Old 10-03-2011, 08:40 PM   #1
gt30sti92
Member#: 296651
Default NOOB on tuning - resetting ECU with AP
If i have an protune on a Cobb AP, and i have a CEL light / cruise flashing (emissions, loose or off gas gap)
do i risk loosing my tunes... (noob i know)....
and when i do click recet ECU on the AP, is it that simple, or do i have to do anything else previous to doing that.
gt30sti92 is offline   Reply With Quote
Old 10-03-2011, 09:02 PM   #2
Cobb Tuning
Member#: 4803
You can reset your ECU via the troubleshooting menu on the AP v2. Resetting the ECU will reset all learned parameters as well as clear the check engine light codes. It will not impact your reflashed map, but it will set your real-time map to the reflashed map values. You can go to Tune -> Show Current Map after the reflash to verify the map you have in each slot (reflash and real-time). The reflash map should always be the map that is designed for your mods and the octane gas you are running. Real-time maps are temporary maps you flash when you want to temporarily account for a change or a create a desired behavior, such as an anti-theft, valet, economy map, etc. Real-time maps are reset when you reset the ECU, reflash a new map, or disconnect the car's battery.
Bill
Tune and reset ECU JuggernautTCW Engine Management & Tuning 5 03-02-2008 08:55 PM
resetting ECU with AP aznmc16 AccessPort 1 10-10-2006 07:18 AM
Changing O2 sensor - reset ECU too? GTWagon_Phreak Legacy Forum 5 05-02-2006 03:42 PM
How often to reset ECU with AP 2hip Engine Management & Tuning 18 05-01-2005 09:13 PM
Reset ECU with MAP? Ryan24 Technical Forum Archive 2 07-27-2000 11:16 PM
