Old 10-05-2011, 11:34 AM   #1
97LegacyWagon
Member#: 294715
97 Legacy
Dark Blue
Default Can I use 02 wrx harness on 95 EJ20
Have 95 sti ej20 can i use a harness from 02 wrx would it fit and would it work right with a stock wrx ecu ?????
97LegacyWagon is offline   Reply With Quote
Old 10-06-2011, 01:18 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
short answer...
NO...
your 95 is OBDI and an 02 is OBDII...
not even close.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 10-06-2011, 02:42 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
No way. Or at least not without a lot (and I mean really a lot) of effort and modified or custom parts.
Marnix is offline   Reply With Quote
Old 10-06-2011, 07:50 PM   #4
iamianoliver
Member#: 215839
2002 Impreza WRX
Sedona Red
Its a piece of hardware, anything is possible. Yeah its not bolt up and go but it doesn't mean its hard
I'm running a phase 1 motor with a phase 2 harness and ecu.
You need to modify the one timing cam gear, put a WRX crank gear on the crank.
Run the STI intake manifold (what i did) and make a plate to allow the WRX throttle body's on board IACV to work.
You also have to make a bracket to hold the throttle cable in the right area. and block off the old IACV hole.
As far as engine management goes that's a personal preference.
And before i get flamed, I'm not saying its the best but it worked for me on a budget for a race car.
iamianoliver is offline   Reply With Quote
Old 10-10-2011, 07:41 AM   #5
subieguy87
Member#: 153412
1998 Impreza wrxRS
Phase 1&2 is alot different than obd I&II
subieguy87 is offline   Reply With Quote
Old 10-10-2011, 07:45 AM   #6
subieguy87
Member#: 153412
1998 Impreza wrxRS
Don't do what iamianoliver said... Get a turbo legacy wire harness(or the right one)
Old 10-11-2011, 08:50 PM   #7
Turbocrazy1
Member#: 297489
if he used the body/dash harness out of an 02?
Turbocrazy1 is offline   Reply With Quote
02 wrx harness on 04 wrx Whoa!ShutItDown Electrical & Lighting 0 09-24-2010 01:35 PM
need help. 02 wrx trannny on 95 1.8? 95imprezagc8 Transmission (AT/MT) & Driveline 8 08-14-2010 09:42 PM
Can I use EJ25 Oil Filters on a EJ20? jmeltzer4 Service & Maintenance 4 10-05-2009 06:33 PM
Can I use 2002 WRX wheels on 2007 WRX? skiracer Tire & Wheel 10 03-06-2008 04:13 PM
Can I use GC8 intake manifold on an EJ20? singincanary Subaru Conversions 14 12-30-2005 03:32 PM
