Old 10-02-2011, 11:16 PM   #1
JPN4
Member#: 248084
2003 WRX Wagon
Default Tuning or chipping a V6 EJ207
Have probably one of the biggest head aches for a tuning solution for my V6 sti. If anyone has any info on tuning for this car that would be awesome.
JPN4 is offline   Reply With Quote
Old 10-02-2011, 11:35 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Put a usdm wrx intake manifold and harness on it.
There's also link and power fc, hydra should work too.
Old 10-03-2011, 12:40 PM   #3
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
yeah you can go PowerFC.
or convert to USDM WRX since there is no AVCS to deal with. then you could just do an accessport or open tune
elislider is offline   Reply With Quote
Old 10-03-2011, 01:06 PM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
In Europe they can be Ecutek'ed...
Marnix is offline   Reply With Quote
Old 10-17-2011, 12:03 PM   #5
da_coolest
Member#: 236388
Sorry for hijacking the thread. But I also have the same engine and the same question as well! I asked few people about the Power FC and most of them told me to get something like haltech instead of power fc and power fc is not good enough. But still theres a huge price difference between those two. Can someone please clarify what would I miss if i buy the power fc instead of the haltech?
da_coolest is offline   Reply With Quote
Old 10-17-2011, 12:06 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Knock control. The power fc can not retard timing in response to knock.
Old 10-17-2011, 12:22 PM   #7
elislider
Member#: 133923
03 Legacy GT wagon
and to do real tuning with a PowerFC you need a datalogit interface ($350) or a tuner with the real Apexi interface (doubt theres too many of those if any in the USA)
Another option is the ViPEC but it costs more, about $1700. However, it is newer and more advanced and has direct USB connectivity
Old 11-03-2011, 03:52 PM   #8
darkcrave
Member#: 204753
2002 wrx
Its that simple? Just swap only the Intake Manifold and harness from a WRX? Would the STI Intake and harness work the same? Would you have to swap the WRX/.STI COP with it?
darkcrave is offline   Reply With Quote
Old 11-03-2011, 03:59 PM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's that simple. Yeah you'd need the COP too.
USDM sti is more work with DBW and all.
Old 11-03-2011, 05:01 PM   #10
darkcrave
Member#: 204753
2002 wrx
But if your using the Whole STI harness and ecu would the DBW still be a issue?
Old 11-03-2011, 05:08 PM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
No just more complicated
Old 11-03-2011, 05:19 PM   #12
darkcrave
Member#: 204753
2002 wrx
Gottcha! This is going to make my V5 STI Swap so much easyer with more tuning options
Old 11-04-2011, 03:27 PM   #13
elislider
Member#: 133923
03 Legacy GT wagon
There was a long thread about this on RS25, basically the way to go with a v5/6 engine, if you DON'T want to just use the v5/6 intake/wiring/ecu, and if you need emissions/OBD compatibility, is to use a usdm WRX intake, harness, and ecu, and just use the jdm longblock. That way you have all the mechanical performance benefits of the jdm engine (forged pistons, good valvetrain, etc) and the tuning options of a usdm WRX
Old 11-04-2011, 04:27 PM   #14
darkcrave
Member#: 204753
2002 wrx
any chance you can LINK me?
Old 11-04-2011, 06:08 PM   #15
elislider
Member#: 133923
03 Legacy GT wagon
well theres no point in reading the thread, i summarized it all just there. also i believe you have to switch your cam gears (at least the one on the left intake) to WRX style so the cam sensors work. but literally for all reference purposes you'd be doing a USDM WRX swap, except the longblock is JDM. youd have to get the wiring from a WRX and merge it with your chassis/dash harness.
Old 11-04-2011, 06:27 PM   #16
69subaru360
Member#: 159682
1995 WRX
2015 F150
I don't think you have to swap the gear. The V5-6 EJ207 is a phase 2 engine.
Old 11-04-2011, 11:06 PM   #17
darkcrave
Member#: 204753
2002 wrx
"FOR v5/6 Engines to pass in CA you need to swap over to a WRX ECU (which means wiring it up) and running the WRX intake manifold/cam gears/sensors/etc as talked about before."
So The 207 Will need the 205 cam gears?
Old 11-05-2011, 12:28 PM   #18
theonlygreat
Member#: 65916
1996 Impreza WRX
The more obvious tell would be the crank gear. The older style has only 6 knobs on it for the crank sensor and the newer one has like 36 little ones. If it has the newer crank gear, you are good to go. If it has the older one, then you need a new crank gear and cam gears.
You can see the difference HERE.
theonlygreat is offline   Reply With Quote
Old 11-08-2011, 12:32 PM   #19
elislider
Member#: 133923
03 Legacy GT wagon
you SHOULD swap over all 4 cam gears for consistency but you only NEED to swap the left intake cam gear (and the crank gear, as discussed) because those are the only 2 that have a sensor with them
Looking for 91 or 93 octane ver8 EJ207 timing map jblaine Engine Management & Tuning 13 03-10-2011 06:49 PM
Sreet Tune, Dyno Results: JDM STi EJ207 Blouch Dom3, dyno video too DuCash Proven Power Bragging 46 11-01-2009 11:25 AM
anyone have a jdm v6 ej207 maf housing or need a maf sensor? swapstar Subaru Conversions 2 02-04-2006 09:11 PM
Cusco Zero 2r's Or Zeal Function V6? fg1quest Brakes, Steering & Suspension 30 12-09-2004 10:44 AM
what first? upgrade the turbo or cooler or chip? YaZahX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 12-23-2001 04:41 AM
