Old 08-04-2002, 10:16 AM   #1
Dr.Outback
Member#: 22133
1993 Legacy Turbo
Maroon
Default Anybody try manifold insulators?
I was reading about them on this site http://www.autospeed.com/A_0401/page1.html
Has anybody tryed them? I emailed the company on pricing and they said with throttle body insulators and other necessary hardware the kits are in the $100 range. The article makes them sound pretty good.
Dr.Outback is offline   Reply With Quote
Old 08-04-2002, 10:56 AM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
sounds pretty good....I'd give them a shot.
as a side note though, they don't really go into detail about their phenolic material..
Phenolics are like the basic building block of millions of other things, composites, polymers, adhesives, etc etc in everything from helicopter rotor blades, to fiberboard cabinets, to anything made out of plastic...
phenolics are like the bonding matrix usually for some other material, like urethane, carbon fibers, or whatever... so what I'm saying is, in these manifold insulators, what exactly is the phenolic based material bonded with?????? Theres got to be at least a hundred different kinds of phenol based materials out there.... its kind of important to know when you are looking for something that is going to last a long time,
oh yeah, and not give off any toxic fumes/substances when exposed to prolong heat.
sorry I kind of sound like a freak, but I work as an environmental scientist, and get paid to detect phenol and alkaline-phenol compound contamination in soil and water samples; so they can be cleaned up.. they are toxic to the whole ecosystem deal.
but for the most part I'm sure these are very tried and true and I'd go for it. carry on
Cujo31 is offline   Reply With Quote
Old 08-04-2002, 01:00 PM   #3
Dr.Outback
Member#: 22133
1993 Legacy Turbo
Maroon
they would only be for my '84 GL with 2Bbl Weber carb. With carbs I don't think it is good to use them because the carb might get so cold it freezes.
I just posted it as an FYI. If I had FI I would probably use them.
Cujo31... you know a lot more then I do about plastics.
Old 08-04-2002, 02:18 PM   #4
redwagon
Member#: 2181
2008 SpecB
Thumbs up
'phenolic resin' spacers come stock on many motors at the manifold to carb junction, to keep some heat out of the carb and avoid heat-soaking the fuel. They also usually have some kind of de-icer for the carb too, like some hot air piped from the exhaust manifold heatshield or wherever. As I recall, it's not reinforced with a fiber or anything, it's just a high-temp stable resin that's resistant to heated gasoline vapors. Go ahead and use 'em, shouldn't be any downside.
redwagon is offline   Reply With Quote
Old 08-04-2002, 06:40 PM   #5
obyone
Member#: 16523
There was a thread somewhere in the Classified section of the board, where someone was selling these. (I'm lazy...you do the search) HndaTch627 is supposed to be buying a set of these. If he ever gets them installed, I'll ask what he thinks of them.
obyone is online now   Reply With Quote
Old 08-04-2002, 08:08 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
subachad makes these for $70...pm him, we are trying to get a group thing going. I am on the list.
jeremy
Old 08-04-2002, 08:44 PM   #7
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
They are actually $60, I have about 5 sets left of the first batch that I can sell. Shipping to the "48" will be $5. As for a time frame, I'm supposed to pick them up Monday the 5th.
The phenolic material used can withstand up to about 270 degrees F for an extended period of time.
Here is a link for you.
http://www.uniquemotorsports.com/pro...ic_spacers.htm
Thanks,
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 08-04-2002, 10:28 PM   #8
SubeDonC
Member#: 426
86 MR2 - 07 Tundra
426 not a newbie anymore
im kinda interseted... but being that i never heard of such a thing, im kinda skeptical about it. Kinda like iridium tip plugs.
SubeDonC is offline   Reply With Quote
Old 08-04-2002, 11:41 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
the spacers do indeed work, they have been used for years in SB Chevy's between the carb base and manifold to keep the carbs from heat soaking, they also use them quite often on honda's to space the intake away from the head.
Chad-i tried finding the thread to bump it, i want to get that buy going. PM me with your paypal address.
jeremy
Old 08-05-2002, 01:22 AM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Phenolic spacers have also been used for years in the 5.0L Mustang crowd. I'll be honest, I've never seen any sort of dyno or drag strip comparison, so I don't know how effective they are, but the idea makes good engineering sense.
One thing I'd be interested in seeing is how the use of the spacers affects the torque curve of the engine. Using the spacers will create longer runners, which generally improves torque at the expense of some top end power.
Chad - I'm assuming you're selling just the spacers themselves? Or will this be some sort of "kit" including gaskets and the longer fasteners needed?
Also, I vaguely recall reading that the SOHC and DOHC 2.5L intakes are not interchangeable, although they look nearly identical. As I recall, the bolt pattern at the heads is opposite. Am I out to lunch on this?
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-05-2002, 05:46 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
[i]
Pat Olsen
'97 Legacy 2.5GT sedan [/b]
pat IIRC you are correct, the bolt patterns on phase 1's are different from that of phase 2's. But i don't think it'd be too hard to make a few different sets. I forgot the mustang guys used them as well. It has no relevance but in the LT-1 by disconnected the preheater for the throttle body(prevents throttle plate icing) they made 12 more HP @ the wheels IIRC...amazing what a lil hot air can do isn't it?
jeremy
Old 08-05-2002, 12:50 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Perhaps a 2.2 version will become available? That would cover quite a range of vehicles.
