Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 08-04-2002, 01:48 AM   #1
subyguy1995
Member#: 21740
1995 impreza L
red
Question Stroker kits?
this may be a dumb qustion but what dose a stroker kit do i have a 2.2L 1995 impreza L and i see a 2.2L stroker kits what do they do
subyguy1995 is offline   Reply With Quote
Old 08-04-2002, 01:48 PM   #2
Section 8
Member#: 821
Those kits are usually for increasing the displacment of 2.0 liter WRX engines.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 08-05-2002, 11:14 AM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
A stroker kit is typically a different crankshaft, rods and pistons that effectively increase the displacement of an engine by increasing the stroke, or travel of piston within the cylinder. The old addage "no replacement for displacement" holds true but there is a limit to just how much an engine can be "stroked". More tradtional engine builders will bore and stroke an engine, i.e. boring out the cylinder walls and lengthing the travel to increase displacement. The #1 problem with the EJ series engines is the open block design is very close to its limits in terms of cylinder wall thickness so we're relegated to stroking only. Hope this helps.
Old 08-05-2002, 12:27 PM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
search on the web for aftermarket stroker kits for aircooled VW flat 4's, and you'll find volumes of info. almost all of what's true there carries over, ESPECIALLY parts about keeping engine temps down. having owned a 2.0L beetle in FL (with numerous extra oil coolers and the biggest fan i could jam under the early-style decklid), i can tell you that even with a liquid cooled engine, proper cooling is still ESSENTIAL; make sure you don't overlook that.
RaceCarRiot is offline   Reply With Quote
Old 08-05-2002, 01:17 PM   #5
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
Default Re: Stroker kits?
I was curious about this too, and found a kit by JUN, but thought it would be for raising a 2.0 to a 2.2. I have a 2.2 already, does anyone know if the SOHC 2.2 can use the parts from a SOHC 2.5 for the same effect?
Darby is offline   Reply With Quote
Old 08-05-2002, 01:25 PM   #6
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
You would need to get a 2.2l stroker kit. The EJ25 parts would not work. Try Paeco Industries for info on stroker kits.
Old 08-05-2002, 01:58 PM   #7
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
Now if somebody would just make a 2.7 liter stroker kit for the 2.5 liter SOHC motor...
subarumantoo is offline   Reply With Quote
Old 08-05-2002, 02:07 PM   #8
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Let me reiterate: Paeco Industries
Old 08-05-2002, 04:59 PM   #9
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
thanks for the link, I contacted them.
Old 08-05-2002, 05:23 PM   #10
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
anytime
Old 08-05-2002, 08:32 PM   #11
obyone
Member#: 16523
this anymore???
WERD!
obyone is online now   Reply With Quote
Old 08-06-2002, 08:11 AM   #12
subarumantoo
Member#: 3257
2000 ImprezaRS
Blue Ridge Pearl
I just e-mailed them about a stroker kit for the 2.5 liter motor. I will let y'all know what they say...
Old 08-06-2002, 10:07 PM   #13
JSiwek
Member#: 14909
MRT has a stroker crank shaft for the 2.5 L engines... check their website.
Jeremy
JSiwek is offline   Reply With Quote
EJ20 Stroker Kit or Engine Rebuild Kit Mindravel Private 'Wanted' Classifieds 2 09-17-2008 05:06 PM
Brian Crower Spring/Retainer Kits, Stroker Kits!! Built Industries Engine/Power/Exhaust 0 04-09-2007 04:58 PM
Stroker Kits for WRX!!! subaruwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 51 02-01-2003 03:12 PM
Stroker Kits -- what's involved? phatride01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-11-2001 03:51 PM
Anyone ready to try the BPM 2.2l stroker kit? Hucker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-28-2001 11:29 AM
