Old 09-30-2011, 12:08 PM   #1
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
Default Cam Seal questions
After a quick search I found out that the cam seals I need on my EJ20g are the same as any DOHC Subaru Motor. Is there a proper method for removing the seals? I plan on doing my timing belt soon (<--85k) and figured this would give me the perfect opportunity.
JDMFLCL is offline   Reply With Quote
Old 09-30-2011, 01:21 PM   #2
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I dont believe you can just pop them out and push the new ones back in with out pulling off the valve covers and removing the cams....thats untorquing all the internals and new valve cover seals. You mind as well do everything seal wise while your in there then .....you know the whole sha-bang!
Hopefully Im wrong....but I dont think so
dangerousatom is offline   Reply With Quote
Old 09-30-2011, 06:46 PM   #3
bangusto
Member#: 296349
1997 impreza gt
black
i have the same problem on my car!! i think you can remove the valve cover only for replace the gasket
bangusto is offline   Reply With Quote
Old 09-30-2011, 09:42 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Just pop the out with a flathead and drive them back in with a big socket or piece of pipe.
You don't need to touch the valve covers.
Be careful not to gouge anything popping them out and be sure to use something as big as the outside diameter driving them back in so you don't ruin them.
Old 09-30-2011, 11:18 PM   #5
dangerousatom
Member#: 70710
nice......69 would know for sure.....
Old 10-01-2011, 12:57 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
As above, 'just' remove the timing sprockets and remove the seals destructively with a scre driver.
New cam seals are the same part as the USDM EJ25 DOHC up to 1999 only, and also the same as SOHC came seals. The USDM WRX and STI DOHC use different seals (bigger diameter).
Marnix is offline   Reply With Quote
Old 10-03-2011, 11:08 PM   #7
JDMFLCL
Member#: 180513
Baby Baby C'mon!
How do I go about removing the cam gears?
Old 10-04-2011, 01:43 AM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
You have to 'lock' the sprockets and use a wrench with hex 17 nut. It's best to remove them with the timing belt in place if you don't have 'the' special Subaru tool but be careful that the belt doesn't skip. And do not re-use that belt afterwards.
Old 10-04-2011, 12:53 PM   #9
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
This.
When I took the cams off of my 1993 EJ22, I kept the belt on, and just tightened 2 c-clamps on each side of the belt. That thing did not spin at all and the cams came off no problems.
Might be a little harder to position some c-clamps on a DOHC, but I'm sure you can figure something out.
Good luck.
Jessekrs123 is offline   Reply With Quote
Old 10-06-2011, 01:17 PM   #10
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
Best way to get the cam gears off is with the belt on, but you could also just use an impact to get them off
This. it is super easy to deform the metal around the seals so be extra careful that you dont gouge it. then get a big socket thats the same diameter of the seal to carefully pound them back in (and be sure not to let the lip of the seal flip up/out when you are pushing it in
elislider is offline   Reply With Quote
Question about cam seals wrxwagon1992 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-26-2011 05:17 PM
changing cam seals, got some questions EPskate Service & Maintenance 3 02-22-2007 01:00 AM
replacing a cam seal, have a couple questions EPskate Tri-State Area Forum 2 02-21-2007 01:28 AM
Crank/Cam seal replacement question Topshelf Service & Maintenance 2 06-24-2005 12:22 AM
Cam seal question emanon Normally Aspirated Powertrain 7 07-12-2004 01:24 AM
