Old 10-05-2011, 10:08 AM   #1
kleedzine
Member#: 273531
02 frankenSTI
white
Default I cant reflash a map I changed in ATR
I am trying to use ATR. And I load the Cobb ots Stage1 93 map and change some table values (boost target). Saved it as different name. And transfered to AP. But I cant reflash the map I created to my 09WRX.
all firmware and software is updated to the latest.
Any idea?
kleedzine is offline   Reply With Quote
Old 10-05-2011, 11:56 AM   #2
Cobb Tuning
Member#: 4803
Any idea?
Hi there.
Is the map greyed out or do you receive an error message when attempting to flash? If the latter, what is the error message?
Bill
Old 10-05-2011, 12:20 PM   #3
kleedzine
Member#: 273531
02 frankenSTI
white
There's a message on AP about communication error, and ask to check the connection between AP and my car.
Old 10-05-2011, 01:15 PM   #4
Cobb Tuning
Member#: 4803
This doesn't sound like a map issue, but a general connection issue. Give the following a try:
1. Make sure the Cobb ODB cable is secure to the car's OBD port and the AP.
2. Before starting the process of changing maps, make sure the key in the ignition is set to ON (engine not running).
4. Go through the process of changing maps, when it indicates to cycle the key (i.e. turn it ON to OFF to ON again), do so (again, engine should not be running). As soon as you turn it to ON, hit OK on the AP to start the flashing process. If you hit OK too soon before turning the key to ON or too late after, the process will fail.
If you still have issues, give our tech support department a call:
866-922-3059
Bill
Old 10-05-2011, 03:01 PM   #5
kleedzine
Member#: 273531
02 frankenSTI
white
thanks for the input. I am at work so I'l try the method later.
But another concern is that I have no problem with reflashing any other cobb ots map.
It makes issue whenever I try to reflash with ATR revised, and saved map.
Oh and it appears to be processing ok for the first few seconds then the error message comes up.
Old 10-05-2011, 03:38 PM   #6
Cobb Tuning
Member#: 4803
Can you post up your modified map somewhere?
Bill
Old 10-05-2011, 03:54 PM   #7
kleedzine
Member#: 273531
02 frankenSTI
white
I'l try when I get home. Thanks for the help
Old 10-06-2011, 12:27 PM   #8
kleedzine
Member#: 273531
02 frankenSTI
white
It is been solved with simple flashing process change...lol
thanks Bill
Old 10-06-2011, 01:17 PM   #9
Cobb Tuning
Member#: 4803
thanks Bill
No problem. Glad to hear it!
Do you mind me asking what you changed? That would probably help other people with the same problem that read this thread.
Bill
Old 10-10-2011, 09:59 PM   #10
kleedzine
Member#: 273531
02 frankenSTI
white
it was so basic and stupid change.
1.key in and ignition on 2.connect the AP 3.flash -> no error
1.connect AP 2. key in and ingnition on 3. flash -> error
lol what a basic I have misssed.
Thanks again
cant reflash an 07 wrx Keif Engine Management & Tuning 10 01-15-2008 04:08 AM
MAP VE never changes in log... cdvma UTEC 3 08-31-2006 09:24 AM
STI Type UK - Change from Full Decat 2.5 to 3" - What parts of the MAP need changing? CustomScoobyIOM Engine Management & Tuning 0 03-01-2005 03:27 AM
Anyone using ECUTEK / COBB reflash map? Gethin Vancouver Impreza Club Forum -- VIC 23 09-18-2003 01:35 PM
When will a reflash/map be available for those w/ STi piping? SoLiDbReAkZ Engine Management & Tuning 4 05-13-2003 02:31 PM
