
6266 is 62mm compressor, and 66mm turbine.
benit0 is offline   Reply With Quote
Old 10-20-2011, 09:07 AM   #10
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Nice build!! How do they compare to the gtx and hta86?
D Money is offline   Reply With Quote
Old 10-20-2011, 10:52 AM   #11
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Depends what GTX your talking about. It is smaller than an HTA86 (62mm inlet/86mm exhaust)...
Just waiting on GSC to get me the cams and this thing can start going together.
Old 10-20-2011, 11:11 AM   #12
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
The HTA86 is only a compressor wheel upgrade. The inducer is 62mm but the exducer is 86mm vs the standard 82mm. The exhaust side however is just a stock GT35R wheel so the 6266 is a bit larger in all areas especially the exhaust wheel except for the exducer of the compressor wheel.
Crystal_Imprezav is offline   Reply With Quote
Old 10-24-2011, 07:59 PM   #13
expo9091
Member#: 249359
any updates?
im doing a similar build, im interested what this puts down = )
expo9091 is offline   Reply With Quote
Old 10-27-2011, 03:35 PM   #14
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Originally Posted by expo9091 View Post
any updates?
Making headway. Bottom end is together. Turbo kit is shipping this week. We are away at SEMA next week. Hopefully car will be done the week after we get back.
Adam
Old 10-27-2011, 06:04 PM   #15
expo9091
Member#: 249359
Adam
very nice! keep us posted
Old 11-06-2011, 11:17 PM   #16
ddejaege
Member#: 291612
'02 Bugeye
Subscribed. Interested to see how this one comes together.
ddejaege is offline   Reply With Quote
Old 11-07-2011, 10:03 AM   #17
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Just got back from SEMA. Time to start assembling the motor.
Turbo kit is due to be here from ETS this week, that's the only thing that may hold us up.
Old 11-15-2011, 06:52 PM   #18
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
The turbo kit has arrived!!!! Basically full v-band turbo kit. The only gaskets on the car are motor to header, header to up-pipe, and downpipe to catback... I might have to handle that for a full v-band setup
All up-pipe to turbo, turbo to downpipe, and downpipe connections are wonderful v-bands
Sexy welds and wastegate transition. Expect nothing but the best from ETS. Never a disappointment
Built in 02 simulator, and more perfect welds
Yummmm more sexy welds on the 2 piece V-band downpipe
Best up-pipe ever? I think so
Why hello there giant perfect front mount core!
Every bit of hardware included
More pictures tomorrow....
Old 11-15-2011, 07:05 PM   #19
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
Wow...........damn nice
Wrx_Fan_0717 is offline   Reply With Quote
Old 11-15-2011, 07:13 PM   #20
B03scooby
Member#: 102929
2003 07STi,03,07 STi
SWP/ WRB/UGM#239
subscribed build threads allow me to dream
B03scooby is offline   Reply With Quote
Old 11-17-2011, 05:14 PM   #21
dScooby
Member#: 277465
2010 WRX
sl0w
Wow beautiful!!
dScooby is offline   Reply With Quote
Old 12-01-2011, 09:12 PM   #22
expo9091
Member#: 249359
any more progress?
Old 12-02-2011, 12:41 PM   #23
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
any more progress?
Ask and you shall receive. I have been very busy lately. I am going to post pictures where it sits right now. I expect it running tonight
Old 12-02-2011, 12:47 PM   #24
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
Ok the kit is not fully installed yet. Still need to put on a couple intercooler pipes and the intake, but at this point it is safe to say it is the best fitting turbo kit we have ever seen/worked with. I will never use anything else.
Every single piece needed was included. Every bracket PERFECT. No fighting with anything for fitment
Engine on the stand getting buttoned up. We used the HKS equal length header.
Here you can see the v-band up-pipe
Some pictures of the front mount
About to drop the engine in
As it was when I left last night
As it sits right now. Need to run the fuel lines/regulator and than put the remaining pieces on. Should be done by 6pm ready to break in, and tune
Old 12-02-2011, 01:11 PM   #25
Member#: 194655
08 STI
Great write up so far! I can't wait to see the results of this build. I like the attention to detail.
Thanks,
Michael
Extreme Turbo Systems is offline   Reply With Quote
No heat - '05 STI shiplemw Service & Maintenance 21 02-07-2012 04:51 PM
FS : EJ25 Short block NO pistons - NOT STI ! poruki VIC Private Classifieds 1 05-14-2011 02:12 PM
New & Improved No Limit Motorsports - Engine/Power Build Up Thread - Many Brands!!! No Limit Motorsport Engine/Power/Exhaust 421 01-25-2011 01:14 PM
FS: Impreza Magazine no. 38 - GRB tuning feature noweeng Accessories & Misc 7 03-17-2010 07:43 PM
WTT: CGM rear trunk lid - no wing - 05 sti jscramst VIC Private Classifieds 0 10-24-2007 09:29 PM
