Old 08-04-2002, 09:54 PM   #1
archer
Member#: 9234
1998 2.5 RS
Default Just Replace Battery and lights won't tstop blinking
I am searching old threads now, has anyone seen this before?
archer is offline   Reply With Quote
Old 08-04-2002, 10:40 PM   #2
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
Yes, the problem resides in your alarm/keyless entry system. Try using your remotes. They need to be reprogrammed into the system for it to work. The old systems work this way. If you don't have any transmitters you could buy some from the dealer or have the system removed.
jake
KONKILR is offline   Reply With Quote
Old 08-04-2002, 10:43 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you need to disarm your alarm/keyless system. and i have managed to erase my keyless entry transmitter info before just by hitting the button while i was turning off the ignition switch.
jeremy
Old 08-04-2002, 10:44 PM   #4
archer
Member#: 9234
1998 2.5 RS
Ahhh, yes indeed you are correct. I found this in an old thread and fixed this problem. Thanks for your reply
Old 08-05-2002, 12:59 PM   #5
bratmantlz
Member#: 3231
88 626 Turbo
white
yep hit the lock/unlock button and your good to go no blinking lights.
bratmantlz is offline   Reply With Quote
Hazard Lights Won't Stop Blinking cdunbar Newbies & FAQs 2 12-26-2008 12:07 PM
Replaced battery, now lights blink subiekid Legacy Forum 3 01-18-2008 10:40 PM
Help! I disconnected my battery and now the hazard lights keep blinking! Pleasehelp Electrical & Lighting 6 09-25-2004 05:03 AM
need your help! just finished clutch and light flywheel blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-13-2003 11:53 AM
Can I just replace midpipe and keep stock exhaust? bedabi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-16-2001 04:46 PM
