#1 |
Member#: 305282
VIC
Vehicle:2011 STI Sedan Plasma BLUE |
Moms Santa Fe, Hyundai threw a code today while she was driving home. May I bug someone tonight? for a quick read? Ill even drive out to your place.
Just want to check what it is since she needs the car in the morning.
#2 |
Member#: 209685
Vehicle:2004 STI |
What year Santa Fe and how many Km's ?
#3 |
Member#: 305282
VIC
2011 Santa Fe - 28,xxx
#4 |
Member#: 301858
VIC
Vehicle:2011 2.5i |
Got a reader in west van...
#5 |
Member#: 165121
VIC
Vehicle:08 2.5i WRB |
I work in east richmond. Be leavin around 9ish back abby. Im on mobile so i can't see where you're located
#6 |
Member#: 214088
VIC
Vehicle:1995 WRX Type RA JDM YO!! |
as long as its not flashing than you should be fine, nothing to really worry about
#7 |
Member#: 305282
VIC
I am located in Guildford, Surrey. West Van is a bit too far.
#8 |
Member#: 79952
VIC
Vehicle:1999 RS/ 2004 WRX WRB/ JBP |
#9 |
Member#: 251482
VIC
Vehicle:2000 2.5RS silver 2011 Lexus, 1990 all-trac |
#10 |
Member#: 305282
VIC
Codes are pulled here is the verdict -
P0638 HYUNDAI - Throttle Actuator Control Range/Performance P2110 HYUNDAI - Throttle Actuator Control System - Forced Limited RPM Limp-Home Mode P2106 HYUNDAI - Electronic Throttle Control System Forced Limited Power |
#11 |
Member#: 209685
Vehicle:2004 STI |
Check for TSB's related to those codes. I think there may be an update related to those codes. If
Not it might need a throttle body |
#12 |
Member#: 214088
VIC
Ill look into it tomorrow at work
#13 |
Member#: 305282
VIC
Something I found the very first TSB -
http://engine-codes.com/tsb/hyundai/santa_fe/2011.html Bulletin Number: SB-10-FL-018 Bulletin Date: 2010-12-01 Component: Engine and engine cooling:engine Summary Hyundai: procedure to reset the electronic throttle control. *rm Read more: http://engine-codes.com/tsb/hyundai/...#ixzz2MAbGTrbA |
#14 |
Member#: 305282
VIC
Codes were pulled, car had problems.
Brought it to the Hyundai Dealership in Langley. Where all 3 Yap Brothers work. Jason flashed the car and so far no problems. Required a ECU Update / Flash. Thanks guys. |
