Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 09-29-2011, 07:18 PM   #1
JasonBlessed
Member#: 226412
04 Wrx wagon
Default where do I download a stage 3 map from?
Sorry if this is a very dumb question. Just got my accessport today for my 04 wrx 2.0. Just finished installing a vf39, 560 cc injectors, walbro fuel pump and catless turbo back. I plugged it in to the obd2 port and only stage one and stage two maps are loaded. Tried googling, searching nasioc and searching cobbs site. Any help on where I can get the stage 3 maps? Thanks in advance again sorry if this is a dumb question. Jason
JasonBlessed is offline   Reply With Quote
Old 09-29-2011, 07:38 PM   #2
WashmyScooby
Member#: 83820
You are most likely going to need a custom tune if I had to guess.
WashmyScooby is offline   Reply With Quote
Old 09-29-2011, 07:43 PM   #3
JasonBlessed
Member#: 226412
04 Wrx wagon
Is there a base stage 3 map I could use before I get a pro tune?
Old 09-29-2011, 08:04 PM   #4
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Call cobb and see if you can get away with 560 injectors instead of the 565's. They have 565's spec'd for the stage 3 vf39 maps, so its hard to say.
2Fast4U1DAY is offline   Reply With Quote
Old 09-29-2011, 08:22 PM   #5
JasonBlessed
Member#: 226412
04 Wrx wagon
I did some research before I bought them, pretty sure I can use them. Where can I download the base stage 3 map from?
Old 09-29-2011, 08:37 PM   #6
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Honestly your scaling will probably be off a little, so I would contact cobb to make sure before I flashed the car.
First you have to marry the accessport to the car by loading one of their preloaded maps into the car (do not run the car after you do this).
Then you can connect the AP to your computer. Go to Cobbs site and click the support tab, and download the accessport manager for your ap. Then be sure to update to the latest firmware (done one the AP manager).
After you do so, you can access their database of maps for your car in the AP manager, and download the map to your computer.
Then you just add it to the AP.
The AP has onscreen instructions for the initila flash (and when you decide to do the reflash) and I believe the AP manager has good directions too for uploading the map to the AP.
When you change the map make sure you do it as a reflash, and not as a realtime map.
I am sure Cobb will chime in with more detailed instructions, but this is just the C/N version lol
Old 09-29-2011, 08:58 PM   #7
JasonBlessed
Member#: 226412
04 Wrx wagon
Exactly what I needed! That gives me a place to start, thanks a bunch. Any other tips are greatly appreciated. Thanks a bunch!
Old 09-30-2011, 11:14 AM   #8
Cobb Tuning
Member#: 4803
Hi there. You can find all our maps here:
http://www.cobbtuning.com/info/?ID=3061
There are VF39 maps available for the 02-05 WRX for different aftermarket injectors.
Bill
Old 10-02-2011, 12:09 AM   #9
Dj Xtz
Member#: 183720
2003 Impreza WRX
Sonic Yellow w/DGM 2-tone
Default Stage 3 Maps
I downloaded my stage 3 Map straight from the Cobb site under the Accessport tab. I am using the dark blue Denso 560cc injectors with no issue. Did plenty of data logging looking at knock learn boost and ignition timing. Hitting close to 19psi at 4180rpm in 3rd with 100% tp and 51% wgdc. You can get the maps from this page http://accessecu.com/accessport/suba...-Map-Grid.html. Just click on the view link for the model year you have and whether you have a stock or SF intake.
Dj Xtz is offline   Reply With Quote
Old 10-03-2011, 03:09 PM   #10
Dj Xtz
Member#: 183720
2003 Impreza WRX
Default Stage 3 Map
Here is the datalog of the Cobb Stage 3 Map on my 03 WRX. http://www.mediafire.com/?nb5q1qq1fghkqo3. Hit 20.19 PSI according to the AP, at the most I see 900 degrees for EGTs.
Engine and Drivetrain Mods include:
Cobb AP V2, of course
Cobb Catted DP
Denso Dark Blue 560cc Injectors
Walbro 255lph Fuel Pump
5/16" Fuel Line Conversion
PNP VF39
PNP Intake w/ Winkle Black Finish
PNP TGV Delete
3mm Intake Risers
4 Ply Black Silicone Turbo Inlet Tube
STI Catback w/ Resonator Deleted
Heat Wrapped STI Up Pipe
Coated Borla Unequal Length Headers
Snorkus Delete on Stock Intake
Stock EBCS with restrictive coupler removed
Perrin Radiator Shroud
Exeddy Stage 1 Clutch Kit
F1 Racing 12lb Flywheel
Has anyone ran the turbo xs stage 3 map from turboxs.com? alenk37 UTEC 7 07-13-2009 06:01 PM
anyone have a decent Stage 3 Map that isn't as conservative as base map? wrxpeed UTEC 14 05-05-2006 05:41 PM
AMERICAN DAD: Where do I download the Preview Oh Canada Off-Topic 12 02-04-2005 11:43 AM
Where do you download free music? SubaruRules Off-Topic 27 06-16-2004 10:37 PM
How do I modify my stage 3 UTEC map for Race gas? Davenow Engine Management & Tuning 1 03-31-2003 05:39 PM
