Old 10-06-2011, 09:09 PM   #1
invaderzim
Member#: 201991
2011 wrx dom3'd
satin white pearl
Default Stage1+SF 93 not reaching ~17psi
I have a 2011 wrx with SPT cat-back exhaust and the cobb intake. I was watching the boost through the AP and noticed that the highest boost I'm obtaining is 15.5-15.9psi.
It seems like the car was boosting a bit higher before I had the intake installed (over 16psi) but it still feels fast. Just wondering if I should try a high wastegate or low wastegate map and if not what should I do to get more boost?
invaderzim is offline   Reply With Quote
Old 10-06-2011, 09:24 PM   #2
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
try the normal wastegate map.the other map is primarily for west coast owners with lower octane fuel available. what octane are your running? ive always used 93 in mine. i see 22 psi with a stage 3 custom tune.
424wrx is offline   Reply With Quote
Old 10-06-2011, 09:58 PM   #3
WiRX
Member#: 205930
Your going to want to try the High Wastegate map.
WiRX is offline   Reply With Quote
Old 10-07-2011, 08:01 AM   #4
Cobb Tuning
Member#: 4803
Keep in mind that your actual boost target can vary by gear, throttle position, RPM, RPM you start your run in, altitude, outside temperature, etc. For example, you will not hit your boost target in 1st and 2nd gear (this is normal). You will also not hit your target in high gears if you do not allow time for boost to build (boost is not instantaneous).
If you can do so safely, try to get a data log of a 3rd gear wide open throttle run from about 2000 RPM on up (up to near redline if you can do so safely). This will give us a good picture of what boost control is doing.
Here is a general video on how to data log with the AP v2:
Just use the default logging set (do not remove or add any parameters).
Bill
Old 10-07-2011, 11:47 AM   #5
invaderzim
Member#: 201991
2011 wrx dom3'd
satin white pearl
Thanks for the response! I will try to data log 3rd gear later today and get back to you.
Old 10-08-2011, 01:37 AM   #6
invaderzim
Member#: 201991
2011 wrx dom3'd
satin white pearl
here we go. did a 3rd gear pull from ~2500rpm to ~7000rpm. it never went past 16psi.
https://docs.google.com/spreadsheet/...=0&output=html
also this was on a mostly flat road with temperatures at about 50F and one passenger.
Old 10-08-2011, 10:44 AM   #7
Cobb Tuning
Member#: 4803
Log looks good other than the low boost (no knock). I would go ahead and give the high wastegate (HWG) version of the map a try.
Bill
Old 10-24-2011, 07:01 PM   #8
damonhimself
Member#: 235835
2011 WRX 5DR
That is not correct information.
damonhimself is offline   Reply With Quote
Old 11-03-2011, 08:24 AM   #9
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
I just did the same thing on my 2011 wrx hatch.
SPT exahust
COBB SF + Stage 1 93
I was running just the map for 2000 miles before i put the SF w/air box on. Now the car definitely feels slower. Its hitting boost around 17psi, but its taking longer to get there, and its not as "violent" as before. Based on how it acted before I can tell a difference, and I'm not sure why. Seems a lot more "laggy" with the CAI and the new map then just with the MAP before.
subiebosch is offline   Reply With Quote
Old 11-03-2011, 10:17 AM   #10
Cobb Tuning
Member#: 4803
SPT exahust
Best thing to do is to get a data log and we can see how things look:
If it hasn't been very long since you reflashed the map for the SF intake, then give the ECU some time to learn. Reflashing a map clears all learned ECU functions.
Bill
Old 11-03-2011, 10:26 AM   #11
subiebosch
Member#: 155548
2015 2500 Dmax
Sir,
Thanks for the reply. I drove less then 100 miles on the new map and that's mainly highway driving. I'm not too concerned since I do hit boost at 17psi. But I will drive it some more, and take a log of a pull as well.
Andrei
Old 11-03-2011, 09:31 PM   #12
subiebosch
Member#: 155548
2015 2500 Dmax
Bill,
here is the log that i took....weather was 52F.
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
2011 WRX, SPT cat back, COBB intake with airbox. car has about 7.5k miles on it.
Been running the COBB stage 1 + SF 93 MTv300 map for about 110 miles now. but for the last 2k miles i was just running the stage 1 93 map....which to me seemed a lot more peppy....but it could be just me.
Let me know what you think. Much appreciated Sir.
