Old 10-02-2011, 08:00 AM   #1
Powermonky
Member#: 295056
Default accessport reading low boost
i ordered grimmspeed boost control solenoid jus cause but here it is
i own a 07 sti its got a stock set up other than tgv delete and sum air tank removeed it has summin to do wit emmisions ???
cobb ap reads 9.8-10psi is this stock this is from a third gear pull wot through power band full boost at roughly 3800 rpm car feels fast but i havnt ben in a boosted vehicle for a while and my last was a slug 99 gsx
i kno i have no leaks that i could detect the turbo outlet to turbo was iffy but i seated it better and tightnd good
Powermonky is offline   Reply With Quote
Old 10-02-2011, 10:36 AM   #2
Cobb Tuning
Member#: 4803
Do you have an AccessPORT v2 (small gray device with color screen) or v1 (black brick-looking device)?
Bill
Old 04-19-2012, 05:00 PM   #3
GravityDefyingSTI
Member#: 311445
2006 STI
Default Same issues
After searching for awhile I found this thread, but now follow up! So im hoping to bring it back.
I just bought stage 2 from perrin and I plugged in my AP to get some before and after boost number along with other stuff. Im only seeing 9.6 psi the best was 10.1 psi? This is low right? Car is completely stock. If anyone cam help that would be great, I was planning on installing my parts this Sat.
GravityDefyingSTI is offline   Reply With Quote
Old 04-19-2012, 05:54 PM   #4
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
instead of jacking someone elses thread, why dont you make your own... and include a datalog.
Black94Snake is offline   Reply With Quote
Old 04-20-2012, 08:51 AM   #5
Cobb Tuning
Member#: 4803
Hi there. Stage 2 maps are designed for a car with an aftermarket downpipe. Boost control will not be appropriate for a stage 1 (i.e. stock) car and you will likely underboost. Also, the peak boost you see is dependent on a number of factors including the gear you are in, start RPM of your WOT pull, and how long your run lasts. Best thing to do is to install your stage 2 parts and then get a data log:
Bill
Old 04-20-2012, 04:24 PM   #6
GravityDefyingSTI
Member#: 311445
2006 STI
okay great I will install everything tomorrow, just thought I would see what my stock boost was. I've hear 14.5 psi, so my 9.8 psi looked way low. plus I flashed to stage 1, which should of brought boost up? the car feels alittle stronger, but boost is still the same? I then flashed stage 1 high waistgate duty, still same boost! thank you for your input.
Old 04-20-2012, 04:36 PM   #7
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
If you are seeing the same levels of boost with both a nwg and lwg map, you have a boost leak.
Old 04-20-2012, 05:37 PM   #8
Cobb Tuning
Member#: 4803
If you have air pump delete, check your barometric pressure reading via the live parameters on the AccessPORT. If it shows something like 21 psi, then you have removed the ECU's only means of measuring baro pressure that is part of the air pump assembly. This will cause your boost reading to be much lower than actual. A normal baro reading will be around 14.7 psi at sea level.
If that is not the problem, then get a 4th gear log as outlined in the video posted earlier.
Keep in mind that an aftermarket BCS is not compatible with our OTS map and will require a custom tune after you install it (likely you will overboost without a custom tune).
Bill
Old 04-20-2012, 07:15 PM   #9
GravityDefyingSTI
Member#: 311445
2006 STI
Bill
https://docs.google.com/spreadsheet/...HpFWGtxYzBjbmc
Thanks for your help. im not 100% sure about the air pump, but the car is siad to be 100%. tomorrow I'm installing everything (stage 2) at the same time I'll check for leaks and the air pump. again thank you very much.
Old 04-21-2012, 12:38 AM   #10
Chasey
Member#: 242109
2004 WRX Wagon
Here is a oversight that may have been made. If you changed any vacuum lines, make sure you re-use the restrictor pill otherwise you will probably under-boost.
Chasey is offline   Reply With Quote
Old 04-21-2012, 09:46 PM   #11
GravityDefyingSTI
Member#: 311445
2006 STI
So i'm stage 2 now, im only boosting 14.5psi... car pulls harder, but with my perrin map boost should be at 18psi. i checked my hose and the pill is there, i didnt find any leaks. i checked baro pressure @ 14.7. so is it safe to say either i have a leak or maybe my bcs is bad?
Old 04-22-2012, 09:32 AM   #12
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
If the BCS is working, its probably not bad.
Cobb AP reading low boost xssasin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-01-2010 09:21 PM
Real Low boost readings on Accessport?? Kings028 Engine Management & Tuning 0 05-05-2010 09:41 PM
dyno reading low boost possibly Dekka98 Newbies & FAQs 3 06-02-2008 03:10 PM
Will Auxiliary Boost Controller fix Cobb AccessECU/AccessPort low boost issues? ImportVenom Engine Management & Tuning 2 06-23-2004 12:22 AM
accessport + VF30 = low boost? clamdip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-12-2004 06:29 PM
