Old 10-06-2011, 02:34 AM   #1
2000subie
Member#: 207638
2004 WRX
Yellow
Default 2004 ej205 wrx hta68 last runs before built motor
2004 wrx with 80k on stock ej205 and 5mt car was full weight
Event: dyno pull / quarter mile
Location: revolutions performance colorado srpings, co/ S.R.C.A. dragstip Greatbend, Ks
Ambient Temp: 87/ high 60`s
Elevation: 2000
Weather: sunny calm day
Track and Conditions: asphalt, dusty, flat
Tires: nankan/245/17s
Car: 2004 wrx
Tuner: Adam Kennedy
Dyno Info: dyno dynamics
Transmission: 5spd gearset
Gear: 3rd
Peak HP at RPM: 287awhp 6700rpm uncorrected
Peak Torque at RPM: 290awtq 4300rpm uncorrected
Baseline hp/tq for a stock on same dyno: 2.0 wrx 150awhp/ sti 210-220awhp
Target Boost: 24psi tapering to 21-22psi at redline
Target AFR:11`s
Fuel: E85
Engine/Power Modifications:
hta68 8cm
walbro255
ID1000`s
turboxs fmic
turboxs mbc
k&n typhoon intake
38mm turbosmart ewg
grimspeed up pipe
individa downpipe
3in catless exhaust
AP v2
ebay inlet
Driveline:
excedy stage 2 clutch
Suspension Modifications: tienen springs, perrin sway bars
r/t - .584
60` - 1.764
330 - 5.101
1/8 - 7.836
mph - 90.31
1000 - 10.211
1/4 - 12.128
mph - 112.28
only decent run i had all night couldnt get my launches or 1st to 2nd shifts dialed
2000subie is offline   Reply With Quote
Old 10-06-2011, 08:02 AM   #2
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
There is a format for posting results in PPB. Please read this thread and update your post when you have time. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 10-06-2011, 03:05 PM   #3
rexblake
Member#: 178426
2010 S4
Gray
Nice runs, that's booking it at altitude. Love the uncorrected numbers btw. Screw this huge correction factor/ high reading dyno bs.
rexblake is offline   Reply With Quote
Old 10-06-2011, 11:45 PM   #4
2000subie
Member#: 207638
2004 WRX
Yellow
thanks i deffinatly supprise a few ppl and i agree everyone argues when really it all comes down to times over numbers
Old 10-08-2011, 01:11 PM   #5
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Great times! Are you going with a larger turbo with the built engine?
Steve.804 is offline   Reply With Quote
Old 10-08-2011, 08:14 PM   #6
liltoua
Member#: 206802
1998 2.5rs
Those HP/TQ numbers seem really low for running E85.
liltoua is online now   Reply With Quote
Old 10-08-2011, 08:56 PM   #7
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
^ That's what I was thinking. Those 1/4 mile numbers look good though. I made 300 whp and tq with a vf39 and complete supporting mods minus the EWG and E85 on my 02 wrx.
JdMS13 is offline   Reply With Quote
Old 10-08-2011, 09:11 PM   #8
rexblake
Member#: 178426
2010 S4
Gray
Lol that's cause it's a low reading dyno (aka realistic), uncorrected, at altitude. His 1/4 mile runs would be about a 11.6 at sea level. That is some power and drastically more than your vf39 setup.
Your not even close to 300whp on a vf39 with pump gas. That's simply a shop trying to get business by having a high reading dyno.
Old 10-08-2011, 09:26 PM   #9
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Yup, just look at the baseline #'s.
Dave D. is offline   Reply With Quote
Old 10-09-2011, 01:10 AM   #10
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
+2
Seems like most shops with DD dynos always use a 1.1-1.2 correction factor. This car makes good power and the trap shows. If you used a 1.2cr on the OP car it would be 344whp
Old 10-11-2011, 12:41 PM   #11
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
Your not even close to 300whp on a vf39 with pump gas. That's simply a shop trying to get business by having a high reading dyno.[/quote]
Is this guy serious? ^ lol. There are thousands of bugeye wrx's with the same setup I have "vf39" and supporting mods that make sometimes over 300whp on atleast 4 different kinds of dyno's. I literally watched them dyno my car with a 1.0 correction factor and came up just over 300 at the end. Look at the power proven braggin and 2.0l forums. I run 93 octane and basically ran out of other mods besides bigger turbo, injectors, head/block work, and ewg and hit it somewhat easily. Why are you hating on the vf series turbo's?
- Dave
Old 10-11-2011, 12:55 PM   #12
dux10
Member#: 235338
2002 Faggin Wagon
srp
Baseline numbers say that the car lost 34% of its power at the crankshaft (227>150ish). that doesn't sound too realistic.
dux10 is offline   Reply With Quote
Old 10-18-2011, 03:08 AM   #13
2000subie
Member#: 207638
2004 WRX
Yellow
thanks i was happy with it and yes i will most likely go rotated 35r im going to run a destroked 2.35 and upwards of 8500rpm so i need alot of air lol
Old 10-18-2011, 03:13 AM   #14
2000subie
Member#: 207638
2004 WRX
Yellow
its uncorrected if the would have corrected it to sea level which i believe is 1.5 correction i would have been in the 350 range they said but im not big for numbers id rather go for time the set up i ran before was a vf22 iwg on 600cc injectors with TBE and fmic on 18psi on 91oct i only made 235/241 but ran a best of 12.63 at 106
Old 10-18-2011, 12:54 PM   #15
JdMS13
Member#: 207299
2002 MBP Bugeye
Out Of Commision
Numbers for the vf22 were that low? Wtf mate.
Old 10-18-2011, 02:53 PM   #16
wrxlaunch
Member#: 181298
300whp is def possible on pump and vf39/43... With 1.0 cf search mi friend
wrxlaunch is offline   Reply With Quote
Old 10-18-2011, 04:16 PM   #17
2000subie
Member#: 207638
2004 WRX
Yellow
its a low reading dyno with no correction low boost and ****ty 91oct fuel ill add both dynographs tonight
Old 10-19-2011, 10:07 AM   #18
rexblake
Member#: 178426
2010 S4
Gray
- Dave
Yes, I'm serious. It's common knowledge actually. Granted, you should be close on higher reading dynos. On low reading you would be around 250-280ish.
Dyno's can say whatever you want them to say peak hp wise. That's the benefit of different styles, different correction factors, and different operators. The dynojet, and more particularly, the dynocom and dynopack dyno's can show ridiculous numbers. There was one kid from Florida in PPB that had a small 16g (35lb/min) that was supposedly producing 400whp on a dynopack on pump gas. Obviously he wasn't, that's impossible. Take the numbers with a grain of salt.
Another example, my 68hta setup made 342 uncorrected on a dyno dynamics, in shoot out mode (which reads like a dynojet, 1.16cf) it was 396. Did I pick up 50whp? Of course not. Hell, the Moon Dyno The Shop uses just has a 1.2cf, if I used that cf I would have been at 410whp. I know that the 68hta isn't a 400whp turbo.
FS : VA: 2007 Rotated 30R WRX TR 23,xxx miles BUILT MOTOR cgmURABU5 Private Vehicle 'For Sale' Classifieds 33 12-15-2010 07:00 PM
FS NY: 07 WRX Wagon w/ 6speed, 37r, built motor + 20k miles vivalaWRX Tri-State Area Private Classifieds 78 10-04-2010 01:45 PM
what oil pans r u running with built motors.. gmanwrx Built Motor Discussion 25 11-02-2008 11:25 PM
