Old 10-02-2011, 07:31 PM   #1
Jah91
Member#: 295101
2011 WRX Limited
Default Boost Readings W/ Datalog
2 Days ago I installed my SF and added the Stage 1 + SF 93 MTv300 on my 2011 WRX sedan. I did some recordings and I was not getting my target boost of 17PSI. Today I flashed the ECU with the 1 + SF 93 MTv300 HWD to see if I would get the 17PSI I was looking for and I got a 16.7PSI, which is good. However in one of my runs I got a feedback knock.
It would be great if I could get some feedback on my logs.
Thanks
1 + SF 93 MTv300 datalogs
https://docs.google.com/spreadsheet/...Gc&output=html
https://docs.google.com/spreadsheet/...VE&output=html
1 + SF 93 MTv300 datalogs HWD Datalogs
https://docs.google.com/spreadsheet/...mc&output=html
https://docs.google.com/spreadsheet/...FE&output=html
https://docs.google.com/spreadsheet/...Xc&output=html
Jah91 is offline   Reply With Quote
Old 10-03-2011, 09:55 AM   #2
Cobb Tuning
Member#: 4803
Thanks
The first log of the HWG map shows some a single count of feedback knock on mashing the throttle (which can be normal) and another single count as feedback knock is being ramped back to zero (which is the more concerning knock event). The rest of the logs do not show any knock events during your WOT runs.
I would take a few more 3rd gear WOT logs (if you can so safely) and see if that second knock event was a fluke or not. If you see it again, I would look at changing gas stations (to a name brand gas if you aren't doing so already), or you can run the more conservative 91 octane map while still running the 93 octane gas.
Bill
Old 10-03-2011, 10:38 AM   #3
Jah91
Member#: 295101
2011 WRX Limited
Bill,
Thanks for the response. Actually the first run with the HWD in the list was my third run. So there was a run before and one after without knocks. However I will follow your advice and keep testing. I will keep you posted with my results.
Thanks again,
Juan
Old 10-07-2011, 07:52 PM   #4
Jah91
Member#: 295101
2011 WRX Limited
Hello,
Here are my latest datalogs using the Stage 1 +SF 93 MTv300 HWD. It would be great if I could get some feedback. On these runs I did not get any knocks, but I did get a fine knock learn, and I really do not know what that means.
Thanks,
Juan
Datalogs
https://docs.google.com/spreadsheet/...t0NlE&hl=en_US
https://docs.google.com/spreadsheet/...JLX0E&hl=en_US
https://docs.google.com/spreadsheet/...NtaXc&hl=en_US
https://docs.google.com/spreadsheet/...tuZlE&hl=en_US
Old 10-08-2011, 10:41 AM   #5
Cobb Tuning
Member#: 4803
Hi Juan,
You'll need to set the permissions to public in order for us to view those logs.
Bill
Old 10-08-2011, 10:55 AM   #6
Jah91
Member#: 295101
2011 WRX Limited
Originally Posted by Cobb Tuning View Post
Hi Juan,
Bill
Fixed links!
sorry about that Bill, Im new to google docs lol
Old 10-08-2011, 12:16 PM   #7
Dj Xtz
Member#: 183720
2003 Impreza WRX
Sonic Yellow w/DGM 2-tone
Hey Juan, fine knock learning has to do with the ECU compensating for a knock event that occurred at the same Load/RPM. By the way, how did you get the boost target and gear columns to show up on your datalog spreadsheets?
Dj Xtz is offline   Reply With Quote
Old 10-08-2011, 02:04 PM   #8
Jah91
Member#: 295101
2011 WRX Limited
Should I worry about the learn? And to get different things on the datalogs, just go to datalog list and check off all you want the cobb to record
Old 10-09-2011, 09:49 AM   #9
Cobb Tuning
Member#: 4803
Hello,
Thanks,
Juan
Datalogs
You have some fine knock learning during the WOT run. Fine knock learning is the ECU's way of tweaking timing based on knock events. It detects knock and then applies a correction and keeps re-applying the correction in the revelant load/rpm range until certain conditions are satisfied (namely no knock in that cell) and then it slowly removes the correction (which it has started to do in your case).
I would give the 91 map a try while still running the 93 octane gas (make sure you reflash the 91 map - not flash as real-time). See if these events completely go away at WOT.
Bill
Reading Hydra Datalogs pollawrx06 Engine Management & Tuning 1 05-20-2009 07:45 AM
Reading Hydra Datalogs pollawrx06 Newbies & FAQs 0 05-18-2009 04:38 PM
Cobb AP Live Data Boost Gauge vs Datalog kwanjie AccessPort 6 05-15-2009 07:16 AM
Low boost problem with datalog horror show! yosemitemtb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-29-2006 09:10 PM
Tach reading vs. Datalogged RPM jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-09-2003 03:11 PM
