Old 12-17-2011, 12:52 AM   #1
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
Default EWG and Axle boot problems
Hey guys i just installed my ewg setup and i'm ready for a tune this sunday but i was just talking to a local mechanic and he said that the shop ran the ewg with dump tube which runs really close to the axle boot and they experienced problems with the axel boot melting or cracking.
I'm gonna be using the car as a DD and i'll get on it a few time when cruising with my buddies but is there some people out there that have experienced problems? I'd really like to maintain this car and i'd hate to get rid of the ewg setup as i just put it in.
let me know what you guys think.
pointblink19 is offline   Reply With Quote
Old 12-17-2011, 02:03 AM   #2
littlewhitewagon
Member#: 103068
11 STI sedan
Heat wrap the dump and make sure the exit is below all the important stuff.
littlewhitewagon is offline   Reply With Quote
Old 12-17-2011, 03:11 AM   #3
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
i heat wrapped and temp coated the dump tube. but there is no way the exit can be below the axle boot; it is right over the top of the axle boot;
but i figured since heat rises, the heat wouldn't be going down as much?
i'll try to snap a pic to show what i mean
Old 12-17-2011, 01:23 PM   #4
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
it is not a problem unless the dump tube is routed so that the exhaust exits directly on the axle. just make sure it's not and it'll be fine. I've had mine running for the last 6 months with no problems.
kenliu84 is offline   Reply With Quote
Old 12-17-2011, 01:42 PM   #5
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Its hard to tell you precisely what to do without really knowing how close it is to the boot and where it actually dumps the excess exhaust gasses. However, you can never be too careful... You can always welt on a small extension pipe to it IF it vents on top or in front of the boot and wrap it IF it sits to close to the boot on either side. That's what I would do.
Imprezer is offline   Reply With Quote
Old 12-17-2011, 08:59 PM   #6
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
it vents parallel to the axle boot but no actual exhaust gas is directed on the boot; i'll try to get a pic up tomorrow in the light.
Old 12-17-2011, 10:08 PM   #7
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
worst case make a new dump tube. 100 bucks maybe.
scby rex is offline   Reply With Quote
Old 12-17-2011, 10:30 PM   #8
WhyHelloOfficer
Member#: 193989
2004 Matte White GTO
Australian Racecar
I've got my dump tube heat wrapped and ceramic coated, and I haven't had any issues with mine yet. It dumps just below the axle, and it past it. Granted, during normal/moderate driving the dump tube isn't seeing any action, running a 21 psi spring.
This is how close it gets to my axle boot:
WhyHelloOfficer is offline   Reply With Quote
Old 12-18-2011, 01:05 AM   #9
isca21
Member#: 245029
I had my ewg setup all custom made because I have the maddad setup. So far my dumptube is fine imma look at it next week to make sure. I heat wrapped my dumptube just incase it leaned against the lines or axle boot but as long as the dump exit isn't right on or above your boot don't worry about it.
isca21 is offline   Reply With Quote
Old 12-18-2011, 08:48 AM   #10
WRX 2002
Member#: 11211
2004 STi
Rally Blue
I had to make an extension on the dump tube, at the track the high speed air going under the car directed the hot exhaust to the gearbox mounts and melted them. Not a nice sight with dripping molten mess.
WRX 2002 is offline   Reply With Quote
Old 12-18-2011, 09:28 AM   #11
AREA1320
Member#: 112508
so who actually installed it? As long as teh dump isnt hitting the axle dont sweat it.. nothing will melt
AREA1320 is offline   Reply With Quote
Old 12-18-2011, 09:14 PM   #12
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
i put it on my self; it isnt on the axle boot, but its right above dumping behind it i dont think any gas should be sprayed directly on it.
but i've run into another problem; there's a sensor or wire sticking out of the transmission that i see is starting to melt from the tune i had today
any ideas on what i should do to cover it or protect it besides extending the dump tube?
Old 12-18-2011, 09:27 PM   #13
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
21 psi spring? hell my 14.5psi spring is hard to open at first and WGDC is dropped almost all the way to zero. what turbo you going to run that you need that much holding pressure and that much boost at redline?
synolimit is offline   Reply With Quote
Old 12-18-2011, 09:31 PM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Mine has been like this for 3 years.
Old 12-19-2011, 01:45 AM   #15
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
so is the dump tube pointing at the ground?
anyone have the grim speed dump tube? i dont think it will point down just towards the rear of the car
Old 12-19-2011, 08:03 AM   #16
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This is how the GrimmSpeed dump tube sits, and many people run it without any issues.