Old 08-05-2002, 01:45 PM   #13
subachad
Member#: 8488
Teal
These things cost me about $300 to make and you are the only one who has asked about a 2.2L version. That said, It's not much of a priority right now.
Next on the list would be for a WRX.
As for the spacing, if they don't fit, I'll just have to take them back. Has anyone ever compared different gaskets for different versions of the EJ25?
Chad
Old 08-05-2002, 02:51 PM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
hey chad i'll take a look whe i get mine.
jeremy
Old 08-05-2002, 09:47 PM   #15
subachad
Member#: 8488
Teal
Hi all,
There was a little problem with the production. More specifically, the bolt hole part of the spacers did not cut well.
That said, I have to order a new sheet of phenolic for them to cut. Sorry, but it might not be until Thursday or Friday of this week.
Thanks,
Chad
Old 08-05-2002, 11:52 PM   #16
Poppa smurf
Member#: 8257
2004 STI
Silver\Silver
So can we still order? who should we send paypal to? MY99 RS for me Phase II
Poppa smurf is offline   Reply With Quote
Old 08-06-2002, 07:49 PM   #17
subachad
Member#: 8488
Teal
So far I'm sending out 6 sets, which should leave me with 3 or 4. I'd like to hold off though before selling any more at least until some of the sold items are installed.
Hondatch will post some info once he gets his.
Thanks,
Chad
Old 08-06-2002, 09:11 PM   #18
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I repeat...
Also, I just went and looked at the bolt pattern for my intake where it joins the heads (and where these spacers would go). There is one bolt on each side of each runner. As you view the engine from the front of the car, the bolts are at the 12 o'clock and 6 o'clock positions relative to each runner. If someone could check their SOHC intake bolt pattern we could determine whether or not they are different - I'm pretty sure the SOHC intake has the bolts located diagonally on each runner.
Pat
Old 08-07-2002, 01:00 AM   #19
subachad
Member#: 8488
Teal
Sorry, that's my bad. The spacers are alone. 1/4" is not enough to require longer bolts.
Thanks,
Chad
Old 08-19-2002, 05:59 PM   #20
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Any update on this? Has anyone actually installed/tested these yet?
On the bolt pattern issue, I confirmed that the SOHC and DOHC intakes do use different ones. A 30-second sketch:
Which bolt pattern was this batch made for?
I just thought up another issue that I think is worth thinking about. Using these spacers will alter the position of the fuel injectors relative to the intake valves. I'll be honest, I don' t know if that's a big deal or not, but I would think that injector placement is something Subaru tunes to ensure proper fuel-air mixing before/as the charge enters the combustion chamber. Will having the injectors 1/4" higher cause them to spray onto the wall of the intake runner rather than onto the back of the intake valves? Will the new position cause the fuel to be injected into a spot where the air flow is turbulent vice laminar or vice versa? Hmmmm.....
Pat
Old 08-19-2002, 06:17 PM   #21
Supapooh
Member#: 4461
02 2.slow
Being local to ya.....kinda I might be up for a little guinee pigging
Supapooh is offline   Reply With Quote
Old 08-20-2002, 04:15 AM   #22
subachad
Member#: 8488
Teal
The bolt pattern (judging by your picture) is for the SOHC version.
Sorry it's taking so long guys, but so far, out of two sheets of phenolic I thought we had 2 sets of spacers. Unfortunately while drilling out the bolt holes, I damaged one of the spacers which only leaves one set. Sorry Jeremy, but you'll have to wait for the next batch. That one set cost me about $200
Hopefully the next batch will have some better results.
Thanks,
Chad
Old 08-20-2002, 05:21 AM   #23
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Thanks,
Chad
it's allright, i did something in the mean time which cut down Intake Air Temps significantly no rush.
jeremy
Old 08-20-2002, 10:29 AM   #24
danci1973
Member#: 19018
1995 Legacy Wagon
jeremy
What did you do? If it cools down the intake air significantly, then I wanna do it too!
D.
danci1973 is offline   Reply With Quote
Old 08-20-2002, 11:37 AM   #25
Jesse Lorenzen
Member#: 14962
2008 Impreza 2.5i
Pearl
I don't know what Jeremy did, but I recently put a valve in the coolant line that feeds the throttle body. I will have to open it a little in the winter, but I can still turn it off when I want the max performance. I cant give any numbers, but my throttle body is much cooler now to the touch.
Jesse Lorenzen is offline   Reply With Quote
anybody try JIC coilovers? RidinLow Brakes, Steering & Suspension 2 05-07-2002 09:47 PM
Anybody try "Twist a Dent"? dRu888 General Community 4 03-01-2002 09:41 AM
anybody try Mobil1 0w-30?? sidewayz Normally Aspirated Powertrain 19 11-13-2001 03:38 AM
anybody try/have/know about whiteline shocks? LttLDGN Brakes, Steering & Suspension 6 11-01-2001 06:16 PM
Anybody try to remove the 3M adhesive protectors? Arch General Forum Archive 1 09-21-2000 06:28 AM
