Old 09-30-2011, 12:08 AM   #1
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
Default Sti version 4 swap help
Hey guys, so I got this sti version 4 swap and its going under the hood of my 2001 2.5rs... So At this point I'm kinda stuck trying to decide how I'm going to setup the wiring and engine management system. The swap came with transmission, axles, front brakes/arms,differential, and ecu... I was told to use a complete ver. 4 harness and use the ecu it came with... idk i just want this thing running perfecto! I'd be cool to get some tips & pointers from the more experienced subaru'ers...
Ralph509 is offline   Reply With Quote
Old 09-30-2011, 12:15 AM   #2
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
how do i post pics??
Old 09-30-2011, 01:59 PM   #3
kheff46
Member#: 66739
2002 WRX wagon
v4 wont pass emissions. you can do a full harness swap, but it will be cleaner with a proper merge. i did the harness twist(my term) and it works, but would be better wired into your cars existing harness. imo
--keith
kheff46 is offline   Reply With Quote
Old 10-01-2011, 12:31 AM   #4
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
--keith
& that would work? V4 merged with 2.5rs?
Old 10-01-2011, 12:35 AM   #5
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
--keith
Im in WA state idk what emissions i have to pass or if i would have to get it approved...
Old 10-01-2011, 09:49 AM   #6
kheff46
Member#: 66739
2002 WRX wagon
verify your states requirements for oldr cars. this would tell you if its really worth the trouble of building this as a DD. if its a race car, go nuts! buut, if DD is in it's future, go for an OBDII compliant swap(or passable). some states require different tests, so this may factor in as well. im unfamiliar with WA state personally, maybe someone can chime in who's "in the know"?!
--keith
Old 10-03-2011, 05:13 PM   #7
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
--keith
Thanks Keith il check out the WA states requirements so I dont waste any time....
Old 10-06-2011, 02:34 PM   #8
Boost4life05
Member#: 223308
2005 STi
OPB-Stage [email protected] tune
WA state "requires" emissions....I quote because not every county requires you to get an inspection. If you dont have to get an inspection then you can pretty much do what you would like... It'll just make it hard if you choose to sell it and its to someone who has to get it inspected. the loop-hole here is you can just register it in a county where you don't need an inspection...
Boost4life05 is offline   Reply With Quote
Old 10-06-2011, 02:35 PM   #9
Boost4life05
Member#: 223308
2005 STi
I am also interested in this thread though so i thought i'd contribute. Im looking to throw a v4-v6 motor in my new 2001 RS project.
Old 10-07-2011, 11:22 AM   #10
kheff46
Member#: 66739
2002 WRX wagon
98 RS and V4 are the closest cars from the different continents and therefore more easily swapped/merged. 01 shouldn't be much more work as it has elec heaters like the V4 and newer cars.
P.S. you can register a car in a place where you don't actually live. you know when you need plates(birthday), so who cares where they mail your reminder? just pick a legit addy in a place with no inspections and you don't need one.
--keith
Old 10-07-2011, 02:42 PM   #11
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
What would be a good aftermarket ecu I don't want to run the stock ecu... i heard most of these engines blow up b/c of detonation due to that fact that they are use to Japanese fuel which is higher octane than the american fuel... the point is i just want it running perfect....
Old 10-07-2011, 02:50 PM   #12
kheff46
Member#: 66739
2002 WRX wagon
the stock ECU would be fine if you wanted to put some higher octane in. i ran 93 without issues for 2 years. others haven't been that lucky i guess.
aftermarket is an option(not for emissions), or another less aggressive JDM ECU. this is where most people stop seeing JDM swaps as a legit replacement. theres stuff out there, but not emissions friendly. i swapped into an older chassis(OBD1) and they can plug in, so i get a sniff test only. some states still sniff and have AWD roller tests(from what i hear). ohio isn't that way, so i went that route.
--keith
Old 10-08-2011, 03:02 PM   #13
Ralph509
Member#: 254379
2001 Subaru 2.5 RS
currently black
I guess I better find a Ej257 short block for back up in case anything happens but I already talked to a local tunner who says he can tune it with the stock ecu and pull timing so it doesn't need the higher octane gas...
STi version 4 Tranny with 4.44Rearend darksc00by Drivetrain 2 03-26-2007 11:14 PM
Need help for JDM STi version 7 swap in 02 WRX mathroch Subaru Conversions 3 08-11-2006 11:14 AM
Sti version 4.11 box, vs Version 2 RA 3.9 supermoose Transmission (AT/MT) & Driveline 14 08-04-2005 10:20 AM
Sti Version 4.11 Gearset with 4.11 LSD - full drop in conversion to 4.11 short ratio! supermoose Private 'For Sale' Classifieds 11 07-06-2005 03:14 PM
wanted: version 4 swap pictures blue2.5 Member's Car Gallery 9 06-27-2005 11:10 PM
