Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 10-04-2011, 07:13 AM   #1
millerlite6633
Member#: 288223
Default tdo4 to tdo5 swap
hey everyone just wondering, its safe to swap out my tdo4 for a tdo5 turbo and not have to worry about making other modifications right?
millerlite6633 is offline   Reply With Quote
Old 10-04-2011, 07:49 AM   #2
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
This was in the newbies section under subaru turbo list.
Blouch TD05H-16G
(275-330whp, Bolt-On)
Perfect for your 350 HP WRX project, the TD05H-16G features the efficiency of the Mitsubishi 16G compressor wheel combined with the lightning quick response of the TD05H turbine in an internally gated 7cm2 nozzle area turbine housing. Like all of our WRX/STI bolt on upgrades, the TD05H-16G is shipped complete with coolant pipes and turbo oil drain tube installed to simplify installation. The turbo is equipped with a standard wastegate actuator calibrated at 9 PSI and optional upgrade actuators are available in incremental pressures from 10 PSI to 19 PSI. The WRX TD05H-16G custom performance turbocharger is a direct bolt on upgrade and requires no modification to intake, exhaust, oil and coolant connections for installation.
Expect to achieve full boost with the proper mods and a quality tune between 3300-3800rpms. 2002-2005 WRX owners will need fuel upgrades for this turbocharger and proper engine management is highly recommended for all vehicles.
Purchase $700
KOJAK-02-WRX is offline   Reply With Quote
Old 10-04-2011, 01:11 PM   #3
RexWagonWA
Member#: 221945
Default TD04 to TD05 swap
Have you aleady replaced the stock uppipe and downpipe?
Larger injectors, higher capacity fuel pump, STi intercooler, and a good tune.
GLWYB
RexWagonWA is offline   Reply With Quote
Old 10-04-2011, 03:04 PM   #4
millerlite6633
Member#: 288223
well i found a tdo5 20 gauge and i have on the car sti up pipe with sti headers. So am i ok with that or should i upgrade a few other things?
Old 10-05-2011, 02:11 PM   #5
ArSoN9
Member#: 285777
2004 STi-
well the 20g is bigger than the turbo u first listed so ur intercooler will be a limiting factor if its still the stock setup.
Also like stated before the fuel supply will need increasing... injectors and pump are a must if u wanna push good numbers.
The sti exhaust manifold will be enough for now but u might want to upgrade in the future to see bigger gains.
If ur tuning the car urself u can do it in stages and make the map changes urself... if ur not the best tuner or want a good shops name on ur tune then maybe save up and do it all at once so they dont charge u for 3 tunes
Last edited by ArSoN9; 10-05-2011 at 02:12 PM. Reason: spelling and grammar--- im dumb
ArSoN9 is offline   Reply With Quote
Old 10-05-2011, 05:15 PM   #6
millerlite6633
Member#: 288223
yea well i was just thinking hey its not to hard to bolt on a new manifold and up pipe and i wasnt sure if the turbo would blow my car up or not with out any other mods first. I have been looking for a shop to give my car a nice tune but i dont know any in the area, and when you say tune do you mean take the ECU and get it updated pretty much?
From tdo4 to 18g + Utec = good **** Dr. octagon Mid Atlantic Impreza Club -- MAIC 19 03-15-2011 08:42 AM
wtb tdo4 to go back to stock Rdwrc Private 'Wanted' Classifieds 6 08-29-2007 10:05 PM
TDo4 to TDo5. my impressions snowman4us Subaru Conversions 2 08-07-2006 12:40 PM
Upgrading TDO4 To VF22 Questions? Gordata Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-20-2006 08:04 PM
Going from a TXS st1 w/TDO4 to VF29 do I need to change the map for now? Camperguy Engine Management & Tuning 7 08-06-2003 10:20 AM
