Old 10-06-2011, 08:47 PM   #1
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
Default Turbo Interchangeability Question?
Does one know of any IHI or VF series turbos that you can swap an ej20g turbo (TD05h or TD04 90* inlet) compressor housing on?
Thanks,
Chris
chrisc1991 is offline   Reply With Quote
Old 10-07-2011, 03:30 AM   #2
pmugabi
Member#: 280926
None. However with a 90 degree silicon bend and a bit of metal tubing, you can make those turbos fit the EJ20G turbo inlet hose.
pmugabi is offline   Reply With Quote
Old 10-07-2011, 04:46 AM   #3
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
What do you mean? I have a ej20g motor, td04, and a ej20g short ram kit (his specific)?
Thanks,
Chris
Old 10-07-2011, 09:24 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can't swap a TD04 or TD05 cold side onto any IHI vf turbo.
Why would you anyway? The stock TD05 16G that comes on the EJ20G is bigger than any VF series.
Old 10-07-2011, 11:17 AM   #5
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
Bump!
Old 10-07-2011, 11:43 AM   #6
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
Not that big on 4k boost! Would prefer to find something with a little less lag
Old 10-09-2011, 04:52 AM   #7
fxt05
Member#: 208521
'96 STI Type RA
'05 FXT
I would never call my td-05 laggy. I guess it does boost right before 4k but with my ra Trans 4k comes before I know it and pulls way past 7.5k.
fxt05 is offline   Reply With Quote
Old 10-09-2011, 08:54 AM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
On my EJ20G with the TD05 16G, I tightened up the wastegate actuator 4 turns and backed off the MBC a bit, this made a good difference in spool up.
Maybe now that these are getting to be 15 years old the springs in the actuators are getting old and need to be adjusted tighter?
Old 10-09-2011, 08:23 PM   #9
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
Thanks for all responses guys! I guess I am just gonna stay with my td05h, I do love the rocket ship thrust once you hit 4k though!!!!! I will definitely try turning the actuator out
-Chris
Old 10-09-2011, 08:49 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Only tighten up the actuator if you have a mbc or ebc. You will need a way to lower the boost in the higher rpms/gears.
Old 10-09-2011, 08:53 PM   #11
jdmwrx94
Member#: 211619
94 jdm wrx
red
At wich RPM you had full boost before tightening it and after? I get 15 psi at 3800 running a home made mbc with a catless 3in downpipe, should it be better?
jdmwrx94 is offline   Reply With Quote
Old 10-09-2011, 08:56 PM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
Mine has bigger injectors, a chipped ecu and a lot more boost so it's probably not comperable. But before it was over 4000 and now it's less than 4000. I'll try to look at the tach more closely, but seat of the pants it's a lot better.
Old 10-09-2011, 09:03 PM   #13
chrisc1991
Member#: 173221
01 GC8 Ver 1 RSTi
94 JUN. 82/200 STM
I have an EVC boost controller.
MHI turbo interchangable? chad1979 Newbies & FAQs 8 05-28-2008 08:35 PM
Strut interchangability question rallyken Brakes, Steering & Suspension 2 09-24-2007 01:25 PM
4eat trans interchange question mikemyer Transmission (AT/MT) & Driveline 2 06-13-2006 07:13 PM
Turbo Interchangeability f4phantomii Newbies & FAQs 2 06-14-2004 11:19 PM
parts interchangeability question? Benjamin Tang Legacy Forum 1 03-11-2001 12:29 AM
