#1 |
Member#: 212576
SWIC
Vehicle:2007 impreza wrx sti pearl white |
I'm trying to install the sub003 AP on a 2011 wrx.
I have done all of the necessary steps prior to plugging in the accessport. When i click "install" on the accessport, it verifies the car, and then it makes me choose a map. I choose a map. It then says "cycle key", and I do so. Immediatly after I turn the key back on and press ok, it says " error; cannot connect to ecu please check cable". It doesn't install itself. It goes straight to choose map. I have tried redoing everything and starting over multiple times with no luck. I have plugged the green connectors in, and I have also tried it with them disconnected. Any help would be appreciated. Thanks.
#2 | |
NASIOC Manufacturer
Member#: 4803
You do not need to connect any diagnostic connectors for any of the cars supported by SUB-003. When called for, the key should be in the ON position with the engine not running. Bill |
| Thread Tools | |
| Display Modes | |
| AP v2 sub-002 installation problem | wordsarize | AccessPort | 9 | 07-21-2009 01:09 PM |
| AP v2 instalation problems | BlazeWRX2002 | AccessPort | 1 | 06-01-2009 05:48 PM |
| AP Install Problem | WanganWagon2002 | AccessPort | 4 | 09-20-2006 01:45 PM |
| ap install problem | TheKrazyAsian | AccessPort | 2 | 09-20-2006 01:08 PM |
| Cobb AP Install Problem | WanganWagon2002 | AccessPort | 2 | 09-18-2006 04:36 AM |