Andrei
Old 11-04-2011, 09:42 AM   #13
Cobb Tuning
Member#: 4803
Bill,
Andrei
Log looks good. You are underboosting a tad, but it is borderline. You could try our high wastegate map (HWG) and see if that gets you closer. Although that could cause you to overboost in higher gears when you go WOT. Hard to tell though without trying it. Won't hurt to try, but make sure you get the same type log and post it up here. The HWG map can be found in our map repository:
http://www.cobbtuning.com/info/?ID=3061
You then would transfer it to your AP via the AP Manager software and then reflash the HWG map to your car.
Bill
Old 11-04-2011, 09:49 AM   #14
subiebosch
Member#: 155548
2015 2500 Dmax
Thanks for checking Sir,
I think I'll stick with this map for now, i really don't want to get into overboosting and i'm pretty close to my target boost. i'll try the other map soon and see how high my boost will get up to compared with this map. I already have all the maps uploaded to my accessport.
Thanks again for checking Bill,
Andrei
Old 11-04-2011, 07:34 PM   #15
PearlRex11
Member#: 284420
2011 WRX Sedan
I just put mine on and flashed the acn91 + sf map. Didn't buy the box yet just the intake. This thing sounds crazy, louder than I thought it would be even though I had read the various comments. I love it. I am getting 16.8psi.
PearlRex11 is offline   Reply With Quote
Old 11-04-2011, 07:46 PM   #16
subiebosch
Member#: 155548
2015 2500 Dmax
16.8 psi is not bad considering you're running 91 map. i was getting 16.5 (around there) during my 3rd gear pull.
and yes, the intake is awesome...it looks better with the airbox, and it keeps the heat from the engine away better, i would invest in the box, just my 2 cents.
Old 11-05-2011, 12:12 AM   #17
PearlRex11
Member#: 284420
2011 WRX Sedan
Yeah I plan on getting the box in december. Yeah I didn't hit redline in that run cause I ran outta room. Did hit about 6k though.
Old 11-08-2011, 12:41 AM   #18
PearlRex11
Member#: 284420
2011 WRX Sedan
Nevermind now since I came back from a 200 mile trip and filled up with Shell 91 instead of Costco 91 I am not hitting 16.8 anymore. Can someone please help me with my datalog it appears that I am not hitting target boost and it shows some fine knock learning. Sorry to threadjack but this might help solve your problem too.
https://docs.google.com/spreadsheet/...wdGJLS2c#gid=0
Old 11-08-2011, 08:08 AM   #19
subiebosch
Member#: 155548
2015 2500 Dmax
Try the high wastegate setting map and do another pull, that's what the advice from COBB was for me when I uderboosted.
I have always wondered if getting fuel form other places can have an effect on the engine. Maybe its just a bad batch of fuel....that might explain the knock learning as well.
Old 11-08-2011, 10:28 AM   #20
Cobb Tuning
Member#: 4803
Hi. I responded to your question over at the cobb forums.
Bill
Old 11-08-2011, 11:21 AM   #21
PearlRex11
Member#: 284420
2011 WRX Sedan
Your great man. I appreciate your help very much.
Old 11-08-2011, 12:21 PM   #22
PearlRex11
Member#: 284420
2011 WRX Sedan
I will post my datalog from the hwg map later today. Don't think its what I need because I had the target boost showing during logging and it hit 21.2. Yikes!
Old 11-08-2011, 12:25 PM   #23
subiebosch
Member#: 155548
2015 2500 Dmax
yeah thats why i went back to just regular map. mine hit 19.2 and that was too much for me. it was worth a try tho.
Old 11-08-2011, 06:50 PM   #24
Derek11WRX
Member#: 296224
2011 STi Sedan
Plasma Blue Pearl
Hm I'm having a similar problem. I have Cobb stage 1 + AEM intake. I'm only seeing 14.5 psi in 3rd gear though. I finally saw 15.8 in 4th. I wonder if I should try the HWG map.. although you guys both saw overboosting
Derek11WRX is offline   Reply With Quote
Old 11-08-2011, 07:54 PM   #25
PearlRex11
Member#: 284420
2011 WRX Sedan
Now I am not so sure that it was overboosting. I saw 21.2 on the target boost while I was datalogging but then when I get home and look at the datalog it isnt going over 16 or so??? I waiting to here back from Bill on the Cobb forum. I will post here what I find out.
Stage 2 93 Octane not reaching full boost chodeman07 AccessPort 19 04-01-2013 08:40 AM
Low boost with Stage1+SF 93 map JordanM9 AccessPort 11 02-20-2012 07:18 AM
Boost Gauge not working...not reaching peak boost. mnwrx78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-29-2006 10:20 AM
help - not reaching normal boost S-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-09-2003 07:02 PM
WRX not reaching 44 in 1st MrWRXNYC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-18-2002 07:35 AM
