Old 08-04-2002, 07:21 PM   #1
ibis
Member#: 1132
Default Looking for tips on uninstalling an Apexi S-AFC...
Just bought one off of a friend parting out his RS. Is there anything I should look out for when uninstalling it? If I reversed the intruction steps would that be enough to uninstall it properly? Can I just cut the wires before the splicing into the ecu, and then reset his ecu?? I was hoping it would be easy, but I think its going to be a pain
Now I just need to jump on thar $309 borla header deal
-justin (ibis)
www.team-arg.com
ibis is offline   Reply With Quote
Old 08-05-2002, 09:58 AM   #2
phucvtec
Member#: 16261
2000 Impreza 2.5RS
Blue Ridge Pearl
It is my beleif that if the person you are buying the S-AFC from installed it properly, it should be quite easy. The installation package that comes with the S-AFC includes male an female connectors for the MAP/MAF sensor wire, so you will be able to just reconnect the two factory wires after uninstalling. As for the other wires, it depends on how well they were spliced in. Hopefully, you will be able to just remove them at a plug end, otherwise I suggest cutting the S-AFC wires very close to the splice and make sure you insolate them well. Then, reset the computer by removing the (-) lead for about an hour-hour and a half. Enjoy!
phucvtec is offline   Reply With Quote
Looking for tips on driving a automatic in autocross? Blue i'd Dragon Transmission (AT/MT) & Driveline 27 07-25-2011 07:47 PM
Looking for TIPS on a HYBRID build up quikcobra Built Motor Discussion 5 10-06-2008 06:34 PM
WTB: an apexi s-afc Dr. J New England Impreza Club Forum -- NESIC 12 02-24-2003 10:19 PM
Which shop in the Bay Area knows how to tune an Apexi S-AFC ScrambleBoost Bay Area Impreza Club Forum -- BAIC 2 07-18-2002 01:16 PM
Looking for tips on exhaust manifold removal Snowphun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-22-2002 08:28 PM
