Old 10-03-2011, 03:04 PM   #1
bzbuzz
Member#: 116052
2011 STI ( Sold )
Default 2011 STI Cobb stage2 + AEM map logs
Hi,
I just installed cobb downpipe w/ catback + AEM intake and flashed to stage 2 + aem map V3.00. Two files are I datalogged on 3rd gear and 4th gear from 3000 rpm to about 6000 rpm. I see some knocks that concerns me. It's still within 100 miles after flash so i think ECU is still learning but.. anybody can analylize logs for me?? anything that I should worry about?
and IDC is around 100% as well that worries me..
3rd gear:
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
4th gear:
bzbuzz is offline   Reply With Quote
Old 10-03-2011, 08:54 PM   #2
Cobb Tuning
Member#: 4803
You have a single knock event soon after hitting the throttle. This can be normal with a rapid change in load (try rolling onto the throttle to see if it goes away). I would start your run at a lower RPM (say a minimum of 2500 RPM). I would also reset the logging list to the default (this put TD boost error in the mix which will tell us how you are doing relative to your actual boost target). IDC near a 100% is not a problem.
Bill
2011 STI Stage 1+AEM vs Stage1+Cobb SF glamcem Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 47 12-04-2011 12:41 AM
2011 STI Cobb aem stage1 map datalog bzbuzz AccessPort 4 03-23-2011 12:08 PM
COBB Tuning AccessPORT 2011 WRX Stage2 and Stage2+AEM Maps Online! Cobb Tuning AccessPort 7 03-05-2011 12:58 PM
AccessPORT 2011 STI v1.07 AEM Intake Stage 2 Maps Available Now! Cobb Tuning AccessPort 2 11-06-2010 06:05 PM
AccessPORT 2011 STI v1.07 AEM Intake Stage 2 Maps Available Now! Cobb Tuning Vendor Announcements 0 10-25-2010 06:58 PM
