Vancouver Impreza Club
Old 10-07-2011, 12:42 AM   #1
07WRXwgn
Member#: 150901
2007 Impreza WRX wgn
Obsidian Black Pearl
Default rear clutch-type LSD question
I ordered the LSD rebuild kit from rallispec.com. I had my mechanic rebuild the rear LSD in my 06 STI. He packed in an extra set of clutch plates. He did the work back in June of this year. I did approximately 30 minutes of figure-8 to break in the rear LSD.
4 months later, the rear LSD still clucks and chirps in slow corners. Is this normal? Will this damage the centre diff and gearbox?
Thanks for input!
Victor
07WRXwgn is offline   Reply With Quote
Old 10-07-2011, 03:51 AM   #2
Loomin
Member#: 118113
98' Stagea 260RS
Autech Ver.
extra plates = extra lock.
factory plates = factory feel.
Essentially you have made the LSD more aggressive. the clunking/chirping is from a locked diff and the inside wheel skipping around corners.
it shouldnt damage the centre diff (especially an active DCCD diff) or gearbox, but it will put extra strain on the rear end parts especially the CV axles etc.
Loomin is offline   Reply With Quote
Old 10-07-2011, 01:57 PM   #3
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
I put an Auburn diff in my Tundra which is a clutch type LSD, and it does the same thing. Like Loomin said, it's the nature of the more aggressive diff.
steve is offline   Reply With Quote
Old 10-07-2011, 02:58 PM   #4
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Turns out more grab gives you more grab :P
Splinter is offline   Reply With Quote
Old 10-07-2011, 04:59 PM   #5
Stab Master Arson
Member#: 222926
2006 Impreza WRX STI
SGM
Normal, mine does that turning at full lock.
Stab Master Arson is offline   Reply With Quote
Old 10-07-2011, 09:12 PM   #6
clsmooth
Member#: 86394
2000 RS Coupe
Blue Ridge Pearl
Same thing happens in my cousins Justy when slowly turning in 4WD...
clsmooth is offline   Reply With Quote
Old 10-08-2011, 03:37 AM   #7
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
It can't be as bad as it was before right?
One of the reason I don't feel like rebuilding my R180 :P I'll probably just swap it out for a torsen unit later on.
minifreak is offline   Reply With Quote
Old 10-19-2011, 04:48 AM   #8
07WRXwgn
Member#: 150901
Hello all,
Thanks so much for all the useful input and feedback. I am glad to hear the clucking and chirping from the rear clutch-type LSD is normal. I've noticed less clucking and chirping with a recent Motul 90PA Gear Oil change for the LSD.
Victor
ps. Mr. Yang, will you be autocrossing on October 30?
Old 10-19-2011, 01:50 PM   #9
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
A good fluid is important, but also that you're running the proper friction modifiers. I know that with my diff, I need to run additives blended for use in the rear end.
Help: STI rear seat parts question spaber05 Interior & Exterior Modification 1 10-07-2011 09:30 AM
rear diff lsd question route69wrx Transmission (AT/MT) & Driveline 4 04-07-2009 09:01 PM
Rear LSD Question FalconRS Transmission (AT/MT) & Driveline 9 12-21-2005 09:13 AM
Important Rear LSD question... G-shock STi Forum Archive 1 08-24-2003 01:08 PM
rear LSD questions rrubel Transmission (AT/MT) & Driveline 3 08-23-2001 03:48 AM
