Old 09-28-2011, 05:28 PM   #1
derilict
Member#: 236549
2007 WRX Wagon STish
Default Horrible stumble when cold/moderate when warm
I've searched other similar threads, but all of those have other symptoms and usually display a CEL, which mine does not.
Issue: Runs like CRAP when cold, gets better once it warms up a little. Still has a slight hesitation under light and moderate load; seems to run fine at WOT.
Car: Stock '07 WRX w/ K&N PANEL filter (not intake) and STi OEM axle-back. Currently running AP Stage 1 since the car's stock.
I've replaced the plugs, cleaned the MAF, and cleaned/re-oiled the K&N. I also checked the MAF voltage with the AP, and it rises and falls with throttle/rpm as it should (or so it appears).
Is this a tuning issue?
I was thinking the AP map was making it run richer when cold, thus the bad stumble. But I re-loaded the stock map, unmarried it, and it still does it, but not as bad. I'm just thinking, as with any "issue", if you add power the problem is exacerbated.
Ideas? Thoughts?
Thanks.
derilict is offline   Reply With Quote
Old 09-29-2011, 10:27 AM   #2
Cobb Tuning
Member#: 4803
Does it idle poorly as well when cold or is the issue only present when you are driving?
Bill
Old 09-29-2011, 11:13 AM   #3
CIATexan
Member#: 95189
2002 WRX Wagon
Yea, this doesn't sound like a tune issue, sounds like a mechanical issue. Especially considering you took it back to stock and your having the same issues.
CIATexan is offline   Reply With Quote
Old 09-30-2011, 09:46 AM   #4
derilict
Member#: 236549
Bill
Bill, it idles perfectly cold or hot. The ONLY time I've noticed rough idle is when returning to a stop after longer periods on the interstate running 75+. The whole damn car shakes. This particular issue is only present when under load.
I'm in agreement for the most part. I'm just trying to figure out if the reason its worse with a tune loaded is 1) because of the tune, or 2) as mentioned before, anything that produces more power with an already present issue is going to exaggerate/intensify said issue.
Thanks for the reply guys.
Old 09-30-2011, 10:57 AM   #5
Cobb Tuning
Member#: 4803
Yeah, if it is doing it with the stock map, then you have some kind of mechanical issue. The best thing to do at this point is to get a data log when the hesitation occurs and when you have the rough idle. Try not to make it a huge log that is difficult to go through. Instead, just start the logging right before the hestitaiton (or bad idle) is occuring and end it right after.
Here's a general video on how to get started with data logging. Use the default logging set, but for your particular issue, also add "A/F Correction 1".
Bill
Old 10-17-2011, 11:12 AM   #6
derilict
Member#: 236549
Bill,
Got some short logs in per your direction. I'm assuming at this point I need to email the .xls logs to a tuner for analysis? I'll be honest, I only have a slight idea of what I'm looking at (and conversely, what it's SUPPOSED to look like).
Old 10-18-2011, 09:32 AM   #7
Cobb Tuning
Member#: 4803
Originally Posted by derilict View Post
Bill,
Use google docs and you can post a link to your log here (just upload the original .csv file not the file you opened and saved in your speadsheet software). Make sure you set the permissions in google docs to public so anyone can view it.
Bill
Old 11-22-2011, 06:09 PM   #8
derilict
Member#: 236549
Didn't realize .csv was a type of .xls file.
Old 11-22-2011, 06:26 PM   #9
derilict
Member#: 236549
Log 2
https://docs.google.com/open?id=0B8z...RkZjJkZTI4NDEy
Log 1
https://docs.google.com/open?id=0B8z...I3MjQwMTNkOTI5
I'm not sure if these are telling much, I'll try to run a couple more when it's really misbehaving.
Thanks.
Old 11-22-2011, 06:56 PM   #10
itwasthatguy
Member#: 233580
2006 sti
obp
I would think this has to do with the avcs since they are oil drivven and cold oil would flow differently than it being hot.
I think they have oil screen filters that may need cleaning.
But I am far from a subaru expert yet lol
itwasthatguy is offline   Reply With Quote
Old 11-23-2011, 09:27 AM   #11
Cobb Tuning
Member#: 4803
Log 2
Log 1
Thanks.
Links are not working for me (says "no preview").
Bill
Old 11-23-2011, 04:08 PM   #12
derilict
Member#: 236549
I noticed that too Bill. Having never used google docs, I wasn't sure if this was normal. So I just clicked "download" and "open" to view them. Let me know if I need to fark with something in google docs.
Old 11-23-2011, 05:50 PM   #13
maxx686
Member#: 287807
2011 WRX
clean your maf
maxx686 is offline   Reply With Quote
Old 11-23-2011, 06:22 PM   #14
Cobb Tuning
Member#: 4803
I'm not able to download it either. Not sure what the issue is, but you can upload the actual .csv logs at our forums (cobbforums.com). Just start a post and click on manage attachments.
Bill
Old 11-29-2011, 08:07 PM   #15
derilict
Member#: 236549
Hey Bill, thanks for the help.
I've created a new post over at the Cobb Forums.
http://www.cobbforums.com/forums/sho...460#post659460
Old 11-29-2011, 08:18 PM   #16
derilict
Member#: 236549
Originally Posted by maxx686 View Post
clean your maf
Yup, that was the first thing I did.
Old 11-30-2011, 10:14 AM   #17
Cobb Tuning
Member#: 4803
Hi. I responded to your post at the cobb forums.
Bill
Rough idle, misfire CEL, car stumbles when cold roksax Service & Maintenance 6 07-22-2006 03:53 PM
stumble on cold start with CIL rough idle Deity Normally Aspirated Powertrain 7 11-05-2004 02:44 PM
My car idles lumpy when cold but is fine when warm? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-03-2004 04:37 PM
Misfire/Stumble at cold startup SilverBoosted Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2003 04:01 AM
Squeeky Rear Suspension when Cold, goes away when warm. nhalterman Brakes, Steering & Suspension 2 12-12-2001 03:31 PM