Old 12-19-2011, 09:18 AM   #17
guygettnby
Member#: 298231
just heat wrap it and if you start to notice a problem just extend the pipe with an angle facing away from everything or have a new one made. you can buy the pipe and angles from any auto store and use band clamps to hold it all together so you dont damage the dump tube. the extension pipe and angles just slip on.
guygettnby is offline   Reply With Quote
Old 12-19-2011, 11:32 PM   #18
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
kk i'm going to try and fiddle around with it tomorrow and if not i'll just go to pepboys can get a pipe to clamp on; can yu post a picture of the clamps? im not sure what to get
Old 12-20-2011, 01:20 AM   #19
Imprezer
Dynamic Uno
Member#: 1
As they say... "Don't run with scissors..."
If you do, most likely you will not stab yourself in the face but if you do, it will suck.
Old 12-20-2011, 02:42 AM   #20
preacher#1
Top Scoob 022
Member#: 129894
FSTI '04 4EAT Sierra
Gold Metallic 20G-XT, EWG
Only on 8 months running complete gs mani /xpipe...ina addition to last tune we added the gs 38mm ewg, all coated & wrapped,,_ dump tube is flared out too, protecting cv plasti-boot by a few cm. well planned imo....
preacher#1 is offline   Reply With Quote
Old 12-20-2011, 07:53 AM   #21
guygettnby
Member#: 298231
this is just a quick search with a picture for you. they do make them in the size you need but you will have to search around abit.
http://www.jegs.com/i/Dynomax/289/33228/10002/-1?CT=999
if you can not find this style in the size you need then just use a regular crush clamp. make a few small notches/cuts on the end of the pipe that is going to slip over the dump tube if you go this route though. this is just so you dont have to crank down on the clamp as much and should not cause damage to the dump either if you do it right. plus it wont fall off..
hope that helps some, its hard to explain myself over the computer sometimes.
Old 12-20-2011, 08:28 PM   #22
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
kk so i had to get an extended pipe with a clamp due to the fact i have a erz catted downpipe and when i went to fix the dumptube it would be pinned next to the downpipe leaving me unable to mount it back on.
went to pepboys and got along 45 degree exhaust extension and had it bent to about 65 degrees then cut it to a good length, coated it with high temperature heat spray from thermotech and clamped it on the dump tube. the only issue that concerns me is the clamp is about a mm away from the transmission.
i shouldn't have a problem tho bc the uppipe nor wg should flex right?
Old 12-21-2011, 11:23 PM   #23
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
bumpp?
Old 12-22-2011, 07:42 AM   #24
guygettnby
Member#: 298231
i wouldnt think the pipe would flex, but there is a chance it will move some. think that the engine does move, but so does the transmission. if you think it will be a problem get some thermotec heat wrap and wrap the entire dump. around the clamp and all. but i dont think you will have an issue with it IMO
you could always have a bracket welded to it if your really that worried about it also. but i think thats just going over board with the whole thing. just drive it around and see if it makes noise or is affecting anything.
Old 12-22-2011, 02:58 PM   #25
pointblink19
Member#: 163844
2006 Stg. 3 SSR WRX
02 Black WRX Wagon
ok well as of now its not making any noise that i can notice; i'll probably end up heat wrapping the whole thing if i can't find a cobb catted dp where the cat is towards the end of the pipe.
one thing i do notice tho is a smell of some sort of gas, not sure if thats because of the fumes coming out of the wastegate or not. It could also be the pb blaster i sprayed before burning off so i'll wait a few days and see if that smell goes away.
edit*
one last thing also i was curious as to if anyone hears a "gargle" sound when they start to hit the throttle from the wastegate, i was tuned by sti mikey this weekend and he said its an exhaust leak, i've put in brand new grimmspeed gaskets in the uppipe but im also going to replace the turbo to the dp and see if that solves my problem but i'm pretty sure the sound comes out of the dump tube. I know that the wg only opens in boost so i initially first thought that the springs werent strong enough but i have a 1 bar spring in there on a vf43 which is more than enough.
any thoughts guys?
Front axle and CV boot on 2006 Outback 2.5i DrumNWReX Normally Aspirated Powertrain 6 07-12-2011 07:54 PM
Axle boot too close to coilovers problems? prem205 Brakes, Steering & Suspension 7 05-27-2010 10:42 PM
Axle boot and trans seals part numbers?? dukeduster Private 'Wanted' Classifieds 2 11-06-2008 07:33 AM
Front grille and rear axle boots scoobyimprza Mid Atlantic Impreza Club -- MAIC 6 05-04-2004 09:15 AM
My axle boot ring broke and my Boot slid off what to do? waitandbleed92 Transmission (AT/MT) & Driveline 1 02-23-2004 09:42 AM
