Old 10-04-2011, 08:46 AM   #1
4Warned
Member#: 66092
2011 STi sedan
COBB 20g [email protected]
Default 2011 STi Stage2 OTS mapping, 12.4's
Event: Quarter mile
Ambient Temp: 46.4 degrees Fahrenheit
Elevation: 919'
Weather: Slight tailwind, 66% humidity
Track and Conditions: Well prepped asphalt
Tires: Stock
Car: 2011 WRX Sti sedan
Tuner: Cobb AP, Stage 2+SF, 93 octane v3.0 OTS tune
Dyno Info: N/A
Transmission: 6 speed, factory gearset
Gear: 1st - 4th used (could have shifted into 5th)
Peak HP at RPM:
Peak Torque at RPM:
Baseline hp/tq for a stock on same dyno:
Target Boost: 19.5
Target AFR:
Fuel: 93 octane pump gas from local BP station, 1/4 tank
Engine/Power Modifications: Cobb catted DP, Cobb SF intake & airbox, STOCK exhaust
Driveline Modifications: NONE
Suspension Modifications: NONE
Other Modifications: Removed factory subwoofer & spare tire
2 weeks ago at the same track I ran a 13.3 stock as a baseline. At just under 1000 miles on the odometer I installed the stage 2 parts and tuning from Cobb. I went back to the track to see the difference and made the following passes. These were the 3 best slips of the day out of 7 passes. The slowest pass of the day being a 12.7 due to a bad launch. The best pass being a 12.42 @ 109.44mph with a 1.686 60'
I am extremely impressed how fast this car has gone with little mods and OTS tuning. In the spring I plan to get the car pro tuned and possibly put in a clutch more suited for drag racing. I am 100% sure low 12's are possible with some more passes and a pro tune
DCCD was in auto
T/C was off
Shift points were 6100rpm
Launches were around 5800 rpms
Did not shift out of 4th gear, probably could have yielded higher trap speeds if I did but was shooting for lower E.T's. I was around 6500rpm through the lights.
Video of the 12.44 run will be posted soon!
4Warned is offline   Reply With Quote
Old 10-04-2011, 09:13 AM   #2
erik11876
Member#: 275888
2011 WRX Limited
Awesome times man!
erik11876 is offline   Reply With Quote
Old 10-04-2011, 10:28 AM   #3
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Very consistent 60's, was this wasn't your first time at the track I take it?
Subian is offline   Reply With Quote
Old 10-04-2011, 10:57 AM   #4
CatfaceType-R
Member#: 81102
Launches were around 5800 rpms[/IMG]
great job, shift early with a vf(unless you are running all the bolt on's and are actually holding out power, which requires not the average tuner, but that's another story)
CatfaceType-R is offline   Reply With Quote
Old 10-04-2011, 11:14 AM   #5
stu
Member#: 25768
35R bugeye
Slowbaru
nice runs. get a race gas tune you will for sure be in the 11s.
stu is offline   Reply With Quote
Old 10-04-2011, 11:25 AM   #6
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Great driving!
jay25RS is offline   Reply With Quote
Old 10-04-2011, 11:52 AM   #7
4Warned
Member#: 66092
2011 STi sedan
Not at all
I actually still hold the fastest: stock turbo, manual transmission, diesel pickup truck 1/4 mile time in the country!
I have run hundreds of passes with various vehicles at this particular track.
Old 10-04-2011, 12:03 PM   #8
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Wow!!
This is awesome! We have a driver here, haha. Get some good gas in there!!
-Mikey
STi Mikey is offline   Reply With Quote
Old 10-04-2011, 12:33 PM   #9
smokey07
Member#: 151683
cummins?
btw, great driving! better gas and you'd be smacking 11's in the face!
smokey07 is offline   Reply With Quote
Old 10-04-2011, 12:39 PM   #10
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Very nice!!
Lets see it get nicer
Junior2JZ is offline   Reply With Quote
Old 10-04-2011, 01:47 PM   #11
4Warned
Member#: 66092
2011 STi sedan
Originally Posted by smokey07 View Post
cummins?
DURAMAX!
Old 10-04-2011, 03:44 PM   #12
9900rpm
Member#: 103733
2015 STI
ISM
Impressive times! Congrats.
9900rpm is offline   Reply With Quote
Old 10-04-2011, 05:34 PM   #13
dethvegi
Member#: 134502
2008 STI
SSM - 12.72 @ 107.66 stg1
Impressive. Stanton is a good track too. I'm hoping to hit similar times when I go stage 2 after winter. 12.72 stg1 sf. I'm on par to do it.
Your 60's are killer. Nice runs!
dethvegi is offline   Reply With Quote
Old 10-04-2011, 05:44 PM   #14
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Very nice time. Subscribing for the video.
WRXt4cy is offline   Reply With Quote
Old 10-04-2011, 09:10 PM   #15
Anexos
Member#: 222894
Nice times D-Rock. Bring it to IL for some runs.
Anexos is offline   Reply With Quote
Old 10-05-2011, 12:46 AM   #16
dangyo
Member#: 289786
2011 WRX Hatch
wow thats nice time. grats.
dangyo is offline   Reply With Quote
Old 10-05-2011, 12:53 AM   #17
mdelg035
Member#: 290433
2011 WRX
great times!!
mdelg035 is offline   Reply With Quote
Old 10-05-2011, 03:33 AM   #18
xandi911
Member#: 163991
Originally Posted by STi Mikey View Post
Wow!!
-Mikey
yeah man impressive 60ft
xandi911 is offline   Reply With Quote
Old 10-05-2011, 11:42 PM   #19
4Warned
Member#: 66092
2011 STi sedan
Default Videos
Old 10-27-2011, 11:07 AM   #20
KeithT
Member#: 76871
2011 STI
Charcoal Gray
Awesome!
KeithT is offline   Reply With Quote
Old 10-27-2011, 02:40 PM   #21
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow almost 110 with an OTS map? Is Cobb getting more aggressive? That's tough to hit even protuned. Great driving
Steve.804 is offline   Reply With Quote
Old 10-27-2011, 02:41 PM   #22
Anthonydinatale
Member#: 273143
2004 WRX
Great driving the fully built Sti at the midwest shoot out. Was higher then that pretty much the whole time. Lol
Anthonydinatale is offline   Reply With Quote
Old 10-27-2011, 09:13 PM   #23
Layvon
Member#: 195711
STi 04/05/06/07
Didn't see times cause I was busy filming. Not bad weather for mid october in MI!
Good driving our there!
Layvon is offline   Reply With Quote
Old 10-27-2011, 09:22 PM   #24
HotEvoX
Member#: 299250
super duper driver
HotEvoX is offline   Reply With Quote
Old 10-27-2011, 10:27 PM   #25
yeos
Member#: 133855
2009 STi SparkSilver
Dom Tuned @ MPS
That's some excellent drag racing skills you got there. Those times are killer!
yeos is offline   Reply With Quote
2011 STI Cobb stage2 + AEM map logs bzbuzz AccessPort 1 10-03-2011 08:54 PM
Any OTS 2011 STI OS Maps around? b1aze Open Source Reflashes 0 07-24-2011 07:29 PM
2011 STI OTS map vs Pro tune Jose Gordils Newbies & FAQs 6 05-09-2011 11:08 AM
COBB Tuning AccessPORT 2011 WRX Stage2 and Stage2+AEM Maps Online! Cobb Tuning AccessPort 7 03-05-2011 12:58 PM
Anyone running PE injectors instead of STI with OTS map newsubie1 AccessPort 4 02-26-2009 10:51 PM
